Projects 1927 T Roadster Build
Discussion in 'Traditional Hot Rods' started by Joe Coughlin, Dec 16, 2020.
  1. Tim
    Tim
    from KCMO
    Looking good. If your battery is going to live inside that tool box make sure it’s vented :)
    loudbang and Joe Coughlin like this.
  2. Joe Coughlin
    Joe Coughlin
    Thanks, I’ve still got to add a vent fitting and tube to take it out of the truck floor as well
    Tim and loudbang like this.
  3. Olskool13
    Olskool13
    from Queens NY
    Joe Coughlin and loudbang like this.
  4. Joe Coughlin
    Joe Coughlin
  5. Joe Coughlin
    Joe Coughlin
    Some pics of the metal repair on the turtle deck and straightening the rear panel
    IMG_6714.JPG IMG_6728.JPG IMG_6739.JPG IMG_6742.JPG IMG_6701.JPG IMG_6702.JPG IMG_6703.JPG
  6. PINEAPPLE
    PINEAPPLE
    very cool build. I love t roadsters and model A engines.
  7. getow
    getow
    Awesome progress since da last time i checked in. Top notch.
    Joe Coughlin likes this.
  8. 26 T Ford RPU
    26 T Ford RPU
    Very impressive build, there is something about these T's on A frames. Following along with interest!! JW
  9. Joe Coughlin
    Joe Coughlin
    Thanks.
  10. Joe Coughlin
    Joe Coughlin
    Thank you
  11. Joe Coughlin
    Joe Coughlin
    Thanks
  12. junkyjunkie
    junkyjunkie
    Great build. Lots of good ideas and info here. Looking to start on my '26 roadster soon so am definitely following this.
  13. AGELE55
    AGELE55
    Ok...now you’re making me feel bad for not getting enough done in my stable. Awesome build and impressive workmanship.
  14. Really nice work. Given that these bodies don’t weigh much, what do you think top end will be with the banger?
  15. Tall t 26
    Tall t 26
    Awesome project.
    Metal work looks great!!
    Bringing her back to life only better!!!! Keep the pics rolling.
  16. Nice job on bun replacement panel. Where did you get your patch panel?
    Really like seeing the steps to hammer forge your dash.
  17. joep4567
    joep4567
    I just picked up a 26 turtle deck roadster body so I'm really interested in seeing what you've got going here. IMG_5200.JPG
    Squablow, Tim, guitarguy and 6 others like this.
  18. rusty valley
    rusty valley
    that body looks pretty good, lets see some more of it
    joep4567 and loudbang like this.
  19. rusty rocket
    rusty rocket
    Really digging this build. you have done some really kool ****!
    I’ll post my T roadster build so I can be part of the crowd. I’m running a lengthened T ch***is that will be boxed for strength. Drive train will be 276 flatly, T5 and a bronco 9”. 000DFB4A-18FB-46FA-AD13-7CACE7134548.jpeg F5499216-9732-472A-8263-A55C37B3FEBB.jpeg
  20. Joe Coughlin
    Joe Coughlin
    It’s been a long time since I posted anything on here so I just thought I’d give an update. The car has been on the road for a couple of years now. I’ve been driving and enjoying it. It’s quite a fun car with the model A engine in it, but I have an 8BA from a 49 F1 that I’m about to start swapping into it in the next month or two. I’ll have to go through my photos and post some more build pics from the original build and post some from the V8 swap as well
  21. MMM1693
    MMM1693
    Nice work! Stick to your game plan and carry on
    sko_ford likes this.
  22. Joe Coughlin
    Joe Coughlin
    Getting the Model T ready to pull the motor and start the V8 swap. I’m using the kit from Millworks so I can keep the mechanical brakes for now. Eventually it will get the juice brakes and a 39 rear axle. I have a 32 K member for the car so I need to find some 32 pedals for it
    Squablow, Jeff34, Outback and 5 others like this.
  23. Joe Coughlin
    Joe Coughlin
    Started getting the car ready for the F1 steering box using the flanges from LG Speed and Kustom. I’m going get the V8 in before I finish weld it. It will take a lot of fitting to get the pedal right around the box
    IMG_7540.jpeg Also got the motor out of the model T. Getting the Millworks AV8 kit ready to install the V8
  24. Rob28
    Rob28
    from Calgary AB
    That’s a good milestone getting the banger out. What’s your transmission plan?
    Joe Coughlin and Outback like this.
  25. Joe Coughlin
    Joe Coughlin
    I’ve got a 49 F1 trans converted to closed driveline to go in
    Tim, Squablow, Outback and 1 other person like this.
  26. Joe Coughlin
    Joe Coughlin
    First test fit for the V8
    simplestone, Squablow, Jeff34 and 3 others like this.
  27. ZerroHalfcup
    ZerroHalfcup
    That is really looking good with that flathead in there, I'm loving the progress of this
  28. Rynothealbino
    Rynothealbino
    What process are you using to form the floor beads? Looks like very nice crisp corners where the bead ends.
  29. ChuckleHead_Al
    ChuckleHead_Al
    Are you going to upgrade your brakes, rearend etc?
  30. Squablow
    Squablow
    Looks great! You probably already know, but you can put the earlier, center water neck heads on this engine to give it a bit earlier look.
