Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. topher5150
    topher5150
    Spent most of the morning in the junkyard crawling on top of an old GM trying to yank out a power steering pump and cursing GM with every breath
    Sent from my moto z4 using The H.A.M.B. mobile app
    31hotrodguy, 41 coupe and Blues4U like this.
  2. lonejacklarry
    lonejacklarry
    I'm wondering how you came about this bourbon? Is it as good as the price indicates?
    And Happy Birthday!
  3. gimpyshotrods
    gimpyshotrods
    It is the best Bourbon I have ever had.
    I hold it for special occasions. For regular days, it is just regular Blanton's. I have all the lettered corks.
    My local distributor is happy to sell me the most expensive stuff, since the bars are all closed right now.
    Thanks!
  4. lonejacklarry
    lonejacklarry
    I was not aware that it was sold in the US yet. I'll keep an eye out. In the meantime, I've discovered Garrison Brothers in Hye, TX. and I like that a lot.
  5. Marty Strode
    Marty Strode
    For years I have struggled with storage of Tig welding rods, being they come in 36" cut lengths. I solved that problem today. IMG_6159.JPG IMG_6157.JPG IMG_6158.JPG
  6. gimpyshotrods
    gimpyshotrods
    Well, it is on my kitchen table.
  7. saltflats
    saltflats
    from Missouri
    Got the kit in the last carburetor, things go well tomorrow it should be driving and hope it's out of my hair. :)
  8. gimpyshotrods
    gimpyshotrods
    Today I replaced the Y-axis encoder head on my manual mill, to get the DRO running again.
    Then I proceed forward with preparing the mult-pattern hub for my wheel building jig.
    mad mikey, 61Cruiser and saltflats like this.
  9. rod1
    rod1
    Pictures ,Gimpy,Pictures..
    RICH B and bob b. like this.
  10. HotRod33
    HotRod33
    Started mocking up the rear end in the 34 pickup
  11. junkyardgenius
    junkyardgenius
    from Kernow
    I got to play with this weird material called wood, strange stuff. Can,t weld it can,t hammer it. At least it's starting to shape up a bit. 20210112_104831.jpg
  12. gimpyshotrods
    gimpyshotrods
    You need a WIG welder.
  13. mike bowling
    mike bowling
  14. olds vroom
    olds vroom
    [​IMG]pulled the engine and trans out . Time for an rebuild kit maybe more befor spring gets here.
  15. TrailerTrashToo
    TrailerTrashToo
    20210112 M41 in trunk.jpg Bought an overdrive transmission. Nice day for a 160 mile round trip.
  16. mopacltd
    mopacltd
    That picture looks like the rest area outside Casa Grande
  17. blowby
    blowby
    from Nicasio Ca
    Pulled mine in for winter repairs and maintenance. On the schedule: front seal, new tie rod ends, alignment, fluids change, cosmetic detail..
  18. mgtstumpy
    mgtstumpy
    Pulled the headers off my FE powered 64 Fairlane to swap in period correct ****tershield, new flywheel and clutch. What a PITA even on the hoist! Remove engine tube to access engine mounts bolts, remove oil filter and adaptor, remove starter, raise engine on driver size etc. Disconnect everything and remove exhaust, drop driveshaft, unbolt collectors and jiggle individual pipes (Bag of snakes) out one by one. The top 12 o'clock header bolts are easy unlike the lower 6 o'clock bolts. A size 10 foot in size 8 shoes. :D Not a lot of room at back of engine to access bolts and remove bellhousing. Bottle jack will hopefully allow engine to be lowered suffuciently at rear and finish task. Dropping the transmission crossmember and removing the T10 is the easy part. These are worse than the FE Tri-Ys in my old RHD OT 66 Fairlane and it had no room on right side with steering box next to starter. Off my soapbox!;)
  19. TrailerTrashToo
    TrailerTrashToo
    Love's truck stop, I-10, Exit 302. just west of Benson, AZ
    I needed a cup of coffee and a fat pill to re-charge me for the last 38 miles home.
    I was in the truck lot because of the setting sun (and the probability of being run over on the gas pump side).
    chryslerfan55, Lil32 and bob b. like this.
  20. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    IMG_3495.JPG IMG_3496.JPG Floor removal in my 34' is completed. Almost ready for the sandblasting. Last nice day for awhile so I'm taking my Model A for a drive in the country.
  21. eldiablooxidado
    eldiablooxidado
    I made made enough room in the garage to pull the A ch***is I just picked up inside and start mocking up the T Roadster body on it. Now I gotta order some steel and get this body patched up.
  22. jimmy six
    jimmy six
    It’s a Ford... as we all know who have them and expect no less when working on or up grading them...I’ve spent the last week under my 56 Victoria and whether it is a pain or not I’m pleased when I’m done..
  23. Caprice89
    Caprice89
    Working on a 58 Corvette; it needed new intake manifold and carburetor.
    The car has a custom ch***is. Front and rear independent suspension.
    I will try to take some pictures of the ch***is tomorrow.
    Still the original 58 engine.
    Since I was replacing the manifold, I couldn't mark the ignition properly. So I put some tape over the valve cover, indicating the position of the vacuum advance. IMG-20210113-WA0002.jpeg IMG_20210113_164354.jpeg IMG_20210113_143856.jpeg
    Sent from my online shouting device
  24. HOTRODPRIMER
    HOTRODPRIMER
    Sure you can hammer it but you have to use short pieces of metal (NAILS)
    Nails are usually made of steel but can also be made of stainless steel, iron, copper, aluminum, or bronze, I recommend the steel ones! :D HRP
  25. jimmy six
    jimmy six
    I would have turned the engine over until the rotor pointed the same. Then pull it out..
    chryslerfan55 and mad mikey like this.
  26. Lil32
    Lil32
    Mark
    do not give up
    we need to see it at coffee run
    31hotrodguy and mgtstumpy like this.
  27. jimmy six
    jimmy six
    Finished the plumbing on our dual quad Y-Block for a PCV system. Needed to modify the fitting on the valley cover to miss the rear of the manifold. Feeding to a center threaded plug between the carbs. Bought a 1/2” fuel line with multiple bends to make it easier. I have a roll of 1/2” aluminum tubing and a bender. 343CFCB2-A4A4-44E0-AACE-FBD2C8295722.jpeg 07912B4E-BF97-4E71-ADD9-0BD5D5B1F295.jpeg E3044133-F4D4-49B0-AA4E-8A65BCE5309E.jpeg 6C16A5FC-1D65-4BE6-9C80-01925E9B2955.jpeg
  28. There's not a lot of luggage space in T Modified so I bought a boot rack for a BMW Z4 and narrowed it to fit on the Fordson E27N tank. Made some new brackets for it on my parts bender and metal folder. Had to modify the folder to produce sharp bends. Before it did the bend on the right of the aluminium sheet, now it does the one on the left IMG_20210112_185016786.jpeg IMG_20210110_165650984.jpeg IMG_20210110_161947098.jpeg IMG-20210111-WA0007.jpeg IMG_20210110_151902453.jpeg
    Sent from my moto g(8) power using The H.A.M.B. mobile app
  29. jimmy six
    jimmy six
    Runs great with minor carb adjustments. 1-1/2” of vacuum at the dipstick hole with oil fill sealed up. Idling in gear with AC on will hold a blue shop towel corner on the oil fill tube and the feed to the inside of the air cleaner. 72EDE9C6-CC5F-491C-8D7A-DE9836022FCF.jpeg E87DB80F-9080-4E74-8FC4-7223C2C4FB19.jpeg
  30. RICH B
    RICH B
    Started with a little fender t******* to fit a grille in my '47.
