Technical 292 Y Block Build
Discussion in 'The Hokey Ass Message Board' started by Budro574, Jan 21, 2021.
  1. Budro574
    Budro574
    Decided to do gaskets and rings on the Y. Leaks from the rear main and oil pump. I had a lot of smoke from the breather tube. It Ran great other wise. During the teardown I found a standard piston which was pretty exciting, but rod bearings have .010 on them and crank shaft bearings showing .040. Seems like a lot of honing to keep a std piston. I’m going to mic everything tomorrow.
    The rods were #’d for each cylinder, but the previous builder put pistons/rods in the wrong places. Smh... not sure how or why someone would go through the effort of marking the rods to put them in the wrong cylinders. The bearings look good, so I’m going to wipe them down and reinstall.
    Question: I got some slack in the timing chain. From the first and second chain image, does it look like it should be replaced? I’d say yes, but a friend said the older engines had a bit more play. 90% sure he’s full of ****, but let me know.
    Can anyone recommend a cam and spring set up? It’s a daily driver. Just looking for a bit more get up. The old cam and valves look great. No #’s though, just the letter “W” on the end of the stick. I Wish I would’ve degreed it before hand. A cam swap isn’t a walk in the park for this engine.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. miker98038
    miker98038
    One of the best sources for parts and info is John Mummert's site.
    In particular I've found his cam recommendations, and his comments on the cam chart to be right on. There's also some mods for oiling on the center cam bearing (on the cam, the block, the bearing) you should be aware of if you're not. There's also a lot of casting numbers info at the bottom of the opening page. Once you ID the heads, you'll know more about how to pick a cam.
    Might help is you added your location to your signature.
    here's the cam page
    http://www.ford-y-block.com/valvetrain.htm
    Budro574 and egads like this.
  3. egads
    egads
    Timing chain is pretty cheap, why not go new? No way I would reuse those bearing's. New ring's ,gasket's, possible cam and old worn out bearing's ???? :eek::rolleyes: How are the cam bearing's ? In what order are the rod's numbered ? It's a y-block----not a small block, some thing's are different.
    Budro574, warbird1, mctim64 and 2 others like this.
  4. 51504bat
    51504bat
  5. miker98038
    miker98038
  6. Budro574
    Budro574
    Wow. Those are old and worn out lol? I’ve seen bearings with no silver at all. Good to know. Would the crank need a polish if I replace the bearings?
  7. Budro574
    Budro574
    That’s the book I’m working from. It’s been a great source of information.
  8. egads
    egads
    If you have it out, you should at least have the crank checked.
    Budro574 likes this.
  9. oldiron 440
    oldiron 440
    You don't say anything about the heads but if I was going to be redoing the bottom end I'd refresh the heads before putting them back on. That motor has been together for a while.
  10. JOHN H EDGE
    JOHN H EDGE
    6D215FA7-973D-4D82-989C-3C8FD679F67B.jpeg Here’s some inspiration for a Y block
  11. warhorseracing
    warhorseracing
    from cameron wv
    Replacing the cam bearings has a specific orientation so pay attention to the book that you have. Yes you need to change that timing chain, they are cheap. New bearings all around, and follow jimmy six on the piston and re-ringing. Why would you not at the very least lap the valves and install new valve seals when torn down? Clean the valve train and ***ociated parts to keep the upper end oiled. There are no real "cheap" engine repairs. Yes you could pop on new rings after a quickie hone, lay in new bearings, re do the heads as far as a hand lap and seals, new gaskets and a can of paint. Cheap engine rebuild. Will it last? Guaranteed 10 minutes or 10 feet even if you have to push the vehicle.
  12. jaracer
    jaracer
    I've got one of Mummert's cams in my 312 and I'm pretty pleased. It has a decent idle and the old Y block performs well.
    I did everything to mine when I pulled it out including a "new" block. One of the things I found was the cam bearings were badly worn. Y blocks also have a lot of casting sand in the coolant p***ages. I spent a lot of time with a couple of tools digging it out through the freeze plug holes. Then I found substantial cracks in the main webs (common on 312 blocks) and had to find another block. That one went to the machine shop to be bored and the coolant p***ages looked like new when I got it back.
    Budro574 and Desoto291Hemi like this.
  13. Fortunateson
    Fortunateson
    That book overview starts off by saying all photos are black and white and then later it says the photos are in colour? If they can't get that right how about the tech side?
  14. 55blacktie
    55blacktie
    More info. will be needed for a cam recommendation. For instance, what is the engine going into? What transmission? Axle ratio? What cylinder heads do you have. Mummert's Technical page will help you to identify heads, including valve sizes and combustion chamber size. Exhaust? It looks like you already have a 4-barrel intake. What size carburetor? Ted Eaton uses Isky cams. Mummert's are Clay Smith. Tim McMaster likes Oregon Cams. Oregon Cams's website has a list of mechanical cam grinds. You can send an email to Ken, who will be very helpful. If you email Ted Eaton, go through his website (eaton balancing). He should reply within a couple of days. In either case, you will need to provide answers to the above questions.
    Budro574 and jimmy six like this.
  15. There is way too much to outline here unless you really want it. I have a lot of opinions and the fastest Y-Block powered car in the world. You can make really good power on a budget if you do a lot of work yourself and have a good local machine shop willing to work with you. If you want to talk look up Hanford Auto Supply in Hanford CA and give me a call. I'll talk you through it.
    Cheers, Tim
