Projects Frenzel Supercharged Ford 1936 3 Window Coupe-Chopped Build
Discussion in 'Traditional Hot Rods' started by TWO9FORD, Jan 17, 2021.
  1. TWO9FORD
    TWO9FORD
    I figured I would start a build on my 1936 Ford 3 Window Coupe since I am finally back after it.
    You can follow along on my IG @Spankys_garage
    Going to have a solid ch***is/suspension underneath, pretty engine and interior, and rough outside...
    Chopped and roof filled by the Menges Twins Speed Shop:
    Frenzel Supercharger by Aaron Loveless and hand delivered by a Cessna:
    Anthracite powdercoating on the Eddie Meyer Heads and Black for the intake. Duel Stromberg 97's
    Filled in the firewall and painted it Wimbledon White:
    Stock 36 front axle dropped 5" by Anson Axles with 2 leafs removed from the stock leaf. Flattened rear crossmember by John w/ Br*** Junkie:
    Custom gl*** all the way around... Getting the hood and decklid louvered Monday by Gene Winfield...
    Old cloth style wires...
    Just because:
    Finally sitting on all fours... I like the stance and love me some wide fives!
    Currently at
    Hot-rod Chavik for some finishing and customizing. Body is coming off and frame is getting blasted, then add a T-5 Trans, and some mods (flattened rear crossmember) then powder coating it to have a good base to start from. Run brakes, Fuel, Power, Suspension, Open Driveline, and fire that baby up!
    catdad49, j hansen, Sprout and 42 others like this.
  2. Kiwi 4d
    Kiwi 4d
    Absolutely wicked, there clearly has been some serious thought gone into this one. Its going to be a game changer.
    TomT, chryslerfan55, fegsta and 2 others like this.
  3. TWO9FORD
    TWO9FORD
    Thank you! Its a dream build so I am pulling out all the stops and having some serious talen lay their hands on it....
  4. x77matt
    x77matt
    Awesome!
    TWO9FORD and loudbang like this.
  5. akoutlaw
    akoutlaw
    Nice! Do you have any in progress pics of the chop?
    chryslerfan55, TWO9FORD and loudbang like this.
  6. $um Fun
    $um Fun
    from Nor Cal
    That is just too cool as a jewel.
  7. Rustygt
    Rustygt
    from Emeryville
    A cool looking rod for sure that Frenzel is like unobtainable to most
    Enjoy your dream
  8. hotcoupe
    hotcoupe
    Wowza!
    Tom
    loudbang and TWO9FORD like this.
  9. brady1929
    brady1929
    Incredible.
  10. TWO9FORD
    TWO9FORD
    I do have a decent amount of pics... I will post some up if you would like?
    Thank you!
    Thank you! Not sure how I got here but I'll take it and enjoy the build and ride!
    Thanks!
    Thank you!
  11. hotcoupe
    hotcoupe
    A car like that, you should consider using Lincoln Zephyr brakes, REAL ones.
    Tom
    chryslerfan55 and TWO9FORD like this.
  12. akoutlaw
    akoutlaw
    Please! Thank you!
    loudbang, chryslerfan55 and TWO9FORD like this.
  13. Is the Frenzel a new made piece. Great looking car & engine.
  14. Doc.
    Doc.
    Great looking build. Definitely not an original Frenzel. Nothing wrong with that,just answering a question
  15. TWO9FORD
    TWO9FORD
    It is a repop of the original.. #6 ... Best part is it has a few updated parts and I was told to run the **** out of it and if there's any issues, just bring it back in... and you bet I'm going to try...
  16. TWO9FORD
    TWO9FORD
    Had an epic day today at Gene Winfields getting 274 Louvers done on the hood and decklid... Great time with Great People!
    140188668_3805881256144226_1287154409278211237_o.jpg 140395529_3805882506144101_8875461345948231423_o.jpg 140041873_3805882209477464_2749156848750881887_o.jpg 139770371_3805882916144060_6890458454123286386_o.jpg 140111285_3805881889477496_1216862692649953558_o.jpg
  17. TWO9FORD
    TWO9FORD
    Body was pulled and frame was taken apart to send out to get media blasted, do some fab work, then powder coat it... All by Hot Rod Chavik
    20210119_081152.jpg 20210119_084559.jpg 20210119_124624.jpg 20210119_144231.jpg
  18. 41rodderz
    41rodderz
    from Oregon
  19. b4autodark, VANDENPLAS, Stogy and 8 others like this.
  20. JOHN H EDGE
    JOHN H EDGE
    Love those chopped coupes ours has small block Chevy with mustang 2 front end and 9 inch ford with coil overs
  21. flatheadpete
    flatheadpete
    from Burton, MI
    Uh....Flathead, check. Blower, check. Bad *** chopped coupe, check. Dang. Checks all the boxes for me.
  22. hotcoupe
    hotcoupe
    Cool set-up, just curious, how are you going to drive the generator?
    Tom
    TWO9FORD likes this.
  23. akoutlaw
    akoutlaw
    I love the look of this car! Were you the ones who chopped it? I have a 36 to do some decade, & would like the chop to look like this. Thanks.
  24. fegsta
    fegsta
    Gene made a m***ive impression on my grandson Liam. Liam said the same that man never stops. We was hopefully going to get over to tour his place. Anyway gene told Liam he was cool and that was that. 1592645230138.jpeg
    Sent from my KOB-L09 using The H.A.M.B. mobile app
    Outback, rumblytruck, Stogy and 6 others like this.
  25. fegsta
    fegsta
    loudbang, TWO9FORD and chryslerfan55 like this.
  26. TWO9FORD
    TWO9FORD
    Very nice 36!!
    Thank you!! I had the same checklist! lol!
    Thats a great question and thats the game plan tomorrow... ill post what we come up with...
    Menges Twins Speed Shop in Creston, CA chopped it... they are legit!
  27. JOHN H EDGE
    JOHN H EDGE
    Didn’t do the chop. Was done many years ago we upgraded
    The suspension and added a/c. Have had several guys get the dimensions from the windows to use for their cuts
    Stogy, fegsta, loudbang and 1 other person like this.
  28. AmishMike
    AmishMike
    Love your hot rod. Any idea of boost & how rise by rpm?
  29. TWO9FORD
    TWO9FORD
    A little more progress on the car....
    Body ready to be removed.
    original frame was shot... found a 40 frame here on the HAMB to change out..
    Flattened rear crossmember:
    Front frame horns were tweaked on the 40 frame so they were cut out and swapped from the original frame:
    Flattened crossmember, open driveline kit, and mocking up the T-5 trans and engine:
  30. TWO9FORD
    TWO9FORD
    Little more on the adapter and trans:
    20210120_080533.jpg 20210120_132147.jpg 20210126_074731.jpg 20210126_074734.jpg 20210126_075349.jpg 20210126_112744.jpg
