Projects I'm 18 and building my first flathead 59AB+merc crank for my chopped 34 4 door sedan
Discussion in 'Traditional Hot Rods' started by Jesse Borba, Nov 20, 2020.
  1. Ziggster
    Ziggster
    Just found this thread. Glad to see the next generation take an interest in traditional hot rods. I picked up my C59A as well for $100 back in 2018. I was very lucky as it was already in pieces.
    Jesse Borba likes this.
  2. Jesse Borba
    Jesse Borba
    Thanks for the advice!
    Sent from my SM-J727V using The H.A.M.B. mobile app
  3. Jesse Borba
    Jesse Borba
    Thank you
  4. Jesse Borba
    Jesse Borba
    Ok I'll look into it!
  5. Kiwi 4d
    Kiwi 4d
    @Jesse Borba , you are seeking the right advise. I have a C59 flat motor that had historical significance down under unfortunately some one with no solid knowledge got it and attempted to pull it down . lets get a hole saw to cut around the vintage Edelbrock head studs ,yikes now we have 3/4” holes where the studs were. Ok now lets drill out the pistons , oops lets drill through the bore while we are at it . These sort of folk should not be allowed near power tools .
    Ziggster and chryslerfan55 like this.
  6. Jesse Borba
    Jesse Borba
    Yikes, I'm asking questions to avoid making an *** out of myself like whoever did that.
  7. lowrd
    lowrd
    Just another welcome and wish you the best. There's a ton of info here on flatheads, read carefully!
  8. Budget36
    Budget36
    What I do on a flat surface with a bit of the bolt/stud showing...
    Use a grinder with a cup brush and get the nub shiny
    Take a piece of flat bar , drill a hole near the end just undersize of the bolt/stud and tap it over it
    Lay the weld in the center of the hole and work it outwards
    Go away and do something for a few hours till everything is cooled down to air temp, then start wiggling the flat bar and get the bolt/stud moving. If it starts to bind up again, stop. Use your torch to heat the weld cherry red and work outwards again to the flat bar
    Let it sit and cool again and go back to wiggling it free
    I hate using nuts, because I’m a tight ***, I can clean a piece of rusty flat bar, inside the drilled hole will be shiny anyways
  9. Jesse Borba
    Jesse Borba
    I really like that idea I'll bring it up to my dad
    chryslerfan55 and warhorseracing like this.
  10. wheeldog57
    wheeldog57
    Great to see you are making steady progress, keep it up bro
  11. Jarek Thompson
    Jarek Thompson
    Hey man I’m over in Napa and am looking for some Evans heads to match my intake
    chryslerfan55 and Jesse Borba like this.
  12. Jesse Borba
    Jesse Borba
    Cool! You're right down the road I think I'm going to hold on to them for now but if I change my mind you'll be the first person I contact
  13. vilanar
    vilanar
    from Finland
    Weld a large washer on the end of that broken bolt/stud and then weld nut on that washer , let it cool
    and it will come out easily. Washer is much easier to weld on that bolt remaining so that it will hold than nut.... just my 2 cents.
    Good luck...
    getow, Hnstray and Jesse Borba like this.
  14. Jesse Borba
    Jesse Borba
    Thank you for the advice!
  15. Fortunateson
    Fortunateson
    Wow, Baron Engineering joined the HAMB yesterday and he has parts you need! How "lucky" is that?
  16. Pinstriper40
    Pinstriper40
    Hey kid, do you have a parts list yet? I'm sure you might get a couple donations if you just had a list of the things your flatty/34 need on the thread....
    Just an idea 'cause I like helping fledgeling motorheads out. I'm 33, but it doesn't seem that long ago I was putting my first Flathead in my '40 sedan.
  17. Jesse Borba
    Jesse Borba
    I'm not exactly sure yet with the 34 because I haven't really dug into it.
    But with the Flathead I definitely will need water pumps, a distributor, and definitely some internal stuff but I don't want to go around asking for handouts.
    chryslerfan55 and brEad like this.
  18. Jesse Borba
    Jesse Borba
    Today I've been doing little stuff with the motor I took out the oil fitting in the side of the block, took a broken off oil pan bolt out of the block and took off the main caps just to check out the crank. 1610065180438.jpeg 1610065196304.jpeg 1610065210948.jpeg
  19. Pinstriper40
    Pinstriper40
    If nothing else, I can "give" you some parts at a really good discount. I've had enough people help me out over the years, might as well build up some good karma and offer some help!
    Petejoe, Baumi, Bluefox and 6 others like this.
  20. Jesse Borba
    Jesse Borba
    Ok, I'm always thankful for the help, what do you have available?
  21. getow
    getow
    Just ran accross this thread. And glad i did. Im cheering for ya. Good to see another youngster getting their hands dirty. Keep up da good work.
    51504bat and Jesse Borba like this.
  22. flatheadnut0
    flatheadnut0
    It's good to see a youngster liking flatheads. I hope you have a lot of fun along with some of the frustration you will encounter. Stay with it and you'll be proud of what you have done and will be one of the few that still work on these wonderful inventions. Good luck!
  23. NoSurf
    NoSurf
    Are you driving this thing yet?
  24. Keither
    Keither
    Just saw this thread myself. The good news for you is that YOU ARE LIVING IN FLATHEAD COUNTRY !! I am in Santa Rosa and have been fooling around with flatheads for years and there are a lot of us doing it. Come over to Coddingtown tomorrow (Sunday) morning and there is a cars and coffee. I will have a black 32 roadster with halibrand wheels on it and would love to talk to you. (The flatty roadster in the avatar is getting a break tomorrow). My name is Keith.
    chryslerfan55, Jeff34 and Jesse Borba like this.
  25. Jesse Borba
    Jesse Borba
    What time should I be there?
  26. roseville carl
    roseville carl
    sent ya a PM...........Carl
    loudbang and Jesse Borba like this.
  27. Don't mix up the main caps , put them back the way you took them off.
  28. F-ONE
    F-ONE
    from Alabama
  29. Jeff34
    Jeff34
    It's not often that I look to see where people are from on this site, since most are NOT where I am. I happened to be at the Coddingtown C&C last rainy Sunday. Good turnout for a ****py day. I thought it was awesome to see the two roadsters at the meet... My drive was wet enough. Can't imagine the drive up without a top!!!
  30. lndseaair
    lndseaair
    Have a 34 pickup with a 283, wish it was a flathead.
