Technical Ever Heard of a "charging problem" that required pulling the engine?
Discussion in 'The Hokey Ass Message Board' started by South Dakota Six, Jan 9, 2021.
  1. So, I have experienced such a thing and I'll be happy to share it with you all but before I do that I thought I'd see if anyone may have a guess as to what I found. The car is my street/strip '56 Chevy, 292 6 cylinder that I was hoping to have ready for the last drag event at our local track. The week before the charging light came on and, I'm embarr***ed to say, it took be about 3 tries before I figured out what was going on. And, yes, the engine is out and at the machine shop hoping to be ready for this spring.
    seb fontana and loudbang like this.
  2. FrozenMerc
    FrozenMerc
    Sure, on a vintage snowmobile where the magneto is mounted to the crankshaft, behind the clutch or recoil. Often easier to just pull the motor. Automotive, can't say I have had the experience.
  3. Can't say that I've ever run into that, and interested to hear the story. Trying to figure out how that is possible. I did have to pull the engine to change the water pump on an OT '85 Buick Century with 3.0 V6, clearly indicating why engineers should stick to running trains and let mechanics design automobiles.
  4. FrozenMerc
    FrozenMerc
    Had the same issue with the water pump on an '88 Mercury Topaz. Engineers don't design cars for ease of service. They design them for ***embly, once, on the line and as cheaply and efficiently as possible. After that, you're on your own.
  5. Wanderlust
    Wanderlust
    Not to side track things but I can’t help myself, more than a few “engineers” need a thorough boot fn, things used to be , dare I say it engineered to be repaired by someone with modest talent and tools. Next came special tools, nowadays things are just meant to be replaced by a “ Tech”. Makes me so angry I can’t even think straight.
  6. dalesnyder
    dalesnyder
    Like an old wore out vw flat 4 with so much crankshaft thrust wear the alt belt wont stay on?
  7. Wanderlust
    Wanderlust
    Neighbor brought over his sled, newer machine , rope broke for the recoil. The coolant had to be drained, engine removed from the mounts to get to the bottom 2 bolts on the recoil housing, I ask you how fn long do they think a rope is going to last before it breaks?
    mad mikey, Sandgroper and loudbang like this.
  8. rudestude
    rudestude
    Wasted the time it took to find out nothing so far...not going to bother waiting for the rest of the story.
    Just to find out it was like the first part..a waist of time.
    Moving on.
    Sent from my SM-T387V using The H.A.M.B. mobile app
  9. brading
    brading
    Well the only thing I can think of is that the crankshaft pulley was slipping on the crankshaft. I am a patient man and I am happy wait for the answer.
  10. Charging light came on when the engine locked solid. No turn, no charge.
  11. indyjps
    indyjps
    Interested in the engine diagnosis, what'd ya find?
    Got a good engr story: Im a mech engr and spent a lot of time in operations and design. I had a past job to teach design for manufacturing to others. Im reviewing a large fabricated part with a guy, "tell me how it goes together" part 1,2, 3 etc. We get to part 4 and I ask how its going to be welded way up in that hole. Guy says: well the welder will just crawl up in that hole. ALL STOP. **** THAT. Ill be back tomorrow.
    By the way, redo your datums - they cant be on a bolt hole on the fifth piece of the ***embly.
    Sheetmetal origami, was another one on my favorites, "welding cost money, therefore Ill make 13 bends in 1 part", yeah theyll be based on no parallel surfaces and require laser etch layout or fixtures to locate the form lines, half the bends require dogleg tooling to reach. and the part weighs a 200 lbs, so it has to run on a press with a gantry crane.
    Real basic stuff like that is lost sometimes when people have no practical experience.
  12. AldeanFan
    AldeanFan
    Piston broke the alternator when it came through the block?
  13. Hnstray
    Hnstray
    from Quincy, IL
    The OP should have been back waaaaay before now!!!
  14. BJR
    BJR
    Is this thread like the old joke ...how do you keep a Polock in suspence? . . ......
  15. Sporty45
    Sporty45
    I love these threads! :rolleyes:
    Sandgroper likes this.
  16. winduptoy
    winduptoy
    Here, pull my finger....
    mad mikey, Sandgroper, Baumi and 2 others like this.
  17. 1ton
    1ton
    this is taking far to long, cmon with the answer already !
  19. Svenski
    Svenski
    I think that is the story the OP told his wife so he can make the motor have more "zip"!
  20. rusty1
    rusty1
    I'd like to hear the story and get more info/pics of yer 56 Chev,...hope to see it at Byron, Il. in the future.
  21. kevinrevin
    kevinrevin
    from East Texas
    It's been 15 hours waiting on @South Dakota Six to spill the beans. Did OldTimers kick in and he forgot he started this thread?
  22. SDhotrod
    SDhotrod
  23. Ron, did you type this post and go to bed?
    Sandgroper, loudbang and VANDENPLAS like this.
  24. AldeanFan
    AldeanFan
    I’m pretty sure my neighbour convinced his wife that the only way to fix a rear main seal leak in his 283 Chevy was to replace it with a 396 :0
  25. tb33anda3rd
    tb33anda3rd
    it must have something to do with the engines ability to spin the alternator. broken crank? balancer spinning? there must have been a related noise from either of those and a fan that wasn't spinning . if the water pump wasn't turning it would have gotten hot.
    what ever it is it better be good....
  26. junkyardjeff
    junkyardjeff
    Inquiring minds want to know.
    Sandgroper, VANDENPLAS and loudbang like this.
  27. abe lugo
    abe lugo
    Something like this?
  28. Wrench97
    Wrench97
    I've heard of a ot Bentley that you have to pull the motor and trans then separate the trans from the engine to R&R the starter which in inside the bell housing......................only 20+ hr job no biggie......
