Features Coolvairs Lets See Them
Discussion in 'The Hokey Ass Message Board' started by dons t, Jun 19, 2007.
  1. 61SuperMonza
    61SuperMonza
    I inspect a Corvair just as I would any of the era. The big differance is the powerpack.
    Over the years many Corvairs have been "fixed up". Unfortunately many of the motors are now frankenmotors. Parts used from many different years and HP levels.
    You will want to know witch engine/trans combo the car has and research the serial #s for the block, heads, carbs, dist and vac advance or press retard if it a turbo motor. These parts perform best when installed in there intended engine.
    For a prospective buyer these serial # are available on Clark's Corvair website.
    I would look for a car with the 164 displacement. HP ratings at this displacement were 95, 110, 140, turbo 150, 180. I prefer a 4sp. Although I have had 2 PG cars. The 4sp just allows you to keep the motor in its sweet spot.
    Last but not least, you want to check the oil cooler, what type is it. There were 4 different oil coolers installed at the factory. 4 row folded fin, 3, 8, 12 fin. The 12 plate and the folded fin are the best at shedding heat. The cooler should be checked that the fins/plates are clean and free of debris.
    All the tins should be installed with seals. The damper doors should be closed when the engine is cool. If a door is open when the engine is cool the thermostat bellows on that side has failed.
    With what has already been mentioned that about covers it.
  2. quick85
    quick85
    Very useful information from you fellows and it's truly appreciated. I've rarely seen,
    let alone been in, any Corvairs over the last forty years or so but, for some unknown
    reason have become interested in them again. Thanks.
    Phoenix24, bchctybob and loudbang like this.
  3. 61SuperMonza
    61SuperMonza
    Here's a cool Vair. My dads 64 Goldwood yellow Spyder convertible with Hollywood wheels. 20190601_192124.jpg
  4. quick85
    quick85
    I just wanted a closer look.
  5. Ice man
    Ice man
    I was a small time HVAC guy in the Burg, (COLD WINTERS) and I did mostly service calls. I had 2 Corvans, loved them, one was a3 sp, and the last one was a 4 sp. Lost's of NO heat calls, at all hrs of the day or night. Those vans were always ready to go, many times going where 4x4s dreaded going. I remember the fuel line froze. I unrolled some 3/8 copper tubing, stuck one end in the gas tank, duct taped the tubing down the side of the van, and hooked up the other end to the fuel pump through the engine door. Drove home in style. They were my choice of work vans for yrs. Even kept a spare engine/trans in the shop and could change it out in Twenty min, with my sons help, and ready to go. Love the Vairs ,Iceman
  6. moparboy440
    moparboy440
    from Finland
    Gene Winfield's Corvair powered "Reactor":
  7. 61SuperMonza
    61SuperMonza
    That grill and single head light treatment is bothering me.Looks like a Mustang. I friggin hate Mustangs.
  8. madmike8
    madmike8
    from Tennessee
    I like Vairs... Hopefully there's one in my future...
  9. moparboy440
    moparboy440
    from Finland
  10. Speedblur101
    Speedblur101
    I had several. A 65 monza with a Corsa dash and 140/4 speed was my favorite. There are a million things that you can do to a Corvair and a lot of them really are improvements. Ran a center mounted Holley 4bbl some. Also 2 Holly Webbers. Moved the Battery into the trunk to help weight balance. Had quick steering arms and front disk brakes. The only time I ever had fanbelt trouble was when the alternator bearings went bad. You also need to use good belts. Most people who had belt trouble were over tightening them to start with out of paranoia. Using viton pushrod tube seals instead of the cheap ones that come in the factory gasket sets is a must! Had a lot of fun with mine.
  11. Weird, never saw that one...
  12. 61SuperMonza
    61SuperMonza
  13. 61SuperMonza
    61SuperMonza
    loudbang and anthony myrick like this.
  14. Possibly photoshopped
    Looks cool regardless
  15. 61SuperMonza
    61SuperMonza
    I was wondering the same thing.
    anthony myrick and loudbang like this.
  16. 61SuperMonza
    61SuperMonza
    Okay guys,
    I've changed my mind on the Photoshop thing. The blue car is legit. It has the proper 4 lug wheels and is probably bagged.
    The red car, witch looks great is more likely photoshopped. First the 5 lug wheels. The spindles could have been modded. If you look at the front tires you will se if that car it a bump with the wheel turned that fender would be fouled and a tire toasted.
    All that said they both have the look.
  17. Nostrebor
    Nostrebor
    Bagged early models have "the look". I really dig 'em.
    Guthrie1068 and anthony myrick like this.
  18. guthriesmith
    guthriesmith
    Speaking of cool early models...I really like this one. I am not sure what to think about the skirts, but like everything else. I know nothing about it other than found the pic while researching other stuff I was trying to learn about my 63...
  19. moparboy440
    moparboy440
    from Finland
  20. quick85
    quick85
    The skirts are a definite no-go. My opinion. Then again, so are the spotlights.
  21. 61SuperMonza
    61SuperMonza
    Well this is funny guys, the blue car with the chrome slots is the same one with the skirts and spots. Not sure of the time line but the slots without the skirts is more to my taste. Just needs to ditch the spots. The goofy aftermarket antenna is in both pics as well.
    bchctybob, loudbang and quick85 like this.
  22. 61SuperMonza
    61SuperMonza
    We have seen some cool slammed vairs in the last few posts and I think they look great. I totally dig Corvairs and the EM are my favorite. That being said I am not a fan of bagged setups in a vair.
    Bagging a Corvair will require a fair amount of fab and weight. If you just want to cruise the go for it. That's not me.
    If I was to make a major mod to the suspension I would go with a coil over setup. Gurthrie1068 has a great example.
    For now I will deal with my cut coils. 2 in the front 1 in the rear.
    bchctybob, Guthrie1068 and loudbang like this.
  23. quick85
    quick85
    A 1973 photo. The Corvair belonged to a friend but I'm not sure on the year.
    Went from Illinois to Lake Geneva, Wisconsin and then out to South Carolina.
    Those are not rally wheels but plain 14x7 steelies.
  24. SAM3 Customs
    SAM3 Customs
    from Michigan
    The Don Eichstaedt 1965 Corvair Corsa racecar[​IMG]
    Sent from my SM-G892A using Tapatalk
  25. SAM3 Customs
    SAM3 Customs
    from Michigan
  26. moparboy440
    moparboy440
    from Finland
