Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. I would say either fully polish, or fully copper plate.
    I'm a fan of the polish look myself.
    Stogy, loudbang, waxhead and 2 others like this.
  2. Either way, they are objects of art that would look equally phenomenal regardless of where or what they are attached to!
  3. TFoch
    TFoch
    What CAD program did you model it in? Just curious.
    Stogy and loudbang like this.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    This was done in SolidWorks...
    Stogy, loudbang and TFoch like this.
  5. RodStRace
    RodStRace
  6. burl
    burl
    from Minnesota
    pretty impressive project and parts.Tooling on these parts would be pretty cost prohibitive even if it was built offhore.
    Then try to find a caster that would be interested at the lower quan***ys that would be another hurdle.Machining out of billit on a automated five axis and you could get the price down to cost effective.I applaud your determination to see this through.Most dont understand all of the work behind a project like this.
    Outback, Stogy, loudbang and 2 others like this.
  7. Kevin Pharis
    Kevin Pharis
    from Califunny
    The UPS guy delivered my special tooling order today... now if only I can get some time in the shop this weekend to make some progress on the new throttle barrel.
    Outback, Stogy, dwollam and 1 other person like this.
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    Was able to get most of the throttle barrel internal section finished up yesterday. Ran into an unexpected clearance issue on the ****erfly side of the venturi, so am waiting for some new tools... again!:rolleyes:
    Here is a pic of the top half of the venturi and the spray bar air inlets
    Outback, Stogy, KiWinUS and 10 others like this.
  9. Kevin Pharis
    Kevin Pharis
    from Califunny
    While waiting for the special tools to finish the throttle barrel... I made some more fuel inlet blocks, and also some Winfield S-A to Model A manifold adapters
    Outback, Stogy, TFoch and 7 others like this.
  10. tubman
    tubman
    I am still amazed by all of this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Get’n there...
    426B7FB9-F3CF-4933-BC68-A2DA8340CF23.jpeg A091E227-D0B6-4DBC-9C5B-F16E6D9F9449.jpeg
    Outback, Stogy, KiWinUS and 7 others like this.
  12. belair
    belair
    Marvelous. Thank you for sharing.
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Do you ever get the feeling yur makin progress...?
    9CA072EE-7DD6-4BB7-8629-65F4C394D82D.jpeg ECCA9485-F8A4-4355-8D67-7B429D99A55D.jpeg
    Outback, burl, Stogy and 12 others like this.
  14. hotrodA
    hotrodA
    WOW! Amazing skills.
  15. banjorear
    banjorear
    Super cool! Please keep us posted.
  16. TFoch
    TFoch
    Looking great!
  17. Kevin Pharis
    Kevin Pharis
    from Califunny
    Have had the itch to get out in the shop... but can’t seem to find the time!:eek: The weekend is almost here, so hope to have more progress pics soon...
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Last weekend was dedicated to ironing out the issues of the first part... and it was no small task! Tooling was adjusted, fixturing was reworked, programs were reconfigured, and somehow I still found the time to run another part... but this time without the oops!
    As long as I can keep from screwing this one up during the next operation, this throttle barrel should finish into a good part!:eek:
    DBFD7C57-EA52-4F64-A25D-EA24429BF5C0.jpeg 0C81BB51-6E43-4B9D-A0AC-230664B6745C.jpeg
    Outback, burl, Stogy and 8 others like this.
  19. I've never responded to a thread so quick!! Love what you're doing.
    You might want to check this youtube out, they do alot of stuff with Winfielf carbs!
    Outback, Stogy and loudbang like this.
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    The further along I get into this project... the more I realize that calling Brauns would have saved me a ton of time and money! But for me, it’s all about the adventure! So when I’m done, I’ll have what I wanted, and if there’s interest maybe even a little side business making parts for these notoriously mixed up carbs.
    Stogy, loudbang and Retson the Racer like this.
  21. Kevin Pharis
    Kevin Pharis
    from Califunny
    Here is a shot of the original literature showing the throttle barrel in cross section during all 3 fuel circuits. Once I have 5 of these ******s to go along with my float bowls, it’s time for the throttle plates... and testing!!!:D
    13E6AD0B-EAFA-4154-B7F8-26807C632D66.jpeg 113CC79A-1D56-4892-A9F8-3BA4C92604D3.jpeg
  22. Kevin Pharis
    Kevin Pharis
    from Califunny
    Was at it again today... this time building throttle plates. Not near as simple as a conventional ****erfly plate, these are basically a segmented ball bearing. After a bit of head scratching, I was able to make some chips and now have a couple throttle plates that fit my new throttle barrels
    Here we are getting spherical
    And finished
    And installed
    Outback, Stogy, mvee33 and 11 others like this.
  23. Just saw your post on MTFCA- fantastic work as usual, Kevin!!!
  24. brading
    brading
    Must say that is some bit of machining. Looks real nice.
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    Thanks fellas! This was a big relief to get these throttle plates done and installed... after spending 2+ months getting 5 throttle barrels made up, I finally feel like this is all going to work out...!:eek:
    Outback, Stogy, kidcampbell71 and 5 others like this.
  26. Ryan Noble
    Ryan Noble
    Amazing work! If you feel like moving on to size BB at some point, you may have a customer here.
    Stogy likes this.
  27. Kevin Pharis
    Kevin Pharis
    from Califunny
    I like to think that I would make other size variations someday... but gotsta get thru this B first. And it looks like I will be starting another batch of B’s as soon as I prove that these work as intended. The more interest I receive... the more likely it’ll happen
    Outback, Stogy, Ryan Noble and 3 others like this.
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    Been having small successes lately... with small parts. Still have a few more pieces to go, but have made throttle bushings, idle byp*** plug, int/high speed adjusting needles, idle needle, idle needle seat, bowl to barrel studs, idle stop screw and jam nut, spray bar retaining screws, float level plug, and int/high speed accelerating well plugs.
    Outback, Stogy, chrisp and 8 others like this.
  29. alchemy
    alchemy
  30. RodStRace
    RodStRace
    This is a goofy question, but the major carb mfgrs always touted about how the jets were high precision in not only the through hole and taper but depth. I figured they would run a batch and measure flow (QC) a selection before stamping with the size, in case tooling wear caused variations.
    Did you copy good examples or compare flow? Just curious, NOT questioning you abilities after the other stuff shown in this thread!
