Technical quick change rear cover bearing removal
Discussion in 'Traditional Hot Rods' started by dirt car, Oct 13, 2020.
  1. dirt car
    dirt car
    from nebraska
    Anyone have a method of removing the rear cover bearings ? some time back while rebuilding a 201 halibrand I tried heat/chilling/reheating/ penetrant etc. with no results, ended up getting a new cover but would like to use the script cover at some point. Thanks, Ron
  2. saltflats
    saltflats
    from Missouri
    I put them in the oven and heat them up and they just fall out.
    Algoma56 and thintin like this.
  3. dirt car
    dirt car
    from nebraska
    Did try that some time back however I've read anything above 350 f may cause warping true or not ???
  4. saltflats
    saltflats
    from Missouri
    I want to say I heated them to 350 degrees, with the even heat in an oven shouldn't cause any problems.
  5. oldtom69
    oldtom69
    from grandin nd
    They tended to fall out when changing gears on a hot rear end-someone may have lock tighted them in--a little heat and a slide hammer made for removing seals may work
  6. Marty Strode
    Marty Strode
    I use a small toaster oven for this, at 300 degrees. If you block the cover up, face down, the bearings should fall out. If not, have a welder's glove handy, remove the part from the oven, an slap it down on a 4x4, and they should fall out. IMG_6544.JPG
  7. dirt car
    dirt car
    from nebraska
    Thanks, need to see how I'm able to grab on to the bearing to put some prying leverage on it, don't have it readily available to ponder it again...currently stepping through a 11 bolt Frankland rebuild with a similar situation & it happens to be the deep cover & perhaps even more challenging
  8. 28rpu
    28rpu
    If all else fails, cut the inner race out, remove the balls and cage, weld a bead around the inside of the outer race. Works every time.
  9. dirt car
    dirt car
    from nebraska
    Thanks Marty, I always enjoy your posts & I did early on exactly as you suggested even giving it a couple hammer raps, I'll need to give it another whirl for a longer bake. Might be in order to pick up a toaster oven at the 2nd hand store & stay clear of my wife's new oven.
    seb fontana and Mr48chev like this.
  10. dirt car
    dirt car
    from nebraska
  11. dirt car
    dirt car
    from nebraska
    Yeah, thought about breaking it out & tacking on as well
    HotRodWorks likes this.
  12. Prying can mess up the bores they rest in.
    tractorguy likes this.
  13. saltflats
    saltflats
    from Missouri
    I use an old gas oven that came in the ba*****t of the house I bought. You need to put the part in and let the oven get to 300 or so then remove your part. If you take it out to early it won't be to temp yet.
  14. Blake 27
    Blake 27
    I followed Winter's directions. Place the cover bearing side down, on spacers taller than the bearings, then gently heat
    the cover with a propane torch (for plumbing). The bearings will simply fall out.
    If you heat the entire cover and bearings in an oven, both will expand and defeat the purpose.
    stillrunners likes this.
  15. saltflats
    saltflats
    from Missouri
    Expansion rate is different between the two dissimilar metals.
    ottoman and chickenridgerods like this.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Usually the oven heat works just fine. But, I recently had two that just wouldn't budge. I limit the heat to 350*.
    I had a Snap-on blind hole bearing puller but not the proper collet. I borrowed one and then ordered my own which worked just fine.
    I can post pics and part numbers tomorrow.
  17. What Temperature Degree’s Settings do you Ser it @. & how long should it be in the Oven? Thanks Dereald Millsap
    H.A.M.B. BigDTexasKid (903) 952-1933.
    BigDTexasKid@gmail.com
  18. saltflats
    saltflats
    from Missouri
    I set the oven to 300* and let the plate get to 300*
  19. seabeecmc
    seabeecmc
    We've used a vintage K-D tappet puller to remove the bearing from the heated cover. Seldom need to use it. Ron
  20. flamedabone
    flamedabone
    I use my kerosene shop heater for all my quick change heating needs. I keep a super close eye on it with a pyrometer, but you are probably not "supposed" to do it that way.
    -Abone.
    saltflats likes this.
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The recommended way is in an oven for even heating of the casting. I also use 300 degrees. About half an hour.
    The kerosene heater will work and so will a grill. I have done it with a rosebud heater, but you have to be careful. Frankland had an instructional video, years ago, showing what I believe was a MAP gas torch, huge flame. Heated most of West Coast Florida, I'm sure.
    The main thing is to not heat the pinion nose bearing support quicker than the rest of the case. It will make a 'ping' sound you will never forget as it breaks.
    The magnesium is more sensitive to uneven or over heating than aluminum. DO NOT exceed 350 on a mag case!
