Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. iron dave
    iron dave
  2. High test 63
    High test 63
    IMG_20210121_205027883.jpg IMG_20210121_201543290.jpg finally got the pistons in new mill for the roadster. Scrounged up all the oil pan and timing cover bolts out of my stash also.
  3. impala4speed
    impala4speed
    Looks good Dave. I used VHT black epoxy paint on mine. Took me several tries to get it where I was finally happy with it.
  4. fastcar1953
    fastcar1953
    It was last week but I took the 54 to Kenny Baker choprods on here to get 3 inches taken out of top. a1.jpg
    mad mikey, Lil32, Blues4U and 3 others like this.
  5. norms30a
    norms30a
  6. lake_harley
    lake_harley
    fastcar1953....Is Kenny back at it? I had talked with him late last Summer and it sounded like he was going through some health challenges. I had been wanting his "how to do it" directions set on chopping a Model A Coupe, but he said he was concentrating on his health at the time.
    Lynn
  7. fastcar1953
    fastcar1953
    He's back at it. Feeling good.
    Lone Star Mopar likes this.
  8. Stock Racer
    Stock Racer
  9. blowby
    blowby
    from Nicasio Ca
    Been plugging away with winter upgrades and maintenance on my heap. New cap and rotor, belt, crank seal, hoses, a bung in the pan for filter return.. Still waiting on tie rod ends. I did do a quick touch up job on the frame with some leftover truck bed liner. Thinned it with acetone and sprayed with a touch up gun. Looks shiny because of the flash, really it's flat. Tough as nails on the trailer I painted. My frame is nothing to write home about, build by a couple of Cubans in Florida decades ago with a stick welder and a hack saw. But it works.
    mad mikey, LAROKE, Hamtown Al and 7 others like this.
  10. fastcar1953
    fastcar1953
    Kenny started on the chop today. 143492406_2897366697187593_1579669421358175794_n.jpg
  11. Fabulous50's
    Fabulous50's
    from Maine
    Had my 8 year old helper pull this out for an upgrade.
    mad mikey, Lil32, RICH B and 6 others like this.
  12. lake_harley
    lake_harley
    Good to hear. I'll have to give him a call again.
    Lynn
  13. guthriesmith
    guthriesmith
    Resolved some issues with the rear brakes on my bird and otherwise just drove it to work every day this week...again. Because of the brake issues, I drove the 56 a couple days last week and the Corvair one day after the blower motor in the 56 seemed to have locked up (or something that I have not taken time to chase why there was smoke coming out from under the dash when my kid turned it on). The one day in the Corvair identified some work I still need to do on it now too before it can be a reliable driver...:( For some reason it puked out a bunch of oil on my trip home from work like it created too much crank case pressure or something and blew it out the dipstick. These old cars can **** at times... :eek:
  14. LAROKE
    LAROKE
    I remember those. My '59 Ford taught me how to swap those trannies like a NASCAR pit crew. I was always knockin' second gear teeth off with my three-on-the-tree speed shifts in my formative years.
  15. Fabulous50's
    Fabulous50's
    from Maine
    What came out (pictured) is a '69 close ratio top loader. Going to put an OD (4 speed) in. The origional Borg Warner T-85s were not as ummm...robust.
    mad mikey and LAROKE like this.
  16. RICH B
    RICH B
    My buddy's hood was finally released from paint jail; so we put it on and after a little tweaking it fit pretty good. Have to finish out the latch hooks on the front and shim the cowl lacing a bit. IMG_20210128_161846_3.jpeg
    Sent from my Nokia 2.3 using The H.A.M.B. mobile app
    32SEDAN, blowby, mad mikey and 7 others like this.
  17. topher5150
    topher5150
    Got to thinking about my hot rod the other day and I had a moment where I realised that most everything was in place and all I needed to do to get it move under it's own stream was to do the plumbing, electric, brakes and some some odds and ends to the suspension.... In theory of course
    Sent from my moto z4 using The H.A.M.B. mobile app
    mad mikey and RICH B like this.
  18. davidvillajr
    davidvillajr
    I patted the fender when I got home. Dumping down rain, and the car has to live in the driveway, so it was all I could do.
    Blues4U, mad mikey and Lil32 like this.
  19. olds vroom
    olds vroom
    NOTHING the wife won’t leave the house thanks to corona virus
    Lil32 likes this.
  20. mad mikey
    mad mikey
    Took delivery of my new racing transmission for the coupe. Time to get the swap under way.
    Lil32, saltflats and blowby like this.
  21. Bjorn Wilsson
    Bjorn Wilsson
    The dents in the roof is straightend just a little left after welding in a patch panel. Thre was some rust under bindo and primer. The cowl is welded to- Yes it was rust there to. I started to measure the frame its square and no damage what I can see. Front and back corner of the rails are on the right height, but left rail are 1/4- 5/16 inch higher on the middle than the right rail. I have to measure more. Any way a good day in the garage 001.jpg 017.jpg
    32SEDAN, Lil32, Stock Racer and 5 others like this.
  22. Poverty cap
    Poverty cap
    Last couple days I got the door in final primer and hung it back on to keep it out of the way, also did the body work over and primed the lower rear quarter panel. 13204470-77B5-4813-A690-FDEFF38E11BE.jpeg
  23. Jack Rice
    Jack Rice
    Mine's a crusty old hot rod pickup so it's easy to have a little fun once in awhile. Today I masked and painted some scallops on the fenders.
  24. TA DAD
    TA DAD
    from NC
    Going to try my hand at making a door hinge for my Stud market place 008.JPG ebaker
  25. jockeyshift41
    jockeyshift41
    from Florida
    Made cross members and painted inside of bed last weekend. Fit and cleared the wood this weekend. [​IMG][​IMG][​IMG][​IMG]
    rod1, 61Cruiser, 40two and 8 others like this.
  26. fastcar1953
    fastcar1953
    more updates on top chop. choprods Kenny Baker is the one doing the work in Elmer mo. 145135246_2900528413538088_2062170090772343842_n.jpg 145201571_2900528143538115_2528428237609261385_n.jpg 145243632_2900527680204828_4746017013166305225_n.jpg 145493447_2900527820204814_5589981969852090633_n.jpg 145737701_2900528030204793_2180072293779536565_n.jpg
    High test 63, 32SEDAN, 40two and 6 others like this.
  27. 31hotrodguy
    31hotrodguy
    Picked up a pair of Cragars with 29 inch slicks from a long time friend and H.A.M.B. members. IMG_4358.JPG
  28. 31hotrodguy
    31hotrodguy
    Took the boys on a road trip and Picked up a solid cam pop up piston 301 from a long time hamb member and new friend yesterday!
  29. fastcar1953
    fastcar1953
  30. lonejacklarry
    lonejacklarry
    That looks really good, Jerry. Who is going to do your gl*** work?
