Hot Rods T Bucket Interiors
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Aug 12, 2017.
  1. 1923Fratrod
    1923Fratrod
    Have u done the corbeau bench seat in the t bucket was planning on using it myself send some pics plz and how much of a riser is needed on it like to make something that I can mount fuse box’s and that under it
  2. 1923Fratrod
    1923Fratrod
    Can I get some better pics on this seat in ur t bucket and how much did I have to raise it up off floor looks nice. Been thinking about doing it myself same seat thanks
  3. RodStRace
    RodStRace
    Fred got another seat and has installed it in his bucket.
    There may be pictures here, I KNOW there are pics in the "Bucket Of Ugly" thread.
    Here is one from there
    If you go back one page in this thread, you can see Fred's seat riser and how much room there is.
    The pic I posted was just something I found. I don't currently have a T bucket, with or without a seat.
    Depending on if your floor is at the bottom of the body (unchanneled) or up inside the body from the bottom (usually the height of the frame i.e., 3 inches channeled), you could have the seat flat on the floor and the fuse box inset into the floor. Just make sure it doesn't run into the frame or any other mechanical bits. Note that the front of the seat is usually up off the floor even if the rear of it is right down on the floor for leg support, so you often can have the fuse box mounted at the front of the seat or on the seat riser, depending on size and it will still clear.
    Doing an image search, I found this kit. This fuse panel should be enough to handle a basic t and it's SMALL. Note that I do not know the company or product, this was just a picture I found. I suggest buying from and supporting companies that support the HAMB.
    http://ns2.holidays.net/store/8-cir...-rat-rod-32-34-Model-A-T-28_161019692411.html
    [​IMG] [​IMG]
    loudbang and patmanta like this.
  4. 914 seats
    WC145 likes this.
