Technical Painting distributor
Discussion in 'Traditional Hot Rods' started by dirt t, Jan 20, 2021.
  1. dirt t
    dirt t
    If I tape terminals can I paint the distributor cap to match the eng color.
    Chevy orange.
  2. seb fontana
    seb fontana
    from ct
    I don't have any rule on that, its done on industrial engines when the equipment get painted, no tape for you...
    2OLD2FAST, VANDENPLAS and loudbang like this.
  3. Mr48chev
    That just sounds too lame for words.
  4. dirt t
    dirt t
    Was that a yes ??
    BigDogSS likes this.
  5. abe lugo
    abe lugo
    do what you want, just don't paint the contacts inside or outside.
  6. Mr48chev
    That was a serious don't do it and make it look goofy. If it happened to come black, repaint it black but painting it to match the engine color just doesn't fly.
  7. Bigmac48
    Bigmac48
    from Dundalk Md
    Thought about doing that myself !
  8. 19Fordy
    19Fordy
    Plug the terminals with old plug wires and paint the cap.
    Let dry and remove the wires.
  9. seb fontana
    seb fontana
    from ct
    From me yes, especially if it will irritate some one!
  10. Budget36
    Budget36
    I have no patience to sand and paint a distributor cap, don’t most of them come in about 10’colors anyways?
    seb fontana likes this.
  11. hotrodjack33
    hotrodjack33
    ...just don't use a lead based paint ...or any metallics;)
  12. Groovy
    Groovy
    I painted mine... I ripped off small pieces of paper towel and inserted in the top contact holes and also masked off the metal hold down clamp so I didn't blast off the plating. Blew off and replaced new paper towel in terminal holes and masked off the bottom and painted. It was originally a light blue. IMG_3991.JPG
    mad mikey and loudbang like this.
  13. Okie Pete
    Okie Pete
    I've painted the dizzy cap on my Hough 30 payloader . When it gets weathered . The local parts store has a tough time getting new ones
  14. Jokester
    Jokester
    I've done it before..... but orange?????????
    Blues4U likes this.
  15. bchctybob
    bchctybob
    I just painted the ugly red cap on my MSD black. So far so good. I just wiped it down with oil and grease remover, masked the terminals and shot it with engine paint.
    Here’s the before and after...... I know, I know, never mind all of the late model *****ely ****, I’ll be taking it back to the ’60s little by little as I drive it.
  16. George
    George
    That looks good! ***le said Dizzy & the opening comment said cap, didn't notice....
  17. southcross2631
    southcross2631
    SEGA requires red MSD caps get painted black. Go ahead and paint away.
    mad mikey and bchctybob like this.
  18. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Yes. I always paint mine to match. Tape it off good, dont get paint on interior or exterior terminals. It it with some adhesion promoter and go to town.
  19. Blues4U
    Blues4U
    from So Cal
    How much does a new cap cost? Is it really worth it to paint it?
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Sometimes the " silliness" factor on forums amazes me !!:rolleyes:
    mad mikey, LWEL9226, XXL__ and 5 others like this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    Terry, go ahead and paint it orange, it's your car. HRP
  22. Ebbsspeed
    Ebbsspeed
    Do you really need to worry about getting paint on the terminals? Any ignition system worth it's weight in coulombs will shoot a spark right through the paint.
  23. bchctybob
    bchctybob
    I hadn't thought of that, seems like you're right but in my case I always clean electrical connections thoroughly no matter what they are.
    As far as a "silly thread"; I've seen some weird **** happening with distributor caps and rotors, from cracks to moisture, oil and carbon contamination and tracking, all making an engine run poorly. Some coatings may contain ingredients that are somewhat conductive and could lead to erratic ignition.
    The OP asked a valid question, the only silly question is the one you're afraid to ask.
  24. Jalopy Joker
    Jalopy Joker
    x2 - I have painted caps before - keep used rubber ear plugs and put them in plug holes - yes, you do want to cover contacts
    mad mikey likes this.
  25. Bandit Billy
    Bandit Billy
    I did it once when the only cap I had lying around was a standard ignition cap and it was blue. I put those rubber vacuum caps (I have tons of those things) in the terminal holes, removed the door (BBC) and shot it semi flat black. Looked good when it crossed the block.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    Sorry , its just one of those " which end of the nail do I hit?" Things:D
    bchctybob likes this.
  27. jimmy six
    jimmy six
    Paint it any color you want an put on some giant Yellow spark plug wires too..:)
    Blues4U likes this.
  28. Elcohaulic
    Elcohaulic
    If that paint has lead or something that conducts electricity you'll have a miss..
  29. Doublepumper
    Doublepumper
    from OR-WA, USA
    How much does some spray paint cost? Is it really worth it to buy a new cap?:D
    Some paint contains carbon black, which is conductive when exposed to high voltage.
  30. Kiwi 4d
    Kiwi 4d
    Look at @bchctybob , the cap and leads have gone, just how it should be.
    jimmy six likes this.
