Technical Early Ford Quick Change Banjo Build
Discussion in 'The Hokey Ass Message Board' started by brsturges, Nov 4, 2019.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Everything I have seen on your car is first cl***. Sorry to see that second cl*** rear end:p
    When you're ready to step up, I'm here!
  2. With a Winters V8 Quick change you don't need to notch the 32 Gas Tank.
    big duece likes this.
  3. brsturges
    brsturges
    from Miami, FL
    Alright, time for the axle ***embly. The only hiccup I encountered was the fit between the driver's side axle and the ring gear. The axle goes through the ring gear in the area circled in red in the photo below and rides on the area of the axle circled in red. The fit was a bit tight, so I found a socket that was the right size, wrapped some 500 grit sandpaper around it, and honed the opening in the ring gear ever so slightly. That did the trick.
    I got all my internal parts cleaned up and spread out ready for ***embly.
    I greased up the p***enger side axle and the p***enger side of the differential carrier....
    And slid the p***enger carrier half onto the p***enger axle. I then clamped the axle down in a vise to hold it steady when the rest was ***embled.
    Some more grease on the axle teeth and the spider gears...
    Then I fit the spider gears into the p***enger side carrier half.
    I greased up the driver's side carrier half and installed it the same way it came off. Note the punch marks on each half (circled in yellow), which were made during dis***embly. An important step I am told...
    The last remaining parts are the driver's side axle and the ring gear ***embly.
    Those got greased up and went together nice and smoothly thanks to the quick hone job.
    Then that whole ***embly can be bolted to the p***enger side ***embly that is secured in the vice.
    Threw some washers on, applied some loc***e, and torqued them down.
    That's it for the axle ***embly. Next post will be ***embling the housings and shimming the quick change gears.
    kadillackid likes this.
  4. 19Fordy
    19Fordy
    Thanks for posting your QC experience. Looking forward to the rest.
  5. brsturges
    brsturges
    from Miami, FL
    On to the next step....
    Before final ***embly, I finally installed the axle seals. These are the seals at the ends of the banjo housings and they can be tricky to get seated correctly. I used a 3 foot length of allthread and a few sockets to build a little tool to press them in.
    The spacing is very important here. You can see my socket held up to the end of the allthread to check to make sure I will be able to dis***emble everything once it is pressed/pulled into place. The big socket on the right presses the red seal into place when pulled in with a nut on the end of the allthread shown in a few steps below. The black socket centers the ***embly nicely in the axle housing end. The allthread needs to stick out far enough to get on nut on it with a strong enough spacer (I used another socket) to take the load.
    The ***embly gets inserted in the axle housing. I did this with the axle standing up and elevated from the ground, but you can do this with it laying horizontal on the ground too. Probably would have been easier :rolleyes:
    If you measured correctly, you'll have some allthread sticking out the end of the housing.
    I then placed an appropriately sized socket over the allthread and tightened a nut to pull the seal into the housing. The vice grips on the other end ensure the allthread won't rotate.
    The axle seal is nicely in place without any damage. The picture makes it look uncentered but it is in fact centered perfectly.
    More to come...
  6. butch27
    butch27
    Great work a little more than I did on mine.
  7. brsturges
    brsturges
    from Miami, FL
    Thanks guys.
    The next step was prepping the center section. I changed my mind a bunch of times deciding whether to use studs and lock nuts (which came with the kit), studs and acorn nuts, or bolts to fasten the housings to the center section. I ended up deciding on studs and acorn nuts. That meant I needed shorter studs than what came with the kit. I got some set screws for the job. There are two holes on each side of the center section that go all the way through, so I used sealant on those to prevent any leaks.
    This next part is really where the engine stand comes in handy. I rotated the center section so that the p***enger side is facing up. Again, I decided against using any sealant and just greased the mating surfaces lightly.
    I installed the gaskets/shims for the p***enger side based on the test fitting discussed above.
    I greased the axle housing mating surface...
    And then torqued down the acorn nuts in a star pattern. The instructions said 25 foot pounds if memory serves...
    Then the center section can be rotated on the engine stand and the axle ***embly can be inserted as shown.
    Repeat the same steps for the driver's side taking care to use the correct gaskets/shims and torque it down.
    Once I ***embled it for the final time, I rechecked the carrier bearing preload and the backlash. All was good. The last step is shimming the helical quick change gears, which I'll cover in the next post.
    NoSurf, ottoman, teach'm and 2 others like this.
  8. brsturges
    brsturges
    from Miami, FL
    Sorry for the delay in wrapping up this build thread. Life got in the way a bit.
    Time to install the quick change gears and get them properly shimmed.
    When you opt for helical cut quick change gears, it is recommended that you use the shim kit to adjust the forward and aft play the gears have on their respective shafts. This is done with shims shown below.
    The shims come in .030, .045, and .060 thicknesses. The instructions that came with the set were straightforward, but did not address how exactly to measure the play.
    Before we start shimming, the spacer needs to be installed on the lower shaft. That's part number SR3417/SR3416 in the diagram above and shown in with the green arrow below. It's a tight fit so maybe heat it up a bit and be prepared to tap it home. A large socket or pipe is helpful here.
    I couldn't figure out the best way to measure for the right clearance. Bruce had a great suggestion, which was to over shim the gears, install the cover with the gasket (barely tightening down the cover) and use a feeler gauge to see how much gap you have. The first trick is getting the gap to be even from top and bottom. My clearances were slightly off when I used the same shims on both shafts. My top shaft needed a .060 and the bottom shaft needed a .045. That got me a uniform gap between the case and the cover. See the picture below of me using a feeler gauge.
    Some math is obviously involved here. If you have .025 of clearance between the case and the cover, you need to remove about .015 worth of shims. You are shooting for a clearance of .005 to .015.
    Once this setting is figured out, you can carefully torque down the cover and your quick change will be essentially all done. I still need to figure out how I will be venting mine, but for now, the project is complete. Hope this helped some of you get an overview of how this project goes. It was certainly a fun one and I am thrilled to have an early Ford style quick change rear set aside for my next project. Thanks for following along. And once again, thanks to @GearheadsQCE for selling a great product and providing even better technical support!
    Brad
    NoSurf, HemiDeuce and teach'm like this.
  9. soonrodder
    soonrodder
    from germany
    Awesome thread!
    This makes me buying my 3620, also.
    Mine was an open driveshaft, so I need some time to get the right parts to convert it to closed driveshaft, as yours was from the beginning.
    Now I will go thru your ***embly instructions.
    What was missing at my QC was the instructions- could you please send it to me or take it here via pdf?
    Thank you so much!
    Again, great job!
    Michael
    [​IMG][​IMG]
  10. chasmatik
    chasmatik
  11. chasmatik
    chasmatik
    great info on the clearancing of the ring gear bolts
  12. GuyW
    GuyW
    It looks like one would have to re-shim every time one changes gear ratio pairs
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    No, the gears are generally pretty consistent for thickness, especially from the same manufacturer. As far as I know, only Winters is currently making helical 6 spline gears. No need to shim straight cut gears, but it doesn't hurt.
    GuyW likes this.
  14. Pewsplace
    Pewsplace
    Good article! I found that by the time you get all done, purchasing the Winters tapered tube completely ***embled is the way to go. Just my opinion.
    HemiDeuce likes this.
  15. Frames
    Frames
    I used 35 axle housings. 35-41 same width. Your axle housings are 42-4 2014-07-17 15.32.24.jpg 8. 2" wider. I used 4 1/2 " back space wheels to tuck the tires in close to the body.
    GuyW likes this.
  16. steve hackel
    steve hackel
    After reading through this several times, my question is regarding a complete new Winters quick change rear end with the bells installed. Speedway lists the available axle bolt patterns at 5 x 4-1/2 & 5 x 4-3/4
    but is it possible to get axles with the standard 5 x 5-1/2 bolt pattern? It's a great product in itself, but I would hate to loose me bent spoke Kelsey Hayes wire wheels and new tires just to trade up to a new quick change rear end with the wrong bolt pattern. Just might be stuck with the older bells & axles in order to use Lincoln brakes with a 5 x 5-1/2 pattern.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Steve,
    It is definitely possible to get the Winters rear with the 5 on 5 1/2" bolt circle. I special order these all the time, and have them drop shipped directly to my customers. I don't know if Speedway does special orders.
    To incorporate the Lincoln brakes, the housing ends need to be replaced with ones that use the early Ford bolt pattern. There are a couple of ways to accomplish this. You can either use Ford V8 axle trumpets or cut the ends off the Winters housings.
    I'll send you a PM with my phone number and we can discuss the particulars.
    And to all that are reading this, remember that Alliance Members get a 10% discount. That's probably enough to cover your Alliance Membership and the shipping. Spend your stimulus $ with small businesses. You can't get any smaller than Gearhead's Quickchange Exchange.
    Bruce
  18. brsturges
    brsturges
    from Miami, FL
    Budget36 likes this.
  19. irishjig13
    irishjig13
    This is a great article from start to finish. I am pretty new to this era of Fords. I recently acquired a 1930 Model A with a Flathead V8, original 3 speed top loader and banjo rear-end. I would like to upgrade to a QC rear end and am looking for a Borg Warner T5 to mate up to it as well.
    Model A.jpg If anyone happens to read this and knows where a T5 can be found I would love to hear from you.
    I just contacted brsturges regarding his QC for sale. If that doesn't materialize I will definitely be contacting GearheadsQCE for advice and selection. Thank you all, Kevin
    treb11 likes this.
  20. Budget36
    Budget36
    Sorry to hear that. I checked out your ad, damned nice price. Wish I had a need for it! I suspect you’ll have a quick sale. Good luck!
  21. seb fontana
    seb fontana
    from ct
    I f there is .025 feeler needed then isn't .035 of gear shim need to be removed to get .010 clearence? Also just a note that the set screws used as studs maybe too brittle and snap [over time] but at 25# may not be a worry. I learned this at work as we used them for clamping and some would just give up over night.
  22. brsturges
    brsturges
    from Miami, FL
    It has been a while, and my math may have been wrong. Alternatively, I may not have explained that the gasket needs to get taken into consideration. Can’t recall the thickness of the gasket offhand but that may make up the difference.
  23. italianhotrodder
    italianhotrodder
    from sweden
    wich rustoleum did you use? thanks great post
  24. Rehpotsirhcj
    Rehpotsirhcj
    Bumping this old thread because it’s so damn informative. Big thanks to @brsturges
    RICH B and italianhotrodder like this.
  25. Royalshifter
    Royalshifter
    Moderator
    One of the many great HAMB how to threads.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I sorta compromised by also using a nine inch Ford rear - but I grafted on a QC center section, since nothing looks ***ier than a QC. Believe me I caught a lot of flack from GearheadsQCE. (RIP Bruce.)
    This way I have the look of the QC but the advantages of the common, cheaper, stronger niner.
  27. dirt car
    dirt car
    from nebraska
    I've seen the side nerf bars attached to the radius rods on several back in the day builds as opposed to frame rail mounts & it apparently works, like the 'Throw Back" to the oval track racing motif & granted it would limit the wheel hop & cut tires ***ociated with close track compe***ion, however of the opinion a side impact could render the car out of the race were the rear ****ed enough to induce dog tracking, necessitating a quick trip to the pits to get things back in alignment. Definity like your true race application look & we can safely ***ume the days of old oval track racing would be of little concern on our street driven creations.
    GuyW and THE FRENCHTOWN FLYER like this.
  28. brsturges
    brsturges
    from Miami, FL
    Glad this thread has been helpful. Just wanted to do my part to contribute to the many helpful threads here on the HAMB. If I can do it, anyone can!
    Rehpotsirhcj and Budget36 like this.
