Hot Rods CAMSHAFT GRINDER FOR DAIMLER CAM
Discussion in 'The Hokey Ass Message Board' started by Motorvator, Jan 24, 2021.
  1. Motorvator
    Motorvator
    i'm having trouble finding somebody to grind my daimler v8 cam, tried comp cams and a couple others ,i don't think they have any spec's on a daimler engine as its furun. anyone got any idea's ? otherwise i have to buy a billet cam from England $$$$$$$$$$,$$$$,$$
  2. Greg in Jax
    Greg in Jax
    Recommend Crane Cams. Give them a call, they have done Brit cams for many years. Bet that they have the specs.
  3. Have you checked with Schneider cams ?
    They are out there not far from where you live .
    Tommy
  4. Motorvator
    Motorvator
  5. 73RR
    73RR
    Yup, Jerry Schneider.
    Desoto291Hemi likes this.
  6. deucemac
    deucemac
    My thoughts exactly. Ask to talk to Jerry Cantrell, if anybody knows he will.
    619 297-0227
  7. mgtstumpy
    mgtstumpy
    Engine camshaft all Range Rover Cl***ic & Discovery Ser1 3.5 & early 3.9 engines genuine part number ETC6850L fits models with V belt drive (imperial cam). Lots of Rover/Buick V8 performance groups and parts in UK. It appears that there were some variations specific to capacities over time, 3.5, 3.9, 4.2 & 4.6.
    https://www.trspares.com.au/shop-on...8/camshaft-discovery-v8-3-5-3-9-etc6850l.html
    OEM Cam specs ETC6850: INLET OPENS: 30 BTDC, CLOSES 75 ABDC, DUR 285, VALVE PEAK 112.5 ATDC. EXHAUST OPENS 68 BBDC, CLOSES 37 ATDC, DUR 285, VALVE PEAK 105.5 BTDC
    http://www.mez.co.uk/tuningtheroverv8-pt8-new.html
    Maximum valve lift that a standard engine can take is 0.44". Any more than this requires modification of the valve guides as a minimum. .... I can't locate anything specific on OEM lift, maybe an email to the UK?
