Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. ct1932ford
    ct1932ford
    Yep! Again[emoji849]
    Stogy likes this.
  2. Stogy
    Stogy
    Easier...Easier said then done but TB could pull it off...;)
  3. tb33anda3rd
    tb33anda3rd
    yeah, and this gate is sooo beat up. there is nothing straight about it and is worn/pitted/ground thin.
    think, old celebrity with one too many face lifts. I am not a fan of the block letters and if I start cutting, I may just remove them. I can build a new gate faster and it would be perfect....but not perfect for this truck.
    I could cut just the letters out and raise them. I could cut a across the top just below the upper beam, take a section out and then add to the bottom by extending the flange I need to add anyway.
    I thought of a strip of the tree across the top to balance it out. I thought of painting a full tree with the roots starting at the bottom, the trunk running between the O and R and the canopy spreading out over the letters.
  4. ct1932ford
    ct1932ford
    Thee think too much! Anything you do will look good. Why? Because we are part of the same family.
  5. Peanut 1959
    Peanut 1959
    Any chance you could come up with one of these stamped sections to fill that space? 20210114_114940.jpeg
  6. ct1932ford
    ct1932ford
    Yes !
  7. tb33anda3rd
    tb33anda3rd
    Charlie stopped at work today and i showed him this thread, he said he wants that V8 logo on it and likes the way the ford is low.
  8. nunattax
    nunattax
    sorted so
    loudbang, Stogy and tb33anda3rd like this.
  9. ct1932ford
    ct1932ford
    What the hell does he know? It's only his truck.:rolleyes:
  10. tb33anda3rd
    tb33anda3rd
  11. tb33anda3rd
    tb33anda3rd
    then I hammered "off dolly" for a couple hours..... IMG_1587.JPG IMG_1588.JPG IMG_1589.JPG
  12. tb33anda3rd
    tb33anda3rd
    the back side, and the pile of tools. IMG_1590.JPG IMG_1591.JPG IMG_1592.JPG
  13. TFoch
    TFoch
    You're the man! Looks great Ted!
  14. Stogy
    Stogy
    :rolleyes:...There's a saying that works well for this pitter patter lets get atter...:D...by the way I'm to slow...but I'll share anyways...;)
  15. tb33anda3rd
    tb33anda3rd
    that is exactly what I pictured!!!!
    loudbang and Stogy like this.
  16. Stogy
    Stogy
    Thanks TB...What you hammered out fits the overall feel of the truck as well...;)
  17. The37Kid
    The37Kid
    Rope from the branch to the O tire swing would be overkill I guess.
    Bob
  18. Stogy
    Stogy
    :rolleyes:...Thats a good one...I was thinking a branch broken off crushing the 'R' might have been fitting too...​
  19. Stogy
    Stogy
    @tb33anda3rd the 40 ford pickup gate has a tube or tight roll at the bottom and three hole brackets on the aft Box corners for support...You could make it lift off as well...Put a pinned round bar in each end through the hinges you have..I made sides similar to your lighter ones...Looks good...One other thing I did do is move up and chamfer those 2 inward raised vertical bars to match the top...I did notch where the latching is but you are the Artist...How old is the box?...Remember Ed Lloyds Pizza T...:D
    A great re-purpose for the Tree Branch Door Service Express
  20. loudbang
  21. ct1932ford
    ct1932ford
  22. tb33anda3rd
    tb33anda3rd
    snuck out of work early, Charlie came by to work on the bed. he sanded down the bed. IMG_1593.JPG
    chryslerfan55, brEad, TFoch and 3 others like this.
  23. tb33anda3rd
    tb33anda3rd
    I made up the angles for the perimeter. I had to stretch them to go around the corner. I welded them on with everything clamped to the table. IMG_1594.JPG IMG_1595.JPG IMG_1596.JPG
    chryslerfan55, brEad, TFoch and 5 others like this.
  24. tb33anda3rd
    tb33anda3rd
    cleaned up the welds and test fit it. IMG_1597.JPG IMG_1598.JPG IMG_1599.JPG IMG_1600.JPG
  25. tb33anda3rd
    tb33anda3rd
  26. Stogy
    Stogy
    :rolleyes:...looks awesome TB, I'll bet Charlie's getting excited...I am and it's not mine...:D
    Any green paint around...;)
    OFT, tb33anda3rd and loudbang like this.
  27. ct1932ford
    ct1932ford
    Nice![emoji106]
  28. Ted, your talent never ceases to amaze me.
    Stogy, safetythird, OFT and 3 others like this.
  29. tb33anda3rd
    tb33anda3rd
    thanks guys!
    I missed a few photos but I drilled into the ends of the upper tube and slid the original steel tube back in. I welded the ends up, the cut a couple grooves in the face side. IMG_1602.JPG IMG_1603.JPG IMG_1604.JPG IMG_1605.JPG
    chryslerfan55, Stogy, brEad and 4 others like this.
  30. tb33anda3rd
    tb33anda3rd
    I cut a couple grooves in the face side through the sheet metal and into the ends of the pipe. I then cut a couple brackets for the chain hooks. I pounded them in and welded them up. IMG_1606.JPG IMG_1607.JPG IMG_1608.JPG IMG_1609.JPG IMG_1610.JPG
