Technical 1956 354 Hemi Pistons Size
Discussion in 'Traditional Hot Rods' started by Bambamshere, Jan 20, 2021.
  1. Bambamshere
    Bambamshere
    Beanscoot and Hnstray like this.
  2. Bambamshere
    Bambamshere
    I will get a couple pics of my heads at some point this weekend ornext week. They are definitely truck heads. I bought a original 4 barrel manifold for it before I had the engine but I guess it won't work because the cross overs on the heads are to tall. Unless there is a gasket for that. Forum 4.jpg
    RONNY SCHRÖDER likes this.
  3. greybeard360
    greybeard360
    A 30 second web search turned up....
    1957 Fargo truck 354
    VT 549 ***** C ...... C denotes Canada
  4. Bambamshere
    Bambamshere
    A faster look would have taken you to about 10 posts up where it say 1956 354. Could have been 1957 lol
  5. willys36
    willys36
    I am going to try to adapt truck heads to my 331/354 to replace the stock small round exhaust ports, small valve heads.
    Braze filler plates in the heat X-overs to make them fit the p***enger manifold, new valves and valve guides, grind off the ugliness. Like I said, they otherwise look like hi-po heads.
  6. Bambamshere
    Bambamshere
    I have 2 sets of truck heads. I will take pic of both heads and post. There is a thick layer of white stuff on top of the exhaust valves.
  7. TRENDZ
    TRENDZ
    You have the ultimate “score” engine for a performance build. The truck/ industrial heads have great potential for power, and the block is ( in my opinion) the most desirable of all the early hemis.
    Should you decide to swap heads for p***enger car versions, pm me and I’ll scoop em up.
    Bambamshere likes this.
  8. George
    George
    Hot Heads makes in intake that covers the high cross over.
    gimpyshotrods and Bambamshere like this.
  9. George
    George
    Basically truck blocks are the same as the '54 car blocks.
  10. Bambamshere
    Bambamshere
    I think they only make one that is a single 4 barrel. One thing I do like about both truck blocks I got. Is the both came with 4 bolt exhaust manifolds and not the 2.
  11. stillrunners
    stillrunners
    from dallas
    And the 1956 D500 was no slouch either with the records it set.
  12. willys36
    willys36
    tetraethyl lead.
  13. RichFox
    RichFox
    I filled the exhaust cross over on several race heads with aluminum/ Fills in the connection between the two center ports in each head as well. It's easy to do at home. If anyone wants info PM me.
  14. Bambamshere
    Bambamshere
    Just incase some one doesn't know what that is lol
    Tetraethyllead, abbreviated TEL, is an organolead compound with the formula (CH₃CH₂)₄Pb. It is a petro-fuel additive, first being mixed with gasoline beginning in the 1920s as a patented octane rating booster that allowed engine compression to be raised substantially.
    Sent from my SM-G965W using Tapatalk
    dirt t likes this.
  15. TRENDZ
    TRENDZ
    Yes. Truck block is the same. Im referring to the 354 block. Big bore, short deck, small diameter bearings. Rather have a 354 than a 331, or a 392.
    stillrunners likes this.
  16. TRENDZ
    TRENDZ
    That does work nice for heads with a heat cross over. The heads shown don’t have heat cross overs. Those are coolant p***ages.
  17. RichFox
    RichFox
    What do I know? We don't have water p***ages. They are for sissys. upload_2021-1-22_7-57-18.jpeg
  18. TRENDZ
    TRENDZ
    Yep, water probably would give you issues on that monster.
  19. TRENDZ
    TRENDZ
    My lawnmower doesn’t have coolant either. Im a half sissy.
    Didn’t mean to get you sore, just wanted to put out true info on the topic.
    I ***ume that is alcohol powered? Cant believe you can make all that power for sustained amounts of time.
  20. RichFox
    RichFox
    nitro. and alcohol. It's not mine. Many people have put time and money into it. I bought the crankshaft. Several of the faster cars are using dry blocks and heads. Old Top Fuel parts. Flashpoint is no longer competing. Did run 451 exit speed just before this. Owner/driver, Bob Dalton walked away. upload_2021-1-22_9-16-39.jpeg
  21. Bambamshere
    Bambamshere
    That would have been a wild ride
  22. Bambamshere
    Bambamshere
    OMG your lawnmower doesn't have coolant. I wouldn't say half sissy. I believe that's at least 2/3rds lol
  23. Bambamshere
    Bambamshere
    I will be a sissy since 6 months out of the year it is below -20*c here lol.
    Just joking around
  24. 73RR
    73RR
    It appears that you have.....
    two 354 truck engines. (truck blocks will be drilled at the front for the 51-54 331 front cover)
    truck heads (as mentioned, a good casting and easy enough to fix the tall port and use oem intake)
    After you mic the bore you'll know what you have in terms of pistons, however, truck c/r is usually in the 7:1 range. Custom forgings are readily available for what ever you need and not alot more money than castings which seem to be stuck below 9:1.
    Some truck engines have thicker/taller rear main caps and use the 392 intermediate drive shaft.
    Some truck engines use gear drive for the cam so the cam runs in reverse. Some of the big cam companies ocasionally have new cores. Call them for availability.
    The LA timing chain set interchanges on a new p*** car cam.
    All of this is buried in in the Hemi Tech pages but you still need to take the time to start reading.
  25. Bambamshere
    Bambamshere
    Ok so what does MIC the bore mean?
  26. jaracer
    jaracer
    Measure the inside diameter of the bore with an inside micrometer. Be sure to measure it just below the upper limit of ring travel since that's where the most wear will be.
  27. 73RR
    73RR
    ^^^^^what he says.
  28. Budget36
    Budget36
    Easy way to see if they are oversized, is just use the inside “tongs” on a micrometer. This way you’ll be measuring where the top of the bore is at w/o wear. If you don’t want to spend money on a bore mic, use a ring off the piston once you have it apart ( or source a ring if not taking it apart) then put the ring at the very top of the hole, use feeler gauges and check the gap. Then, with the piston at BDC, slide the ring down and measure the gap again, this will give you a good idea of the bore taper.
    Main thing doing it this way, you really want to use a piston to push the ring down in the bore to keep it correct for measurements.
    That’s how we po foke did it ;)
  29. Bambamshere
    Bambamshere
  30. willys36
    willys36
    Definitely a truck head.
