Projects 41 Ford pickup finally got it home and pictures pictures
Discussion in 'Traditional Hot Rods' started by joel, Jul 19, 2017.
  1. joel
    joel
    Finally it feels like progress. Thanks for following.
    Thor1 and loudbang like this.
  2. joel
    joel
    Thanks, Gary. I was hoping to do a little at a time while driving it occasionally, but it'll be a while before I can drive it again.
    Originally, I looked at doing some machining on transmission pieces so I could keep the torque tube. When I first mocked up the trans, it was easy to see that keeping the trans as is and go open drive was best.
    My coupe has split bones ( Ch***is Engineering ) . I used a doug nash 4+1 there and there was no other option. Stay tuned for the cab repair; There is a ton of rust repair on the cab. Thanks for your comments.
    Thor1 and warhorseracing like this.
  3. 64Pony
    64Pony
    My frame had that same kind of crack under the p***enger side u bolt. Someone had welded it up a long time ago and then put angle iron on top to support the cross member. The same angle iron metal was used for a homemade trailer hit as well. That hitch was belt to hell as well by someone trying to drag or rip something out of the ground. My guess is they were using these trucks to pull stuff they shouldn’t of been. Gotta love these old field fixes. lol
    Thor1, joel and loudbang like this.
  4. joel
    joel
    More work on the torque box replacement.
    IMG_1759.JPG I had to plug some rivet holes that didn't line up and re-drill them. I backed the hole with copper and tig welded them shut.
    Holes drilled and plates installed. I used a plum bob to transfer the frame centerline to the bottom plate.
    IMG_1761.JPG I added 2 reinforcement pieces to the inside of the bottom lip because the frame was a little thin. I took Christmas off, so I have to weld them in place tomorrow.
  5. joel
    joel
    IMG_1762.JPG Started welding in the reinforcement pieces.
    IMG_1763.JPG I chamfered the holes so the weld builds from the bottom.
    IMG_1774.JPG almost ready for the powder-coat.
  6. TomT
    TomT
    Looking good, Joel - I like the lower lip support and I will probably do the same on mine even at this late stage in the game ......
  7. joel
    joel
    I didn't do it on my coupe , but that frame had not been out of the garage for a very long time. I did a little repair in the kick up areas in back, but other wise nothing. Besides, I don't want my grandson to inherit a piece of **** .:D
    TomT, Thor1 and loudbang like this.
  8. Tyler Huff
    Tyler Huff
    About to do the same thing to my 1936 Ford. Thanks for the photos!
  9. Subscribed!...after going through and enjoying your coupe build thread yesterday, I read through and enjoyed this thread today.
    loudbang and Thor1 like this.
  10. joel
    joel
    I took the frame ( second frame ) to powder coat yesterday and should get it back early next week. I'll post pix when I get it back. Hooray!
    kidcampbell71, Thor1, TomT and 2 others like this.
  11. Mart
    Mart
    Hoorah! Looking forward to seeing it start to come together.
  12. joel
    joel
    I picked up the frame yesterday and put it back on the spinner to start ***embly. I rolled the rear axle under it and bolted the spring to the crossmember . This makes the frame difficult to rotate, but it's still possible.
    IMG_1793.JPG IMG_1795.JPG I'm lining up the wishbone front mount to ensure rear end is square with the frame.
    I used racket straps to simulate ride height. Next is installing the front axle and check wheel base.
  13. Mart
    Mart
    Lookin' good, Joel.
    loudbang, Thor1 and TomT like this.
  14. flat-ed
    flat-ed
    Nice work!
  15. joel
    joel
    IMG_1797.JPG Rear is square and front is square with the frame and The dimension kingpin hole to rear axle is the same on both sides. It looks good so far.
    IMG_1798.JPG The wishbone mount is clamped in place; I just need to transfer the holes and drill the frame.
    IMG_1799.JPG All I have to do for the front is bore the hole for the ball mount. The soapstone marks are the where the edges of the block is supposed to be when I'm done. Eventually the block is trimmed to the cap shape and welded to the plate. I'll also have to cut clearance for the wishbone to move in the front edge of the plate.
  16. warhorseracing
    warhorseracing
    from cameron wv
    Final alignment should be a snap as square as you have everything going off of the frame and it being squared also. Good looking foundation for a soon to be spectacular vehicle.
  17. joel
    joel
    I hope so, however, I am moving cautiously when locating the hole for the wishbone socket. Thanks for your encouraging comments.
    loudbang, Thor1 and warhorseracing like this.
  18. joel
    joel
    The rear wishbone mount is done.
    IMG_1800.JPG IMG_1802.JPG This is the first shot at locating the ball mount socket. The hole is undersize with a 45 deg. cut at the top.
    IMG_1804.JPG The cut matches the angle on the tip of the socket piece.
    This is how I'll install it to check location. If the axle is still square with the frame, all i have to do is open the hole to the finish size. If the axle is off square, I have enough material to move the hole left or right.
  19. ronzmtrwrx
    ronzmtrwrx
    Looking good man. Are you planning on triangulating your rear wishbones, or did I miss that?
  20. Mart
    Mart
    Nice work, Joel.
    Can I share a thought with you (all). If you added two tabs to the front parts of the rear radius arms, sticking inwards, towards each other, so they overlapped and then bolted the two radius arms together, it would stop any tendency to bend the two ears where the bolt goes through the heim joint.
    Just a thought, can anyone else understand what I'm thinking?
    Mart.
  21. joel
    joel
    I have a tab welded to the right side bone and a "torque arm" that fits between that tab and a bracket that bolts to the diff. housing. It is a kit from HRW that makes the wishbone mounting plate and the slide in axle kit that I used. https://www.hotrodworks.com/
    40FORDPU, TomT, loudbang and 2 others like this.
  22. joel
    joel
    That's an interesting idea, Mart. I'm going to look at that when I can get the trans. back in and the driveshaft made. Thanks for your input.
    TomT, loudbang and Thor1 like this.
  23. joel
    joel
    IMG_1806.JPG The wishbone mount is finished machining and locating on the plate; all I have to do is weld it to the plate. You can see the sharpe marking the clearance cut in the plate. It needs to be welded before I cut on it. Then I can paint it.
    BTW the wife and I got vaccine shots today.
  24. The 39 guy
    The 39 guy
    That's a slick looking install Joel.
  25. Bandit Billy
    Bandit Billy
    If that's a vaccinations against catching the hot rod bug I think I'll keep the Mrs and I out of the herd.
  26. joel
    joel
    No, nothing can cure that. We hope to be able to spend more time with our grandson is all.
    loudbang, Bandit Billy and Thor1 like this.
  27. hotrodA
    hotrodA
    Wow! That frame came out nice.
    That’s what I wanted to achieve with my pieced together frames, but it wasn’t destined to happen.
  28. joel
    joel
    I've been working on the transmission. I tore it down to replace gaskets and seals and inspect for wear. I'll probably replace the syncro rings and maybe the reverse idler gear; otherwise it looks pretty good. I mocked up the empty case to get a driveshaft length.
    IMG_1814.JPG IMG_1815.JPG The angle iron is because I can't find the water pumps ..... Aaaa the golden years.
  29. joel
    joel
    63314264910__C1C9371A-D860-4E5E-BA0A-BABE4B23279B.JPG Everything is cleaned up and waiting for rebuild kit to arrive.
  30. joel
    joel
    I finally finished the wishbone mount and rattle canned that and the front shock mounts.
    IMG_1819.JPG IMG_1820.JPG I put this copper weld through where the pieces are against each other. Better than nothing I guess.
    IMG_1821.JPG IMG_1822.JPG I added a bridge across the wishbone clearance cutout to maintain strength.
    IMG_1823.JPG Ch***is Engineering mounts came on the truck, but the frame now looks too nice. I had to repaint them.
