Time to make space. 1928 Ford 2 door Sedan original paint hot rod. Great patina! Came out of a barn in MT years ago. Car was originally Washington Blue. Below are several of the key components: Original body, most all original ford wood. Top needs replaced if you want to put covering on Home built 32 style frame, pinched for '28 cowl. Model A front xmbr, 32 Ford rear xmbr 1950 Cadillac 331 V8 and Hydramatic trans (converted to floor shifter) Original 1932 Ford grill shell and insert 12" Buick brakes (finned Alum front/finned iron rear) 1940 Ford rims Original dropped axle (Dago or Okie Adams?) Split wishbone front, transverse leaf spring 36 radius rods rear with Johnny Joint ends and torque arm Detroit Racing Equipment manifold and linkage with 2-2bbl 1950 Cadillac WCD carbs Early curved gl*** Stewart Warner gauges (not all hooked up) 32 gas tank modified to fit behind 28 body. Front and rear bench seats 1947 Lincoln 12 steering wheel with horn ring Ford F1 steering box and column with big truck Column mount Many more details and neat parts. Hot rod built with original parts where possible I will be keeping the Hildebrandt valve covers and 1928 WA plate (unless WA buyer wants to pay a little more for it) Will put original early script Cadillac valve covers on. Now has a 12V mini alternator. I will include 6V generator if buyer wants it Sold as is, where is. This is not a done, completed car by any means. It runs, drives, starts, stops and is a ton of fun! Leave it as is, finish it off, ad your touches. Up to you! Asking $14,500.00. Will listen to realistic offers. Not interested in trades (unless it is for 1936-64 Harley Big Twin bikes, baskets, parts) Pickup and shipping buyers responsibility.
