Hot Rods Cad 390 Build
Discussion in 'The Hokey Ass Message Board' started by lumpy 63, Jan 24, 2021.
  1. lumpy 63
    lumpy 63
    Building a vintage Cadillac engine was kinda a bucket list for me. No real reason, just something I wanted to do. Bought a core 61 390 with a trans that I didn't want but the seller wouldn't separate. Which in the end turned out to be a bad deal. Here is a picture of what I started with. 24833.jpeg
  2. lumpy 63
    lumpy 63
    Now to show you the bad part of this deal. Not only was the block already .060 over but some a-hole in the past apparently broke the corner off and JB Welded it back on. 24837.jpeg 24838.jpeg
    So the search was on for a new block...
  3. lumpy 63
    lumpy 63
    So after extensive Craig's List and Ebay shopping... I located a couple of blocks and heads in the hills north of Magic Mountain hoping and praying that when I got home I didn't buy more junk...
    In the end I ended up with a good block that cleaned up at .030
  4. lumpy 63
    lumpy 63
    So I hauled all the parts down to my friends at Wholesale Automotive Machine and did the full block combo. Decked, line honed, bored, the whole nine yards. Crank was standard and we just polished it. 24842.jpeg 24861.jpeg
    I did some minor porting and clean up work on the heads and had the guys install hardened ex. seats, all new valves and valve springs.
  5. lumpy 63
    lumpy 63
    24865.jpeg 24847.jpeg Then I took it home and began ***embly work. Made a trip down to the guys at Schnieder Cams. 24863.jpeg 24853.jpeg
    I sent the rocker arm ***emblies to Rocker Arm Spe******ts in Northern California for refurbishing.
  6. sproadster30
    sproadster30
    from Natick, Ma
    Great start! What's it going in? I started ***embling my 390 this week as well.
    loudbang and lumpy 63 like this.
  7. sproadster30
    sproadster30
    from Natick, Ma
    Also, just noticed the cam card lists 1.5 rocker ratio, but stock was 1.6 for the 390. Just in case you want to double check your lift specs. Would be approx .480 at the 1.6 ratio. Sorry...I've just been degreeing and checking valve to piston clearance today on mine.
    bchctybob, warbird1, loudbang and 2 others like this.
  8. lumpy 63
    lumpy 63
    For my birthday my wife bought me the just released Offenhauser 3 Duece intake and I went to an estate sale and found a complete SBC tri-power intake with Rochester Carbs that the previous owner had rebuilt with vintage speed parts. So I sold the SBC intake for more than I paid for the whole setup and proceeded to make adapters to fit the Rochester Carbs to the intake. 24835.jpeg 24844.jpeg
  9. lumpy 63
    lumpy 63
    I also ended up with a couple of other intakes during this journey. 24846.jpeg
    And NOS Weiand Drag Star intake :D
  10. lumpy 63
    lumpy 63
    So I got the whole thing screwed together and built a quicky engine stand. And got it ready to fire up.
  11. lumpy 63
    lumpy 63
    Here it is running: You may need to copy this into your browser
    jvo, bchctybob, '40 Coupe Fan and 9 others like this.
  12. lumpy 63
    lumpy 63
    I hope you enjoy this, I had fun building this engine.
  13. lumpy 63
    lumpy 63
    Yep , you are correct , I believe the early 331,s etc were 1.5 . mine degreed with no issues and plenty of valve clearance.
  14. lumpy 63
    lumpy 63
    BTW...disregard the violet generator:p
    loudbang and kadillackid like this.
  15. I like the fuel block Colin, make that yourself ?
    Finding a later block here with the full flow filtration is the hard part.
  16. lumpy 63
    lumpy 63
    Yes Chris , I made that . I bought a Moon fuel block but it was too large to place it where I needed it to fit.
  17. kadillackid
    kadillackid
    Wow...awesome build, well done :cool:
  18. loudbang
    Nice, starts right up. :)
    lumpy 63 and Barrelnose pickup like this.
  19. BJR
    BJR
    So.... what are you going to do with it?
    lumpy 63 likes this.
  20. Budget36
    Budget36
    That’s cool. I’m betting there’s a Coupe in the mans future;)
  21. Dreddybear
    Dreddybear
  22. lumpy 63
    lumpy 63
    My original plan was to install it in a 55 Chevy big window that I had, But when I bought the 59 vette project last year I gave the truck to my friend James who's been hanging around my garage since he was 12 or so , he's 34 now:D . I'm keeping my eyes open for maybe a 49 -50 Chevy coupe to put it in? But right now I really need to concentrate on the 59.
    Budget36 likes this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    how did you get by without adjustable rockers and a non stock camshaft? did they grind the cam using the factory base circle size or did you use adjustable pushrods??
  24. lumpy 63
    lumpy 63
    Hey Mark , Schnieder still had brand new cam cores in stock so the base circle wasn't an issue. I double checked the lifter preload when I ***embled the engine and it checked out fine.
    bchctybob and Moriarity like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    you know where that engine could go?? how about in the 59 vette???
  26. lumpy 63
    lumpy 63
    :D You are not the first one to tell me that Mark! But with the Vette I am going for more of a M/SP look.
  27. Dreddybear
    Dreddybear
    I love this. You built it just for the hell of it. I have an olds and doing the same. No idea what it's going in...
  28. lumpy 63
    lumpy 63
    I blame it on Sutton Speed.....He's the one who posted about Holley blowing out the Quicktime bellhousings for $168:cool:. I'm afraid to add up the what I actually spent on the build:confused:
  29. iwanaflattie
    iwanaflattie
    I have a 62 390 if u want a back up motor.
    Cool caddy tho
    kidcampbell71 and lumpy 63 like this.
