Projects I'm 18 and building my first flathead 59AB+merc crank for my chopped 34 4 door sedan
Discussion in 'Traditional Hot Rods' started by Jesse Borba, Nov 20, 2020.
  1. tubman
    tubman
    To be clear; all late ('49-'53) rods are the same dimension. The longer stroke Mercury used pistons with a different pin height.
    Jesse Borba likes this.
  2. banjorear
    banjorear
    I bought my Ross pistons with Total Seal metric rings last fall. Cost was $670 with everything shipped.
    chryslerfan55 and Jesse Borba like this.
  3. Budget36
    Budget36
    One other thing, as mentioned before, you really need to find a flat head place that knows how to set up the full floating bearings. The inserts are kind of a given. That said, an old timer I knew years ago said for higher spinning FH’s, he’d only use the floating bearings.
    Hopefully someone can chime in with knowledge about it.
  4. Jesse Borba
    Jesse Borba
    That's really interesting if anyone has any information to back that would be helpful.
    Sent from my SM-J727V using The H.A.M.B. mobile app
  5. Budget36
    Budget36
    @tubman may be able offer info. I’ve no experience
  6. banjorear
    banjorear
    Ok, regarding full floating bearings. Yes, in a mechanical sense, they provide the best protection since the bearing is floating is two layers of oil. One between the crank and the inner shell and another between the outer shell and the con rod.
    These were used early on by racers since it was the technology they knew and bearings were readily available.
    Unless you plan to do all out, high RPM racing, I don't think there is a need, but I would defer to the experts.
    I believe Ronnie Roadster, one of the top flathead builders & racers out there, uses insert bearings in all of his stuff. (Ronnie, please correct me if I'm wrong). If that is the case, if they are good enough for his 200+ mph all out state of the art flatheads, they are good enough for the rest of us.
    I would also start a thread over on Fordbarn.com. Guys like Ol' Ron, Bored & Stroked and cam grinder Pete (another West Coast all out race engine builder) will jump in. I remember Ol' Ron saying the New England area guys use to run their floater bearing tolerances loose to help them wind a little higher. I think even Ol' Ron has switched over to insert bearings. Not sure about Dale (Bored & Stroked).
    This is my best advise: Flatheads suffer from some of the worst bench racing in the business. Find a trusted flathead guy and listen to them. It will save you time and money vs. chasing internet rumors, out of touch magazine articles. or plain old snake oil.
    California is full of tried and true flathead guys. Ask around and do your homework. Believe it or not, a great place to start is your local Early V8 club.
    Good luck and let us know how your making out and keep asking questions.
  7. tubman
    tubman
    I couldn't have said it better. Remember, we're talking engines for street use here.
  8. Jesse Borba
    Jesse Borba
    Ok thank you for the information I'll set up a thread on the ford barn.
  9. Jesse Borba
    Jesse Borba
    Does anyone have any clue what a 59 D block is? I thought some of you might know something about this because I can't seem to find any information online. 1611167211323.jpeg
  10. alchemy
    alchemy
    I've never seen a D block. I have seen Z, X, Y, L and regular 59 blocks, but a D is new to me.
  11. banjorear
    banjorear
    Me too. Hard to tell from the pict, but it looks like there is a hog's head attached to it as well. Maybe some type of truck or industrial application?
  12. Jesse Borba
    Jesse Borba
    I just read that someone pulled one out of a general electric welder. I can take a better picture what exactly is a hog's head?
  13. alchemy
    alchemy
    A hogshead is what the guys call the short bellhousing that connects a pre-49 block to the separate truck transmission housing. Basically looks like the big end of a '39 transmission with the gearhousing machined off and some holes drilled into it. Very useful to use to adapt any newer transmission to a flathead. Just need a talented machinist to whittle up a plate with the two different bolt patterns on it.
  14. Jesse Borba
    Jesse Borba
    Oh, it does have a 39 trans bolted to it I forgot to say that, my bad.
  15. alchemy
    alchemy
    There is a guy selling what he calls a hogshead in the cl***ifieds. It is not, he has an F-1 pickup bellhousing ring to adapt to the p***enger-style transmission which was also used in the smaller pickups. Just so's you don't get confused.
    https://www.jalopyjournal.com/forum/threads/hogshead.1218469/
  16. Budget36
    Budget36
    For somewhat local suggestions for FH shop, @roseville carl has a FH powered FED. He might know something in the area. Yosemite Machine Shop in Modesto was a place many used to go to as well, but I don’t know over the past 30 years if they are still good with them.
    All the other places I knew of from years ago have closed down now.
  17. Jesse Borba
    Jesse Borba
    Dropped the pan on the complete 8ba I picked up. A few pieces of rat **** and metal dropped out with it. I don't know what happened but 2 rods snapped and the cam has completely disintegrated and now it looks like a dog turd. Welp there's a few good parts on the top of it, and my dad and I got a good laugh. Don't think it's worth the PB blaster to free it up.[emoji23] 1611355198085.jpeg 1611355254955.jpeg
  18. alchemy
    alchemy
    If the block might be good it’s worth saving. See any cracks from the carnage?
    warhorseracing and Jesse Borba like this.
  19. Jesse Borba
    Jesse Borba
    I didn't get a chance to check it out really I'll look at it more when I get a chance I've been busy clearing out an area in the upper barn on my property so I have a place to store and organize my stuff I've been getting.
    chryslerfan55 and brEad like this.
  20. ronnieroadster
    ronnieroadster
    To add some info about the full floating bearings here's some info. The crankshafts used in the 1948 and earlier flatheads are different in the way the rod bearings receive oil. These early crankshaft rod journals have only one oil hole located in the center of the journal. This design requires using only full floating rod bearings. In old days {the last century} full floating bearing's was the choice for completion engine's. But this is the 21st century so much has changed especially when it comes to flatheads.
    The cost of the full floating bearing's is easily double that of insert bearings and for some of the early floaters the ones with lips pre 1939 those 2 inch diameter rod journal bearings can be even more than double. Adding to the full floater expense is the added cost to rebuild the connecting rods remember the floater bearing is rotating in the rod so this diameter must be a precision bore. This adds considerably to the cost when rebuilding the connecting rod.
    I can say from experience the Ford flathead 8BA connecting rods are strong they can easily handle 300 horsepower. Also all of the available after market connecting rods those being the H beam design while being off shore made can handle more that the 8BA rods. And then there's the USA made connecting rods the type serious all out flathead racers like myself use they can easily handle well over 700 HP.
    So in the end I feel full floaters are good for restorations if needed other than that save your money and use the Ford 8BA connecting rods your wallet will be happy you did.
    Ronnieroadster
    chryslerfan55, Tman, brEad and 2 others like this.
  21. Jesse Borba
    Jesse Borba
    Thank you for the great information!
  22. roseville carl
    roseville carl
    if your block is ok I should have most parts to get ya running give me a call when ya get a chance sent ya a pm.......
    harpo1313, brEad and Jesse Borba like this.
  23. Elrod
    Elrod
    Have you looked inside of this yet?
  24. Jesse Borba
    Jesse Borba
    I have not it's a put together running motor that I can't take apart right now.
  25. banjorear
    banjorear
    Wait, the motor is running currently? If it doesn't smoke, spit water out and starts right up, don't touch it. Trust me on this.
    If you must, put some dress up goodies on it. Get the car on the road and you can rebuild the motor later. Having a running motor is a very good motivator to get your project done.
    warhorseracing and chryslerfan55 like this.
  26. Jesse Borba
    Jesse Borba
    It's not the same motor from what I'm building it is not mine to mess with I was just interested if anyone has any information on 59 d blocks.
  27. 8 years or more
    8 years or more
    Enjoying the thread, I didn't see it but do your self a favor and get a nice tap set and thread restorer set (like taps but not as aggressive) also, anyone can take it apart and ruin it, I think someone said earlier, patience; lots of patience.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  28. Jesse Borba
    Jesse Borba
    Ok I'll look into it!
  29. Dick Stevens
    Dick Stevens
    They are called thread chasers!
  30. banjorear
    banjorear
    Jesse Borba and chryslerfan55 like this.
