Technical What color sealer for a two tone paint job?
Discussion in 'The Hokey Ass Message Board' started by fauj, Dec 27, 2020.
  1. I have been thinking about the eventual painting of my truck and it will be a two tone paint job, white over green most likely. I have always seen that it is suggested to have the sealer as close as possible to the base coat color to aid in coverage. So what would be the best sealer for a white over green paint job?
    I appreciate any info you guys can provide!
  2. oldiron 440
    oldiron 440
    I'd use a medium gray or better yet no sealer at all. Depending on the sealer you will need to sand for the second color.
    fauj likes this.
  3. Thanks OldIron!
  4. 37 caddy
    37 caddy
    from PEI Canada
    i would use a white sealer,spray the white first,then mask off for the green and use a ground coat under the green,i use a valueshade color for what ever it calls for,this is a Axalta brand of paint.If you use the proper valueshade under the paint it will be all even,no funny spots or light spots,and it will take less coats to cover too. harvey
    fauj likes this.
  5. Thanks Caddy!
  6. guthriesmith
    guthriesmith
    I would just use whatever color sealer is the closest to what the majority of the paint will be. Most of today’s paints are high enough solids that they cover fairly quick no matter what is under them. I have only used a colored sealer one time...and that was because the owner of the car owned a paint store and supplied it.
    fauj likes this.
  7. Thanks Guthrie! I'm new to painting so only wanting to do it once, hopefully somewhat correctly!
  8. Mark Stratton
    Mark Stratton
    Easiest to just light gray everything most whites have great coverage​
    fauj likes this.
  9. Never use a red oxide under white.There will be a pink tint.
    fauj likes this.
  10. tb33anda3rd
    tb33anda3rd
    is this a trick question? white sealer under the white, light green sealer under the green.
    fauj and da34guy like this.
  11. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Lighter colored sealer, TAMCO paint, 1 or 2 coat coverage, dont have to worry about all that color match sealer junk
    fauj likes this.
  12. Thanks guys! I appreciate the info!
  13. hotrodjack33
    hotrodjack33
    Just sound like too much wasted effort to have to mask off for sealer, then mask a second time for paint. ;)
    fauj likes this.
  14. 41rodderz
    41rodderz
    from Oregon
    I want a “thanks”.:D
    fauj likes this.
  15. Yes, thank you too Rodderz!
  16. philly the greek
    philly the greek
    from so . cal.
    Most of the major automotive paint mfg's all have primer /sealers available . talk to your local qualified paint dealer for the correct method of mixing and application . Having been in the custom paint business for 40+m years , most of the advice that I see is probably just going to get you in trouble . Good luck
    fauj likes this.
  17. Thanks Phil!
  18. tb33anda3rd
    tb33anda3rd
    I seal right before I spray color, so it is only taped once. the primer under that could be any color. the sealer should be matched to color.
    fauj and hotrodjack33 like this.
