Technical Any Cam experts
Discussion in 'The Hokey Ass Message Board' started by 9sectruck, Jan 12, 2021.
  1. 9sectruck
    9sectruck
    Got this old small block chevy roller cam and trying to find out the manufacturer or the specs. From the engraving and measuring the lobes I've confirmed it's. 410" lobe lift but don't have an old block to check duration or LSA. I think the letters CT point to the manufacturer but have so far come up blank on it. Any help anyone? DSC_2498.jpeg
    Sent from my F3311 using The H.A.M.B. mobile app
  2. sdluck
    sdluck
    Once again it would be easier if you put where in the world are located
    Sent from my SM-J737T using The H.A.M.B. mobile app
  3. 9sectruck
    9sectruck
    England, but can't see what difference it makes? It's for a Chevy motor.
    porknbeaner, X38 and Flathead Dave like this.
  4. Bob Lowry
    Bob Lowry
    Perhaps a Circle Track grind...?
  5. If it was a custom grind about all you can do is measure it...
    You asked this question a couple of years ago too.
    9sectruck and mad mikey like this.
  6. Budget36
    Budget36
    .410 on the cam would be over .600 with 1.5 rockers. Anyways, wasn’t, isn’t there a company called Cam Technique? Google ****s on my phone so can’t confirm or not
  7. 9sectruck
    9sectruck
    Done that, still looking for answers, maybe an old catalog.
  8. 9sectruck
    9sectruck
    Hadn't thought of that. Thanks for some positive input.
  9. Cam experts? We all claim to be. :D :D :D
    This is pure conjecture but I would guess that given that it is hand lettered and not stamped that it is most likely a regrind. Nothing wrong with that.
    I would ***ume that you also have no access to a lathe. I can probably come up with a block but shipping is gonna be a bear. LOL
    pitman and 9sectruck like this.
  10. AccurateMike
    AccurateMike
    Google the numbers. Lots of flaky sites. It does look like that grind was used on Harley cams too. 90% of the hits are yours though. Mike
    9sectruck likes this.
  11. sdluck
    sdluck
    The reason I asked is to send you to someone local,most cam companies offer a service where if they 2 lobes Intake and exhaust they can cam doctor the cam for you.
  12. 9sectruck
    9sectruck
    A free block.....I'll be round later [emoji16] just done a comparison and some meauring with another cam I have and it appears this has a small base circle which points to either a regrind or for a stroker motor I think. Didn't know you could check lsa or duration on a lathe...tell me more.
    Sent from my SM-T550 using The H.A.M.B. mobile app
  13. 9sectruck
    9sectruck
    Fit a degree wheel to the cam and divide by two... Hadn't thought of that.
  14. HotRod33
    HotRod33
    What does it matter where he's from when all he is asking is about a camshaft?.?
  15. SS Pete
    SS Pete
    HI,some info on Cam Techniques ****ord CT. then FLA. David Generous. Very Smart guy. Was engineer at Crane, told me he wanted to be close to home. very successful,small shop, clean , very helpful. . his gig was custom cams. he was into fixing the cam that didn't work. very big on 1600-2300 pinto motors for racing. I installed many of his cams so i recognized the etch.. i still have one in my chevelle, from 1982. he moved to fla. p***ed away 2018.
    pprather and Unique Rustorations like this.
  16. sdluck
    sdluck
    Did you see my reply you can take it to somebody and read the cam
  17. dreracecar
    dreracecar
    from so-cal
    Isky still hand engraves all his cams
    pitman and Blues4U like this.
  18. sdluck
    sdluck
    If you find someone with a cam doctor they can read the camshaft, if it was a custom grind Cam that usually in grave the numbers in the end
  19. Hire a machinist.
    The cam chucks up in a lathe and you turn it and measure. Just like you would in an engine block with a degree wheel. Only more accurate.
    @dreracecar I never would guessed that. I have not even had an Isky in my possession in 30 or so years. This is not a dis to the company or Mr Iskenderian but it seems backward for a modern manufacturer to do that. It shows a great deal of pride in product.
    Tickety Boo likes this.
  20. dreracecar
    dreracecar
    from so-cal
    Could you imagine the stamp size to spell "ISKENDERIAN"
  21. TRENDZ
    TRENDZ
    Most cams I’ve seen are etched.
    Those look like like lobe catalog #s to me. -8 is likely the lsa(108°)
    So, I would ***ume intake is cat# 410
    Exhaust is cat# 410L
    Lsa cut at 108°
    Most cam companies have lobe catalogs on line to search through. They “name” the lobes with a number/ letter . Usually based on lift. The catalog will give duration numbers based on the lobe name/ designation.
    As stated, most cam companies have a machine that will “read” the lobes and locations and print a spec card. If using it is the plan go this route.
    Are you concerned with the mechanical characteristics of the cam, or more concerned with providence? Don’t take that wrong... some people want to have parts with history or a story with markings as proof. Hope this info helps.
  22. Tickety Boo
    Tickety Boo
    from Wisconsin
    ISKY
  23. sdluck
    sdluck
    My old Isky catalog does not list them like that.
  24. Torana68
    Torana68
    from Australia
    nobody read this one?
    oh and cam experts are like boat experts......
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    You can put it in a couple of "V" blocks. Then attach a degree wheel. Probably need to be near the end of the table so the degree wheel can clear. Then get a magnetic base and a dial indicator.Hopefully a 1" travel indicator. That should let you check the cam accurately and quickly.
  26. I had to look it up. Some of us just have difficult last names. :D
  27. dreracecar
    dreracecar
    from so-cal
    Full script "Iskenderian" on every cam produced
    loudbang and Tickety Boo like this.
