Reversing the uprights on 1940 plymouth coupe
Discussion in 'The Hokey Ass Message Board' started by 40mopar, Aug 9, 2006.
  1. 41 d20
    41 d20
    I am in Calgary Alberta canada
  2. inliner2318
    inliner2318
    from Tyler, TX
    How about welding a ford knuckle from a ford axle?
    Then you can use ford spindles, brakes as well as a variety steering arms. Worth it?
  3. 40desoto
    40desoto
    Im getting back into my front end project on my 1940 desoto. OldDaddy, I might be emailing you for some help on modifying he steering arms.
    Im using a fatman dropped upright, scarebird disk brake conversion and installing airbags.
    for airbags Im using the stock lower control arm, just welding a plate to mount the airbag too.
  4. 40desoto
    40desoto
    [​IMG][​IMG][​IMG]
  5. Jhnugent182
    Jhnugent182
    Question here. I have a 1940 Plymouth P10. I’m looking into the dropped uprights from Fatman. The question is what’s the upper trunnion? Fatman called back and asked me what size mine was. I guess there 3 sizes for the 1940 Plymouth. 400,370,310. What exactly am I measuring? Any help would be much appreciated.
  6. Bmac40Ply
    Bmac40Ply
    I just moved the spring perch from the top to the bottom of the control arm. Lowered car several inches. Just cut the old rivets off and bolt to bottom. Nothing else needed
    73RR likes this.
  7. COCONUTS
    COCONUTS
    I had a friend who did this on a 49 Ford. He turn them over, installed them upside down, and switch sides.
  8. onelow41
    onelow41
  9. 64Kaddy
    64Kaddy
    from SoCal
    I took a hiatus on the project for a couple of years but back on it for the last couple of months. Will be happy to answer any questions
