Projects Poly begets a Hemi begets a Model A
Discussion in 'Traditional Hot Rods' started by wstory, May 21, 2020.
  1. X38
    X38
    A cast housing full of gears, manually operated is different from a computer controlled something. Anyway, the place has rules, like 'em or lump 'em.
  2. Beanscoot
    Beanscoot
    Well the EFI went, but look at the bright side, the serpentine belt drive is allowed to stay.
    Maicobreako, kidcampbell71 and X38 like this.
  3. AmishMike
    AmishMike
    Concerned about your fuel distribution with carb on this blower that I believe was originally designed for EFI under the blower at each port. Doesn’t this blower **** in the back then screw forward & discharge at the front? Will numbers 7 & 8 get their fair share of fuel? Just questions
  4. wstory
    wstory
    Well boys, learned my lesson,...gotta read the directions! I've washed my mouth out with E85 and will no longer mention Ee Ph Eye :eek: I will continue to explore and learn like a Tradition Rube but without arbitrary limits to the search to creatively build a cool car,....while carefully watching my mouth.
    Getting back to the project, I've determined that the snout will need to be extended 2.75". Do y'all think using the 4 Banger water pump shaft would be traditional,...enough. I'm also pretty must convinced that a single Weber DCOE "carburetor" will not work. Gotta figger how to dump enough fuel and air into the blower to run a 270 inch engine.
  5. 73RR
    73RR
    Thinking out loud here...
    Rather than depending on the oem cast 'snorkel', I'm thinking of a fabricated part that would mount the DCOE on each side about mid point of the case, maybe pointing forward at 45 deg or so to keep air flow kinda straight.
    A fab part might actually end up lighter than the oem part.
    Your belt alignment conundrum still puzzles me a wee bit. I looked back at the sheave alignment pics and cannot tell if an idler with double sheaves would even be possible given everything below, ie. t-stat manifold.o_O
    Is there enough space to use such a piece? It would offer a place to adjust blower rpm ....;)
  6. warhorseracing
    warhorseracing
    from cameron wv
    With your fabrication skills why could you not come off the blower where you have the two carbs pictured? Replace.JPG
    Think of a Rams Horn sheet metal fabricated intake with the Webbers as originally intentioned. I can't even draw what I am envisioning but you Sir could build it. The Webbers could face either straight forward or off to either side while dropping them down to help with hood clearance.
  7. Atwater Mike
    Atwater Mike
    ^^^^^Right on... side draft Webers or DeLortos. Used both, very 'tunable'...and parts availability second to none. Manifolding only prob? Not for Mr. Bill... Oh, Nooooooo!!!
    Desoto291Hemi, loudbang and fauj like this.
  8. Chalkie
    Chalkie
    from England
    They used mechanical fuel injection, bit like an diesel set up.
    Great build I stumbled across this last night and have read it all keep up the good work.
    AmishMike and fauj like this.
  9. wstory
    wstory
    ****!!!! seems like it's always something.
    When turning the engine over awhile back there was a worrisome s****ping sound coming from the bell housing. I finally pulled the engine off the Model A engine stand to investigate and found the starter ring gear was contacting the bellhousing. About .030" nibbling with the die grinder fixated that. IMG_3186.JPG IMG_3189.JPG
    Then, since I had the rear of the engine available, decided to test fit the trans. **** again!!!! Input shaft of the trans was .060" too long for the combo of flywheel, clutch, T/O bearing and bellhousing. Same issue on my other car,...but I forgot.:eek:
    Soooo,..made a .125" spacer so's the trans/bellhousing will seat w/o loading the input shaft bearing. Also amortized the cost a little more of the POS Harbor Freight spindle sander
  10. TCTND
    TCTND
    Maybe move the blower forward enough to line up the belt and mount the carb/carbs/EFI behind it to fill the space and preserve a low hoodline. You might be able to tap into the rear of the blower housing where the rotors don't p***.
    regards,
    Phil
  11. 73RR
    73RR
    Bill, you have way too much free time....I'd just snip off the end of the shaft.;)
  12. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^ I have done that and wanted to say the same thing, less adapters/spacers!^^^^^^^^
  13. wstory
    wstory
    My first thought! But with careful scrutiny, (something I usually avoid) I determined that the shoulder where the spline begins was the point of interference at the T/O bearing, suggesting that the transition to the spline would need to be "turned back", therefore the spacer plate.
    Atwater Mike, loudbang and fauj like this.
  14. wstory
    wstory
    And re the blower chapter,....first iteration of the modifications got me about 80% of where I want to be. First, I'm not happy with the appearance of the extension and second, that piece is about 3/16" too long. The body of the blower can also be slide to the rear another 3/16" to get the belts to align on the pulleys and a more balanced appearance.
  15. Brand Apart
    Brand Apart
    from Roswell GA
    Interesting. Challenging build, curious You gonna grind the FORD logo off the blower?
  16. Guy Patterson
    Guy Patterson
    thw audi is the s5 V8 model or the Q5 model V6 with supercharged engine. The intake is on the back of the blower and would work quite well as a sidedraft
  17. Guy Patterson
    Guy Patterson
    Also don't grind of the Ford it looks neat
    warhorseracing likes this.
  18. 73RR
    73RR
    ...got a photo of those??
    fauj likes this.
  19. There appears to be one on the Bay. Not terribly attractive... but functional I suppose.
  20. 73RR
    73RR
    You are correct as to the 'looks'....:confused:
    loudbang, fauj and warhorseracing like this.
  21. Guy Patterson
    Guy Patterson
    looks and cost are a big issue from when I looked at them a few years p*** for a hemi build that I didn't do
  22. wstory
    wstory
    I feel like I owe an update. It's been way too long. Not only has this been "giving birth to an elephant",....have also felt a bit deflated and challenged by recent hiccups in the project.
    Got the manifold adapter plate resolved. Knocked the corners off with a router and wire brushed it to get a "cast" appearance.
    Holding the adapter to the manifold after the pulleys were aligned was a challenge as there was no access to the interface for pinning or tacking, with the blower in place. Soooo,....."wicked in" SuperGlue from the outside to hold the plate and manifold together,....and then I could remove the blower to access the area to tack the two pieces together. IMG_3211.JPG IMG_3227.JPG
    Finally got the pulleys aligned and the appearance of the extension resolved. Taking some comfort in how the whole ***embly has come together.
    Hooked up the starter last night to spin the engine and visualize how the serpentine belt tracked. Cool!!!!!!,....except that the freakin blower pulley wobbled :(-:eek:-:mad: So today I start takin things apart to find the offending component.
  23. rockable
    rockable
    Great work, Mr. Bill!
  24. warhorseracing
    warhorseracing
    from cameron wv
    Everything. The blower adaptor, front extension, water crossover, serpentine belt system, all look as if the factory did it that way. You Sir have a definite eye for the aesthetics and the know how to accomplish them. Wobble in the blower pulley is just a minor hiccup that you will overcome.
    loudbang, ottoman and fauj like this.
  25. Joel W
    Joel W
  26. Mitchell Rish
    Mitchell Rish
    from Houston MS
    That’s sharp looking.
    If the appearance of the extension bothers you /and it shouldn’t it looks great- add to or lengthen the rib/support fins to say a 1/4 inch of the back of the belt.
    Then finish wearing out your harbor freight sander and who’s gonna ever know.
    I personally like the way you did it but I am not usually in the majority. Cool build.
  27. brEad
    brEad
    That came out great! As already said, looks OEM.
  28. wstory
    wstory
    video attempt - couldn't figger it out :confused: That a no no?
  29. Dick Stevens
    Dick Stevens
    To post a video, you have to load in on youtube and post the link on here
  30. wstory
    wstory
    Got it! Thanks ****. Probably not gonna happen as YouTube stresses my patience and I am adequately challenge just tryin to get the belt system resolved.
