Projects BACK TO MY ROOTS-261 CHEVROLET 6 Powered Model A Stock Car
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, May 22, 2015.
  1. wheeldog57
    wheeldog57
    Looking good Robert. I picked up some door parts in Maine for you the other day. We will have to plan for a meet up.
    Robert J. Palmer and loudbang like this.
  2. Thanks, I will give you a call.
  3. So long frame horns
    upload_2020-7-11_17-44-10.png upload_2020-7-11_17-45-40.png upload_2020-7-11_17-47-16.png
    The new front crossmember
    I am making a parts run tomorrow
  4. tb33anda3rd
    tb33anda3rd
    those frame horns are a sellable item.
  5. Yes, they will be at Fitchburg in the spring...
    ....If this Covid-19 B.S. is over by then!
    patmanta, loudbang and tb33anda3rd like this.
  6. The vintage racecar is one step closer, the backing plates are drilled!
    The lay out was dad's idea simple, neat and clean!
    After drilling the 60th hole I was thinking "I wonder what Stewart Friesen is doing right now?" Dad drilled some too.
    upload_2020-10-6_19-34-49.png upload_2020-10-6_19-35-28.png upload_2020-10-6_19-36-6.png upload_2020-10-6_19-36-37.png upload_2020-10-6_19-37-14.png upload_2020-10-6_19-37-44.png upload_2020-10-6_19-38-9.png upload_2020-10-6_19-38-38.png upload_2020-10-6_19-39-9.png upload_2020-10-6_19-40-9.png upload_2020-10-6_19-40-36.png upload_2020-10-6_19-41-6.png upload_2020-10-6_19-41-46.png
    ct1932ford, adam401, patmanta and 2 others like this.
  7. The best part is it didn't interfere with the Ford Script!
    ct1932ford, Baumi, adam401 and 4 others like this.
  8. A vintage racecar Christmas
    upload_2020-12-25_11-58-46.png upload_2020-12-25_11-59-51.png upload_2020-12-25_12-0-44.png upload_2020-12-25_12-2-10.png upload_2020-12-25_12-3-51.png
    ct1932ford, tractorguy, Baumi and 8 others like this.
  9. tb33anda3rd
    tb33anda3rd
    ...and gas monkey pajamas...
    tractorguy, Baumi, alanp561 and 3 others like this.
  10. seabeecmc
    seabeecmc
  11. I got out to the garage good and early this morning to get a good full day's worth of ch***is work in.
    However an unexpected (but welcomed) visitor brought me a box full of vintage race flyers, photos and s****books.
    This led to a two hour B.S. session/history lesson.
    I did get the frame leveled side to side/front to back, squared, and the front crossmember removed, and a test fit of the new crossmember.
    My Kirkey vintage series race seat arrived as well.
    IMG_0810.JPG IMG_0822.JPG IMG_0824.JPG IMG_0825.JPG IMG_0827.JPG IMG_0828.JPG IMG_0811.JPG IMG_0806.JPG IMG_0809.JPG
  12. Took a road trip yesterday to study to cage of an old Olson Ch***is (Now TEO). Come spring I have to dig it out and bring it home.
    upload_2021-1-16_6-28-0.png upload_2021-1-16_6-31-11.png upload_2021-1-16_6-34-8.png upload_2021-1-16_6-35-53.png upload_2021-1-16_6-37-57.png upload_2021-1-16_6-39-31.png
    The coolest part was the DPS (Don's Porting Service) decal on the ch***is.
    Don Green was the go to high performance machine shop/engine builder in this area.
    They did work for the top oval track racers as well as Jack and Shirley Muldowney.
    Don's brother George and nephew Tom did the machine work and porting on my engine.
    tractorguy, AHotRod, adam401 and 8 others like this.
  13. Figured my engine/transmission mounts, radiator cage placement, ride height, front axle rear frame kick/stretch for Chrysler leaves.
    This is no where near ride height, it will be much lower.
    I put in a large Speedway order which should be here Thursday or Friday.
    2"x2" placement represent the cage placement.
  14. More purple boxes full of parts!
    Rear springs-
    upload_2021-1-20_18-51-58.png upload_2021-1-20_18-56-8.png upload_2021-1-20_18-57-30.png
    Rear spring sliders
    upload_2021-1-20_18-59-12.png upload_2021-1-20_19-0-28.png upload_2021-1-20_19-2-12.png
    adam401, patmanta, LAROKE and 2 others like this.
  15. wheeldog57
    wheeldog57
    Looking good Robert. Great to see you back on it.
  16. Sometimes sacrifices must be when building a vintage racecar.
    upload_2021-1-24_16-25-21.png upload_2021-1-24_16-31-49.png upload_2021-1-24_16-27-25.png upload_2021-1-24_16-30-36.png upload_2021-1-24_16-33-34.png upload_2021-1-24_16-36-39.png
    I was after the rear rails to kick/stretch the frame for Chrysler leaves.
    This is roughly what I am planning with more kick
    The work that someone had done on the front half, it wasn't that big a sacrifice.
    Just because you have access to a welder doesn't mean you should be allowed to use it!
    This is modern work, the the motor mounts and and wishbone mounts are out of the current Speedway catalog. upload_2021-1-24_16-45-13.png upload_2021-1-24_16-46-7.png upload_2021-1-24_16-47-0.png upload_2021-1-24_16-47-58.png
    adam401, loudbang, Gofannon and 2 others like this.
  17. I didn't get as much done as I wanted, I had to repair my snow blower for the 9"-12" of snow coming tomorrow.
    I did remove the middle crossmember and set the engine in the ch***is it's not in the final placement
    upload_2021-1-31_18-38-58.png upload_2021-1-31_18-42-55.png upload_2021-1-31_18-43-25.png
  19. AHotRod
    AHotRod
  20. Cosmo49
    Cosmo49
    Robert, what carb and how many cfm for your Clifford Intake?
  21. 500 CFM Rochester 2BBl modified by JET performance for oval track racing.
    It runs Holley jets, worked power valves, etc... it was a very common carburetor in street stock, what is called north east ProStock in the and Sportsman, until these cl***es required the use of the GM 602/604 create engine.
    6-bangertim and Cosmo49 like this.
  22. I was only able to spend a couple hours in the garage today, I cleaned the frame for welding, dad and I figured the frame kick pieces.
    I also started the engine mount
    upload_2021-2-7_17-16-57.png upload_2021-2-7_17-19-30.png upload_2021-2-7_17-20-53.png upload_2021-2-7_17-22-18.png upload_2021-2-7_17-24-12.png
  23. Tim Walker
    Tim Walker
    I run a 1954 261 in my first series 55 3100 pickup with that same exhaust and a Eddy Edmond's intake with two gl*** bowl Holleys and Fenton ratioed rockers. After crossing the nation twice and up and down it many times. I can only say it's the best thing I ever built. The factory three and over makes highway driving at 70plus MPH easy and fun.
  24. I started to prefab my frame kick and stretch
    Frame kicks
    upload_2021-2-11_17-21-22.png upload_2021-2-11_17-22-47.png upload_2021-2-11_17-28-18.png
  25. I ended up with another short day today, I tacked my kick/stretch pieces, and test fit them to the frame. I am going to take them back to work to be sandblasted, before I weld them to the frame.
    upload_2021-2-14_18-7-52.png upload_2021-2-14_18-9-26.png upload_2021-2-14_18-11-3.png upload_2021-2-14_18-12-5.png
  26. I had a good weekend, managed to get a fair amount done.
    I got the rear frame sections completely welded.
    Dad had an idea to add a piece of 1/4" plate for extra weld kick to frame.
    upload_2021-2-21_16-43-39.png upload_2021-2-21_16-44-48.png upload_2021-2-21_16-47-19.png upload_2021-2-21_16-49-35.png upload_2021-2-21_16-50-59.png upload_2021-2-21_16-53-4.png upload_2021-2-21_16-54-7.png upload_2021-2-21_16-58-34.png
    Our cl*** rules say "no tubing rails must have stock rails" I didn't see anything about the rails having to be from the same frame.
    I also got my spring pads built, 3" Channel- upload_2021-2-21_17-3-44.png upload_2021-2-21_17-5-51.png upload_2021-2-21_17-7-38.png
    As I was doing that dad was jigging up and laying out the spring slider mounts, I dilled and cut them.
    upload_2021-2-21_17-30-54.png upload_2021-2-21_17-32-31.png upload_2021-2-21_17-33-53.png upload_2021-2-21_17-35-36.png upload_2021-2-21_17-37-7.png
    I was a bit of a task master on dad on Saturday, but only because mom needed to prepare his surprise 72nd birthday diner/party
  27. tb33anda3rd
    tb33anda3rd
    happy birthday DAD
    loudbang and Robert J. Palmer like this.
  28. Just saw this tonight.
    HAPPY BIRTHDAY Willard!!!!!!!
    Regards and all the best !!!!!
    From the Martinos
  29. I lost all of last weekend to a wicked cold, so I tried to may up for it this weekend.
    I jigged up the rear kick tacked it up double checked it's placement, and cut and tacked in 1 3/4 .095 wall D.O.M. (Roll Cage material) crossmember.
    upload_2021-3-7_18-10-21.png upload_2021-3-7_18-14-9.png upload_2021-3-7_18-16-33.png upload_2021-3-7_18-19-10.png upload_2021-3-7_18-20-45.png upload_2021-3-7_18-23-1.png
    I removed the rear crossmember and welded in some 2" square tube (dad's idea) for strength under the frame kick.
    upload_2021-3-7_18-25-8.png upload_2021-3-7_18-26-36.png upload_2021-3-7_18-28-26.png upload_2021-3-7_18-29-57.png upload_2021-3-7_18-31-25.png
    I also got the kick braced and tacked to the rails
    upload_2021-3-7_18-33-1.png upload_2021-3-7_18-35-35.png upload_2021-3-7_18-37-28.png upload_2021-3-7_18-38-52.png upload_2021-3-7_18-40-26.png
    Next up rear spring mounts and main hoop for the cage
  30. I am going to run tube from the D.O.M. to the 2" sq. tube in the frame and build the rear hoop off the frame kick with an X to the D.O.M. crossmember in the frame
