Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. Ziggster
    Ziggster
    Some snap shots off vids from Goodwood of their “chain guards”. Lol! These guys have balls of steel to race those machines.
  2. animal8324
    animal8324
    from nj
    A 40 tooth front sprocket would be doable. I planned on using idlers to set chain tension but now im thinking of making slots where the ubolts for the rear leaf springs go which would allow the axle to be adjusted fore and aft.
    Love the rigs at goodwood. I hope i can afford sprockets that look as cool as the lower one.
    Today I was contemplating sending the 3d printed gears to a foundry instead of a machine shop. Ill look into pros vs cons of casting.
  3. atch
    atch
    Would a cast sprocket have to be quite a bit thicker than a machined steel one to withstand the stresses?
  4. 48fordnut
    48fordnut
    Just read the whole post. I don't have enough adjectives to express the ideas and craftsmanship.
    Awesome.
    Keep up the great work in 21.
  5. Ziggster
    Ziggster
    Just watched an old Top Gear short vid where Jeremy Clarkson says this of the chain drive on the Brutus Bomber:
    “...the chain drive from a machine the devil uses to rotissaire those who displease him..”. Lol!
    It was built on a 1907 NY city fire engine chassis.
    I would think a simple disc of the appropriate thickness using a water jet would suffice. I remember seeing a lot of sprockets at a farm machinery dealer when I was thinking of a chain drive trans.
  6. Fabber McGee
    Fabber McGee
  7. DesmoDog
    DesmoDog
    Thor1 and RodStRace like this.
  8. RodStRace
    RodStRace
    Those numbers look better!
    Nothing says you couldn't have a manufactured sprocket water jetted with holes in your own pattern, unless the maker says no.
    Only concern with cast is strength/hardness of the teeth. This can be planned out to work, of course.
    Depending on what you can find/buy, you could use old stuff and machine the inner and outer to accept new sprocket teeth.
    https://www.etsy.com/listing/917920...2663&msclkid=267c98671c3815d7b388c79516c5aeaa
    Even use the pictured parts and bolt it to new outer sprockets like old BMX sprockets
    chryslerfan55, Thor1 and loudbang like this.
  9. animal8324
    animal8324
    from nj
    The front 40 tooth sprocket is available for $189 from usa roller chain. Ill still have to bore out the center and drill bolt holes but atleast its available.
    My rear sprocket will have to be the custom one.
    Anyways I started getting the 20210103_163211.jpg 20210103_163226.jpg 20210103_163236.jpg cockpit together.
    The 28 plymouth Master cylinder im using needs a remote reservoir and I always thought an oiler would be perfect for it. So i scored one this weekend and it got me energized to figure out my steering column mount and gas pedal so I could see it in place.
    I toyed with a bunch of gas pedal designs in my head before I finally settled on this one and I love it. It's simple and comfy. I may put a slight bend in it but not much else.
  10. This thing is so badass, whats the plan for intake / exhaust?
  11. animal8324
    animal8324
    from nj
    Thanks
    Intake will remain factory. I may do individual stainless exhaust around 10" long or duel lake pipe style. Still chewing it over
    VANDENPLAS, Thor1, Stogy and 2 others like this.
  12. animal8324
    animal8324
    from nj
    Got my steering column extended and the steering wheel mounted!
  13. ratfink56
    ratfink56
    Sheer, unadulterated madness. I love it!
  14. Fabber McGee
    Fabber McGee
    Nice wheel, about 18 inches?
  15. animal8324
    animal8324
    from nj
    Thanks
    She's a 17" wheel. Its absolutely perfect for this rig
  16. In case it matters those cast pieces in the iron anarchy picture are seed plates from an old corn planter, you can read - this side away from seed- on the plate on the left. Newer one were made out of plastic. Not sure that is anything you want to incorporate into a drivetrain.
  17. noboD
    noboD
    Sumbitch, I knew I saw them before. They take a flat chain like a manure spreader too don't they?
  18. animal8324
    animal8324
    from nj
    Seeder plates will definitely not be used on my rig
  19. animal8324
    animal8324
    from nj
    Anyone got recomendations for the sprockets Alloy?
    Also started on the gas tank.
  20. noboD
    noboD
    Steel, could be hot rolled.
  21. getow
    getow
    I personally wouldnt know what to recommend, but if it was me, id look at motorcycle spocket metals. Might be an avenue there??
    Thor1 likes this.
  22. LWEL9226
    LWEL9226
    from So. Oregon
    Case hardened steel....
    LynnW
  23. animal8324
    animal8324
    from nj
    Got the tank tacked together tonight.
  24. Ziggster
    Ziggster
    That looks great. Wish I had those kind of fab skills.
    loudbang and Thor1 like this.
  25. animal8324
    animal8324
    from nj
    Thanks a ton man. I've made a ton of scrap to learn my trade
  26. animal8324
    animal8324
    from nj
    I dug into the engine today and found a cracked piston. On the plus side of the day I blocked off the second outlet on the water pump.
    And really it is time to start teardown to complete welding 20210117_135355.jpg 20210117_134710.jpg 20210117_134455.jpg 20210117_145852.jpg and to get ready for paint. Ill keep the rear chassis together untill I figure out the chains
  27. Fabber McGee
    Fabber McGee
    Now, where do you get a piston?
    Stogy, Thor1 and loudbang like this.
  28. animal8324
    animal8324
    from nj
    I got a line on a set.
  29. animal8324
    animal8324
    from nj
    Heres alittle update.
    Pulled both heads and found nothing else to be concerned about. The bearings miced out in spec and the cylinder walls look damn good so im just gonna hone the cylinders of the 2 pistons I removed and reassemble when I find my new piston. 20210119_133006.jpg 20210119_133006.jpg
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
    Interesting rocker arm setup. How about some pictures of the cylinder heads, top sides and combustion chambers?
    chryslerfan55, Stogy, benke and 2 others like this.
