The Flaven & Flaven Model A build.
Discussion in 'Traditional Hot Rods' started by Pete, Nov 23, 2014.
  1. Pete
    Pete
    Stripped bare and off to the blaster.
    Once it’s back we’re gonna fully box it, add some gussets and plate between the k member.
  2. Saw some of the progress on Instagram. Looks killer. Think it will be ready by September/October? You guys gonna come down again for the show?
    -chris
  3. Pete
    Pete
    I’d love to do the old north state invitational again! We had a great time
    biggeorge and MayDay like this.
  4. WC Durant
    WC Durant
    Is it back from the blaster?
  5. Pete
    Pete
    Its been while.....
    Heres a few update pics. Frame was blasted than a brush coat of POR was sloshed on the inside of the rails before boxing them.
    I added a bunch of reinforcement gussets, boxed the frame the full length, welded up a bunch of holes that were not going to be used, did a quick mud coat from the firewall forward area of the frame. Because its a roadster I thought the frame should have a good amount of stiffness.
    IMG_2944.jpg IMG_2945.jpg IMG_2946.jpg IMG_2947.jpg IMG_2948.jpg IMG_2949.jpg IMG_2950.jpg
    Stogy, alfin32, loudbang and 6 others like this.
  6. Pete
    Pete
    I blocked out the frame, sprayed a heavy coat of sealer than a few coats of filler primer, quick bock sand and three coast of single stage black.
    The frame is back at mikes garage, its rolling, brakes are plumbed, motors in.....body on, shouldn't be long.
  7. Very cool
    Stogy and loudbang like this.
  8. Pete, I always like the builds that you do. Great work keep the updates coming.
  9. Pete
    Pete
    Thanks Ron.
    The rest is up to Mike, I’m sure he can handle the ***embly
    Stogy, loudbang and chryslerfan55 like this.
  10. That green is over the top!
  11. OFT
    OFT
    Boy-O- Boy, things are getting exciting aren't they!! Looks real good!!
  12. Pete
    Pete
    Mike got the motor and trans mated, dropped it in, got the rear end and driveshaft attached. FBE1B216-AC02-4DCF-B213-CFD30135C99E.jpeg E3BBBFB2-2C12-43E6-8F42-C5E731B3F95D.jpeg FBE1B216-AC02-4DCF-B213-CFD30135C99E.jpeg E3BBBFB2-2C12-43E6-8F42-C5E731B3F95D.jpeg
  13. Pete
    Pete
    Then the body mounting blocks,,,,and the body.
    920B70B8-B263-42B3-AAD5-2B29AA58EEF4.jpeg D482E809-B07E-4DA8-B069-6209A29560C3.jpeg 21221002-665E-4EB4-8B3F-0D625477B44C.jpeg AEE06D21-B985-417A-AA79-6BD78A74FE4D.jpeg
  14. Pete
    Pete
    More pics of the grill, radiator and hood.
    8C208B1F-FBEA-4E1B-996B-A073AF51C2EF.jpeg 424BFB34-55CB-48B5-9E3C-044E194C71E7.jpeg
  15. 210superair
    210superair
    from Michigan
    That flattie looks absolutely beautiful.
  16. OFT
    OFT
    The entire package is out of the park!! Great looking!!!
  17. wheeldog57
    wheeldog57
  18. kidcampbell71
    kidcampbell71
    - 2 thumbs up, from Ho Lee Fok !!!!
  19. Pete
    Pete
  20. neds29
    neds29
  21. fegsta
    fegsta
    I'll be showing my grandson this, very inspiring. We've got are eyes on a body ch***is roller. No engine or box or drivers door but looks a nice start. My grandson is 13 so he would be just about be able to drive by the time its built. Thanks for the grate photos.
    Sent from my KOB-L09 using The H.A.M.B. mobile app
  22. 210superair
    210superair
    from Michigan
    Mikel50, triumph 1 and kidcampbell71 like this.
  23. Kirky
    Kirky
    fegsta, loudbang and triumph 1 like this.
  24. custom_lettering
    custom_lettering
    from Wall, NJ
    UPDATE: I am now the owner of this really nicely built roadster. I'm putting my Merc back together after paint and then I'll start working on the roadster. There's a long list of projects that need to be done on it but other than designing and fabricating a clutch linkage and a steering box rebuild there's nothing to big. Can't wait to fire up this new flatty, my neighborhood has been too quiet.
  25. brady1929
    brady1929
    Congratulations. That roadster is *****in.
    mad mikey likes this.
  26. sloppy jalopies
    sloppy jalopies
  27. DaveyJonez
    DaveyJonez
    from Houston
    Really Really Nice!!
  28. mad mikey
    mad mikey
    Great. Don't be a stranger, post up if you have time.:D
