Hot Rods Model T Spring Banjo rear end
Discussion in 'The Hokey Ass Message Board' started by spencer boehm, Jan 4, 2021.
  1. spencer boehm
    spencer boehm
    Hi I have a model t spring that I want to run on a banjo rear end. I am wondering what shackles I will need to make the work I belive the spring is 43.5 inches eye to eye. Any help is much appricated.
  2. RICH B
    RICH B
    We used 2-1/4" shackles with machined DOM tubing washers to match the narrower width of the T spring.
    Stock banjo axle perch width is good with the T spring.
  3. spencer boehm
    spencer boehm
    The tubing is to change the ID on the spring?
  4. T spring is 2”wide. Later rear spring is 2-1/4” wide. You either need to trim the length off the perch or add a spacer to make up the difference. I’ve done both.
    Baron Engineering likes this.
  5. spencer boehm
    spencer boehm
    appricate it thank you
    cactus1 likes this.
  6. Tim
    Tim
    from KCMO
    Put spacers on my model A banjo to run the T spring like @cactus1
  7. RICH B
    RICH B
    The spring ID is the same.
    The spacers go on the shackle pin bushings to make up the difference in width as others have posted. We made the spacers the same OD and ID as the spring eye to blend in better.
    Tim likes this.
  8. spencer boehm
    spencer boehm
    where would i purchase the corret shackles? Also the axle has the press in metal sleeve style?
  9. rusty valley
    rusty valley
    you dont say what axle you have. a model A would have used a metal bushing pressed in, and a v8 would have had a pressed in combo of the pin, surrounded by some sort of rubber compound with a metal sleeve around the whole thing. sometimes, the metal sleeve is all thats left. either way, get the sleeve out and buy what ever you like from the vendors. model A, v8, or most folks today like the urethane bushing type for ease of installment. speedway for those, brattons for A parts, and c&g for v8 stuff
  10. I got mine from CW Moss Ford Parts along with deeper rear spring clip bars to **** the t-spring into the crossmember.
    I used the top leaf of the A spring and replaced it on the T spring to keep everything in place inside the crossmember, ****ed it down in there and settled nice, add shocks to limit rigidity. Can't tell really well from this image but it's a tight two fingers between the top of the rear tire and fender lip. green coupe.jpg
    spencer boehm likes this.
