Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. guthriesmith
    guthriesmith
    Love that 56!
  2. gimpyshotrods
    gimpyshotrods
    I stopped using the dead-blow hammer.
    It was overdriving.
    Switched to a 3lb one, and a block, and finished right up.
    TrailerTrashToo and Blues4U like this.
  3. Clik
    Clik
    Worked on my step van which doubles as our Split Shifters Car Club Halloween Trunk-or-Treat rig and Run Truck.
  4. Clik
    Clik
  5. Clik
    Clik
  6. Greg Rogers
    Greg Rogers
    Wow! Thats quite a step van!
    Clik likes this.
  7. Blues4U
    Blues4U
    from So Cal
  8. olds vroom
    olds vroom
    Just waiting impatiently for the ups guy to bring my rebuild kit so I can get my engine back together.
    Lil32 likes this.
  9. saltflats
    saltflats
    from Missouri
    Finally got the 36 out of the shop after the first test drive had a fuel pump failure. New pump installed runs good. Customer drove off wishing I would take another one of his car in for repair, had to say no as I am trying to get moved out of this place.
  10. hotrodjack33
    hotrodjack33
  11. Stock Racer
    Stock Racer
    Resurrecting a busted up Muncie 4-speed purchased from a HAMBer. IMG_2520.jpg IMG_2526.jpg
  12. jimmy six
    jimmy six
    Removed the roadster out of the trailer from last Octobers El Mirage. Loaded up the car trailer with the 2 mini bikes and Rupp Dart Kart I restored.
    Put the roadster in the air and added another 4’ light to the outside work area. Busy day.. Now I can work anytime. D9A5A7BB-A027-4CC9-86D4-139A92B1C736.jpeg
  13. Marty Strode
    Marty Strode
    Got my traffic light on a pole, now I can tell when to stop working. IMG_6241.JPG
  14. SEAAIRE354
    SEAAIRE354
    Finally got this in the shop and got it running after sitting for 30 plus years. Then wondered what it would look like with a Hemi. A boy can dream can’t he. IMG_2535.JPG
  15. Fabulous50's
    Fabulous50's
    from Maine
    20210123_182600.jpg 20210123_184158.jpg 20210123_182627.jpg Figured I'd let the FE get rid of some asthma while its snowing.
  16. jimmy six
    jimmy six
    Expensive but I like the stepped 2 bolt clamps. Used them on my OT F150 and dirt track car. Bought them all from Summit. Only time I cut and weld is over the rear axle. If you can use a plumbers pipe cutter its better than a hack saw. It will leave the cut slightly flared in. The joining pipe I flare out with a ball peen hammer and need very little filler rod when welding together. Good luck,
    y'sguy and Fabulous50's like this.
  17. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Tried to bury one of the old parts cars. I did not dig the hole deep enough. o_O I will try again tomorrow. 1F4D3D54-8538-4E76-BF7C-DEB17AFF4F49_1_105_c.jpeg
  18. Marty Strode
    Marty Strode
    Lately, I have been taking Sundays to organize and improve my shop. So I punched and formed a holder for the live centers, and other tooling that goes in the tail stock of the lathe. The back splash made for the perfect location. Now to tackle the files, and de-burring tools on the other end. IMG_6280.JPG IMG_6281.JPG IMG_6285.JPG IMG_6288.JPG
  19. junkyardjeff
    junkyardjeff
    Picked up a 292 Y block out of a 64 F100 for parts,I got it for the PCV system,distributor and truck timing chain cover and rear sump oil pan plus it has a manual choke 2 bbl carb.
  20. embyman68
    embyman68
    Summer turned into a 6 month pause after painting my frame and rear end. I've spent the last couple weeks prepping and painting parts and starting to****emble the chassis for my 26 tudor. 20201230_222748.jpeg 20201231_122556.jpeg 20210101_164028.jpeg 20210113_210930.jpeg 20210116_143439.jpeg 20210118_194853.jpeg 20210118_100247.jpeg 20210118_163709.jpeg 20210118_163726.jpeg 20210118_220342.jpeg 20210119_213102.jpeg 20210119_213227.jpeg 20210123_195900.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
  21. j hansen
    j hansen
    Good job .....and many pics!
    stanlow69 likes this.
  22. chevy3755
    chevy3755
    thanks for NOT cutting the rear fender wheel wells....
  23. Marty Strode
    Marty Strode
    Tastefully done my friend !
    65pacecar and embyman68 like this.
  24. rob-redm
    rob-redm
    deck stay.jpg Helped my buddy put the windshield frame on his 1946 Chris- Craft Custom..
    it's cool... can be folded down on to the deck.. with special hardware to hold them
    away .. 46 chris.jpg sorry not car related .. was fun !
  25. 57 Fargo
    57 Fargo
    Scoured the internet and reached out to some contacts in search of a dual quad intake for a Chrysler B engine. So far no luck...
    GlassThamesDoug likes this.
  26. RICH B
    RICH B
    Dug the hood out of the shed, hauled it up to the garage, put in place, and hooked up the hinges. Even kinda fit; have to get it adjusted a little better and then back to the grille. It is a new '42 hood out of Little Dearborn.
    IMG_20210120_134002_3 (Medium).jpg IMG_20210125_144726_3 (Medium).jpg IMG_20210125_144913_3 (Medium).jpg
  27. Rocky
    Rocky
    Classified Editor
    Hahaha, John, that's hilarious! I tried to do the same thing in my front yard with a cut-off top for a 50 Mercury and my wife threw a hissy fit [whatever a hissy fit is] and told me the neighbors already thought I was a junk collector. It would have appeared a Merc was buried in my yard.
    BTW, I spent the day shoveling and blowing snow...yech
  28. embyman68
    embyman68
    Built a cart to carry my 120v. mig and my new 120v./240v. tig machine. 20201224_125325.jpeg 20201223_164428.jpeg 20201224_132656.jpeg 20201224_133354.jpeg 20201224_132642.jpeg
  29. lake_harley
    lake_harley
    I bought a 241 Dodge Hemi a few weeks ago and finally had a chance today to start taking it apart to see how good or bad it is. Got as far as getting the heads off and so far am pleasantly surprised at the relatively good condition of the cylinders and the heads. Unfortunately, the crank still won't turn so tomorrow I'll get it on a proper engine stand and take apart the bottom end. I hope I don't find anything to bad that might be keeping it from turning. Fingers crossed....
    Lynn
    LAROKE and RICH B like this.
