Hot Rods 215 aluminum Buick
Discussion in 'The Hokey Ass Message Board' started by trvguy, Jan 22, 2021.
  1. trvguy
    trvguy
    I have a 215 out of a boat. wondering if its reverse rotation.
    If it is, can it be changed to be used in a car.
  2. pprather
    pprather
    I'd start by taking a clear photo of the timing marks on the harmonic balancer. From that we should be able to determine the rotation of your engine.
    ClayMart and Hnstray like this.
  3. trvguy
    trvguy
    I have get to the shop tomorrow.
    I'll get a picture then. Is there any numbers to look for? casting #'s?
  4. oldiron 440
    oldiron 440
    Unless it came from a twin it will be a standard rotation and if from a twin I still have my doubts that it it would be a reverse rotation.
  5. Ebbsspeed
    Ebbsspeed
    If on the off chance that it IS reverse rotation you can put an automotive cam in it, and it may require a different distributor gear to match the cam. Then there is the issue of the angled serrations on the crankshaft that are under the rope seal which are intended to pull oil towards the inside of the engine. On a reverse rotation engine these serrations will be angled in the wrong direction and tend to push oil out of the rear main rather than pulling it in if the engine is switched to standard rotation.
    What type of boat had a 215 Buick motor in it?
  6. mike in tucson
    mike in tucson
    from Tucson
    Hit the starter with 12V and watch the rotation direction
  7. 24riverview
    24riverview
    My in laws 1964 (I think) Marinette cabin cruiser. Haven't worked on it for years but if I remember correctly one was reverse rotation. Believe they were marketed originally by Gray Marine.
    bchctybob, Fabulous50's, rod1 and 3 others like this.
  8. oldolds
    oldolds
    Fresh water or salt? You are in the middle of the country. I suspect fresh water. Salt water I would be afraid to touch them.
    seb fontana likes this.
  9. lake_harley
    lake_harley
    ^^^^^24riverview...I'm a fan of the little aluminum 215's. I wouldn't care which way they rotated if that boat was being parted out.
    Lynn
    kidcampbell71 likes this.
  10. 24riverview
    24riverview
    May be years but if it comes to that I'll keep you in mind.
    lake_harley likes this.
  11. oldiron 440
    oldiron 440
    What would be different from a standard to a reverse rotation other than the cam and starter?
  12. seb fontana
    seb fontana
    from ct
    Some engines use a gear drive [in place of chain] to reverse engine, cam stays in standard rotation keeping stock oil pump and dist. Only crank goes reverse, ign timing goes opposite side TDC and and reverse operating starter.
    bchctybob, ekimneirbo and Hnstray like this.
  13. trvguy
    trvguy
  14. trvguy
    trvguy
    I pulled the engine few years ago. wood boat. single engine.
    can't remember the brand of the boat.
  15. trvguy
    trvguy
  16. warhorseracing
    warhorseracing
    from cameron wv
    Will the salt water attack the aluminum like it does cast?
  17. Ebbsspeed
    Ebbsspeed
    The serrations on the crank at the rear main rope seal would be slanted the other direction.
    It'll rot the aluminum in one fourth of the time that it does the cast iron. Even in fresh water the aluminum will be subject to rapid corrosion. I suspect that most of the 215 motors that were used in boats had a closed cooling system with a heat exchanger.
    Hnstray likes this.
  18. warhorseracing
    warhorseracing
    from cameron wv
    Did not know that. You would thing that it probably would not attack the aluminum. Learned something else today. Thank you Sir.
  19. pprather
    pprather
    Since it came from a single engine boat it probably is standard rotation.
    Did a get a photo of the timing marks?
  20. 61SuperMonza
    61SuperMonza
    I think the 215 is a cool engine. I have thought about a new Corvair build with this engine. It would be mounted in the rear as well. I would need to figure out the transaxle but I don't think it would be to much trouble.
    I would need a reverse rotation engine in this application.
    The biggest issue is the lack of performance parts for this motor. In a Corvair it wouldn't need to be big HP for a spirited ride. I'm thinking supercharger on this one.
  21. lippy
    lippy
    from Ks
    Why would one be reverse rotation if they are side by side? Lippy
  22. Ebbsspeed
    Ebbsspeed
    If you do begin this endeavor consider using the Oldsmobile variant of the 215. It had 6 head bolts around the perimeter of each cylinder, vs 5 on the Buick. Much better suited to forced induction and the resulting cylinder pressures.
    The Buick valvetrain precludes the use of that 6th fastener as the rocker shaft stands are in the way.
    Propellers in twin-engine boats are set to turn in opposite directions so that the torque created by each balances the other out. If both propellers turned in the same direction, you would feel it at the steering wheel--you would have to counter the torque by steering constantly in the same direction.
    61SuperMonza likes this.
  23. 61SuperMonza
    61SuperMonza
  24. 61SuperMonza
    61SuperMonza
    The same thing is done with many twin engine aircraft that use reciprocating engines.
    This can be critical if you have an engine out situation.
  25. trvguy
    trvguy
    I didn't get a picture of the timing marks but, its on the p***enger side of the engine with
    three lines and two "0's".
  26. Rusty O'Toole
    Rusty O'Toole
    Reverse rotation 215 would be perfect for a Corvair. They had a reverse rotation engine to begin with. There is an adapter to put it on the Corvair transaxle. Transdapt makes them or used to.
    mineseats9 likes this.
  27. rfraze
    rfraze
    Here are the adapters to a Corvair transaxle. This is a Parker (I think) CorV8 unbolted from a 215 Buick. The flexplate adapter must center the converter. It had an Isky 282 Rev Rotation cam, reverse cut distributor drive gear, and Regular size starter (reverse rotation, probably)
  28. rfraze
    rfraze
    Here is the Reverse rotation 215 Buick cam. End says Iskenderian 282. Distributor drive gear is angled opposite a regular distributor drive. IMG_2697.JPG IMG_2709.JPG IMG_2711.JPG
  29. drtrcrV-8
    drtrcrV-8
    As far as updates on the Buick 215 : GM sold this motor to Rover & they used & modified it for a long time, so there is a source for more modern & larger versions in your local wrecking yards...
    SS327 likes this.
  30. brading
    brading
