Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    I made up a strap hinge that will eventually get riveted in. I put a couple screws in till I prep the back sides. IMG_1611.JPG
  2. tb33anda3rd
    tb33anda3rd
    plan is to make up four brackets to bolt through the rear brace with a couple pins for the hinge. IMG_1615.JPG
  3. ct1932ford
    ct1932ford
    Stopped over Ted’s barn today and the pickup bed looks even better in person.[emoji41]
  4. nunattax
    nunattax
  5. 31Apickup
    31Apickup
    loudbang, Stogy and tb33anda3rd like this.
  6. TFoch
    TFoch
    Great looking tailgate!
  7. tb33anda3rd
    tb33anda3rd
    thanks!
    made a template for the brackets out of card stock and cut them out of 2x1 angle. I drilled them out and made a couple pins out 1/2" rod, using a washer for the head and drilling out the opposite end for a cotter pin. IMG_1617.JPG IMG_1618.JPG
  8. tb33anda3rd
    tb33anda3rd
    I shimmed the gate on either side and clamped it in place, ***embled the hinges and clamped them down. I drilled out the crossmember. I used round head slotted 1/4" bolts IMG_1619.JPG
  9. tb33anda3rd
    tb33anda3rd
    once bolted down I tried the gate.
  10. nunattax
    nunattax
    you are on a roll bud
    Stogy, loudbang and tb33anda3rd like this.
  11. tb33anda3rd
    tb33anda3rd
    almost done. I made a cardboard template for the other half of the hook system to hold the tailgate up. I cut them out and welded them in place. IMG_1624.JPG IMG_1625.JPG
  12. tb33anda3rd
    tb33anda3rd
    while it was cooling I cut the belt buckle **** off the chains, and attached the chain right to the eyelet .I marked for the hole, drilled it and filed it square. IMG_1623.JPG
  13. tb33anda3rd
    tb33anda3rd
    gate swinging and latching and lays flat for sitting on. next step will be to finish the rear cross member. IMG_1629.JPG
  14. TFoch
    TFoch
    Time for a "Tailgate Party" :D
    loudbang, Stogy, OFT and 4 others like this.
  15. Atwater Mike
    Atwater Mike
    Ahhh... Ted's BED & TAIL works. Sounds...'modern'.
    True mastery of all the steel and wood repairs, Ted treed it!
  16. tb33anda3rd
    tb33anda3rd
    stopped at the Slackers house yesterday to check on progress . he has been working on the fenders. they are really beat up and one of them has had a bunch of filler work done to it already. he trimmed the front sides and made a piece for the front of the drivers fender that was missing. IMG_1631.JPG IMG_1632.JPG IMG_1634.JPG
  17. tb33anda3rd
    tb33anda3rd
    Charlie has gotten the engine compartment sorted. IMG_1633.JPG and I got a chance to get behind the wheel. there is plenty of room and the seat is very comfortable. IMG_1636.JPG
  18. tb33anda3rd
    tb33anda3rd
    made some tubes for the rear support to keep the hinge bolts from crushing it. I drilled a 3/4" hole through the back side and used EMT pipe. I also filed the holes for the carriage bolts that bolt it to the sides. IMG_1639.JPG IMG_1640.JPG IMG_1641.JPG
  19. tb33anda3rd
    tb33anda3rd
    I then trimmed the top flanges back on the cross member and coated the inside with weld through primer. I bent a piece of 16 gage to make the trim piece for the top of the crossmember. this will give a metal edge for loading the bed and finish and protect the ends of the bed wood floor. IMG_1642.JPG
  20. tb33anda3rd
    tb33anda3rd
    I ran out of wire in that machine so I couldn't finish the welds. but I did take it apart to prep for primer and paint tomorrow. IMG_1648.JPG
  21. TFoch
    TFoch
    You're a busy guy!
  22. tb33anda3rd
    tb33anda3rd
    I unbolted the strap hinges from the gate and sand blasted the area behind them. I then put a weld through primer on the adjoining surfaces so I could heat the rivets up that will hold them on. IMG_1651.JPG IMG_1652.JPG IMG_1653.JPG
  23. tb33anda3rd
    tb33anda3rd
  24. tb33anda3rd
    tb33anda3rd
  25. TFoch
    TFoch
  26. Runnin shine
    Runnin shine
    You forgot to cut the square holes in the top side rail stake pockets. How are you going to put on the fallen tree reclaimed wood extensions? Just one slat a side will still look hot rod if only a few inches tall.
    Are you going to mimic the cab paint?
    Will Charlie have black fenders on this awesome little truck?
    You have to be giggling a little as you’ve made this bed Ted.
    chryslerfan55, Stogy, brEad and 2 others like this.
  27. ct1932ford
    ct1932ford
    Stogy, loudbang, TFoch and 1 other person like this.
  28. tb33anda3rd
    tb33anda3rd
    no holes for the stake pockets, it will have the reclaimed wood in the back half of the bed floor. the front half will have a tool box to cover the fuel tank and battery and a dry spot for tools.
    plan is to mimic the cab paint on the bed and the fenders will be black.
    I am quite pleased at how it came out. I think it looks "model A like" enough.
    I bet in the future someone is going to post a picture of it on the ford barn, asking what year and model.;)
  29. tb33anda3rd
    tb33anda3rd
    thanks Tom
  30. Runnin shine
    Runnin shine
    If I only had a two pot manifold laying around I’d be mailing it to the slacker immediately!
