Technical Painting distributor
Discussion in 'Traditional Hot Rods' started by dirt t, Jan 20, 2021.
  1. 26hotrod
    26hotrod
    from landis n c
    Me likes YELLOW plug wires, cap color don't matter............
  2. warhorseracing
    warhorseracing
    from cameron wv
    Personally I would paint it pink.:p Spray painting in enclosed areas makes me dizzy too.:oops:
  3. jimvette59
    jimvette59
    Get a clear one and you will only see the wires :)
    bchctybob likes this.
  4. X38
    X38
    Wasn't this the rage in the 80's when they used to paint everything.
  5. bchctybob
    bchctybob
    I have an NOS ClearSpark GM window cap around here somewhere. What I've always wondered about is the chrome GM caps that I used to see some guy selling at the Long Beach swap meet years ago. I figured it was something the lowriders installed during setup at car shows. Anyone ever see one on a running engine?
  6. warhorseracing
    warhorseracing
    from cameron wv
    Can you see the spark from the points and jumping from the rotor to the contacts at night?
  7. Blues4U
    Blues4U
    from So Cal
    Oh man, I had one installed way back in the late 70's, early 80's or so. If I remember correctly mine was tinted red, but definitely transparent.
    Yes, you can. It's cool for about 30 seconds or so.
  8. lippy
    lippy
    from Ks
    I'd like to metalflake one. Should I epoxy prime first then sand and seal before I shoot it? I thought I would use fine line tape around the terminal ends. But what about the tape line? Will it buff down? I sure don't want a tape line showing under the plug wire boot. What kind of sealer should I use? Lippy
    mad mikey, Budget36, loudbang and 4 others like this.
  9. Blues4U
    Blues4U
    from So Cal
    :D :D That's awesome! :D :D
  10. lippy
    lippy
    from Ks
    Sorry I was being an ***. Funny though I don't feel bad about it. :D
  11. warhorseracing
    warhorseracing
    from cameron wv
    I'll bet when they first came out people would come from miles just to watch it.:rolleyes:
    Blues4U likes this.
  12. George
    George
    Back in the 70s/80s if they wern't yellow it meant you were a cheap ******* still running old OEM wires....
    mad mikey and loudbang like this.
  13. dirt t
    dirt t
    Thanks guy's I painted it.
    Gearhead Graphics likes this.
  14. Harley1x
    Harley1x
    Just scuff it with scotch brite clean it mineral spirits and paint it.
  15. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Could you just paint the engine to match the distributor cap? :D:D:D:D:D:D:D:D:D
    Oh well, its a slow dreary day...........
    Personally I think you should do what you think looks best. If everything on your car is detailed to the max, then it goes with the rest of the detailing. If your car is a simple street rod, I doubt most people would notice.
  16. birdman1
    birdman1
  17. 1952henry
    1952henry
    Next time, wait til the folks in the peanut gallery are out buying snacks. Lol
  18. dirt t
    dirt t
  19. fastcar1953
    fastcar1953
  20. fourspd2quad
    fourspd2quad
    Unless it is something like a magneto you really don't want to draw attention to it, same thing for plug wires. Black wire black cap, done.
    Blues4U and bchctybob like this.
  21. oldiron 440
    oldiron 440
    Being a painter for 40 years I have painted a few distributor caps for customers. I've never heard that there was a problem with them afterwards.
  22. theHIGHLANDER
    theHIGHLANDER
    Here's an idea for those into this topic. Got a generic black coil? Can't live with a cheezy chrome one? Want something that looks old, fits the vibe? Here's a tip from yer ol Uncle Highlander, paint the top black part some rattle can brown. While it's wet dab it a little and give it that tortoise shell look where it's mottled black n brown, and if the black steel shell is too shiny hit with some semi-flat Krylon. Instant vintage coil. How ya like me now...:cool:
    mrfliboy, 1952henry and bchctybob like this.
  23. Very entertaining comments, makes me think "What about stripes like a zebra".
  24. Hardly62
    Hardly62
    Yes you can..its no big deal. Just make sure to mask the plug wire ends and paint away whatever color you want! Do a light sanding to scuff the surface for good adhesion and then paint it as you would a body part. A clean and prepared surface will give you better results.
