Hot Rods How much does a 392 Hemi really weigh ?
Discussion in 'The Hokey Ass Message Board' started by 73RR, Sep 1, 2020.
  1. gene-koning
    gene-koning
    Years ago, my son bought a 48 Plymouth. We pulled a running flathead 6 with its 3 speed trans (not the auto trans) and installed an LA 360 with a 727 auto trans. After we got the 360 running and driving, the front bumper was 2" higher then it was with the flathead 6. I was surprised how heavy that flathead 6 was. Gene
  2. Scott Jay Smith
    Scott Jay Smith
    I just went through tearing down a bone stock and very complete 1957 392 Hemi that had never been a part since new. I wanted to nail down the weights for the engine as it seems online information varies a bit. What I learned was no huge surprise but interesting. In the 1950's it seems that weight was not a primary concern with any engine by any company, some of the common items most engines of the era shared were heavy as hell. Direct drive starter motors, generators, air conditioning compressors, thick cast iron brackets, etc. It's easy to see why these early engines looked like heavy pigs when comparing advertised total weights to a more modern version with lighter weight accessories. Bottom line, my bare block with main caps and bolts weighed 211lbs. Bare heads were 69.5 each. Crank was 70lbs with the timing chain sprocket and balancer bolt & washer. Rocker ***emblies are 12.5 each. Intake manifold (single 4 cast iron) 45lbs. Water pump and housing, 17.5lbs, both exhaust manifolds totaled 16lbs with heat riser. That's the big stuff but I also weighed every other part down to the smallest items. Bottom line, if you started with a short block and a set of iron heads with rockers and added all of the typical aluminum bolt on upgrades (that most any engine gets these days) they are right in line with most other big blocks, and if you went with aluminum heads (yes, Hot Heads aluminum heads are EXPENSIVE!) they can come down to small block numbers.
  3. jimmy six
    jimmy six
    Too blanking much
  4. seb fontana
    seb fontana
    from ct
    MEL 430. 740!!!
  5. earlymopar
    earlymopar
  6. Ebbsspeed
    Ebbsspeed
    346 Cadillac flathead runs right at 900 lbs.
  7. Hemi Joel
    Hemi Joel
    from Minnesota
    Welcome to the HAMB, Scott. Publishing the weights of individual parts is so important. Many of these weights you see on line don't say what is included. I see some big pig numbers, and then later learn that it includes clutch and belhousing, etc. For comparisons to be meaningful we need to know individuals weights, or what is included.
    Just Gary and loudbang like this.
  8. Scott Jay Smith
    Scott Jay Smith
    Ok, so the engine you see here comes in at 691.5 ***embled with all stock internals and with everything shown, dry, no water or oil plus I added the weights for the distributor, cap & wires, and carburetor to get to this total. What I have not weighed yet are the air cleaner, Generator, AC compressor, Power Steering pump, belts, hoses, and ***ociated brackets. My scale is only accurate within 1/2lb so I plan on weighing the smaller items again on a more precise smaller scale. I'll post results later.
  9. Beanscoot
    Beanscoot
    Scott, is there a flywheel on your 691-1/2 pound engine?
    kadillackid likes this.
  10. Scott Jay Smith
    Scott Jay Smith
    No flywheel and no converter or transmission plate (it was from an automatic car).
  11. Scott Jay Smith
    Scott Jay Smith
    Here's a breakdown, everything was weighed on the same digital shipping scale.
    Block 211lbs
    Heads 69.5lbs ea
    Rocker ***emblies 25lbs (pair)
    Intake with bolts 45lbs
    Crank with sprocket and bolt & washer 70lbs
    Connecting rods 13.5lbs
    Water pump & housing 17lbs
    Exhaust manifolds 20lbs
    Water cross over 6.5lbs
    Harmonic dampener 7.5lbs
    Timing cover 3lbs
    Crank pulley (3 groove) 4lbs
    Water pump pulley 1.5lbs
    Engine mounts with insulators & bolts 6lbs
    Valve springs with retainers 3.5lbs
    Direct Drive Starter Motor 25lbs
    Oil pump drive and front of block cam plates 1lbs
    Head Bolts 7lbs
    Push Rods 3.5lbs
    Distributor without cap or wires 4lbs
    Upper timing gear and chain 4lbs
    Oil pump 5.5lbs
    Fuel pump 1.5lbs
    Piston pins 3lbs
    Pistons 14lbs
    Oil Pan 7lbs
    Valley pan cover 4lbs
    Oil filter base with bolts 1.5lbs
    Oil filter canister 1.5lbs
    Cam eccentric, dist. clamp, oil slinger, misc. wire loom brackets, attaching hardware 2.5lbs
    Spark plug tubes, cam bearings, head gaskets 2lbs
    Main bearings 3lbs
    Carburetor with fuel filter 7.5lbs
    Camshaft 10lbs
    Lifters 4lbs
    Valves 4lbs
    Valve covers (pair with plug wire covers & bolts) 10lbs
    Total 699lbs
    *Not included: Air cleaner, Generator, Power Steering Pump, AC compressor, ***ociated brackets & bolts
    rod1, loudbang and j hansen like this.
  12. Ebbsspeed
    Ebbsspeed
    Should Connecting Rods be added to your "Not Included" list?
  13. Yea but they made enough zot to get them outlawed. hence the saying, "If you can't beat 'em outlaw 'em" :D
    I am not one who has ever weighed a 392 I always figured 700 lbs when I was going to haul one. LOL
    warbird1 likes this.
  14. Scott Jay Smith
    Scott Jay Smith
    Yes, missed them, my mistake. They weigh 13.5lbs with nuts bolts and caps, after adding my numbers again the corrected total is 699lbs.
  15. 73RR
    73RR
    ...and the debate goes on......even with a scale:p
  16. Scott Jay Smith
    Scott Jay Smith
    Oh, it will change again, I am weighing the smaller stuff again with a more precise scale, total will almost certainly change LOL :)
  17. cfmvw
    cfmvw
    A lot of early internal combustion engines used cast iron pistons as well. I once talked to someone who was rebuilding an engine that used them. I forget the make, but I remember those pistons were heavy!
  18. KenC
    KenC
    Lots of 216 chevys had those.And I think a few of the early 235 truck engines, pre-insert rods.
  19. tubman
    tubman
    Known as "The Cast Iron Wonder" back in the day.:)
    Hnstray likes this.
  20. BigJim394
    BigJim394
    According to a HRM article (late 60s era) on engine /trans swaps, the heaviest combo was a 392 hemi with a dual range hydramatic trans.
    The second was a 394 olds with the same trans.
  21. 392
    392
    Heavy and one of the best mils ever made.
  22. Beanscoot
    Beanscoot
    On the other hand, some engines had cast iron pistons that really weren't very heavy at all - they were beautifully cast, fairly thin iron.
  23. Flathead Dave
    Flathead Dave
    from So. Cal.
    About as much as a henway...
  24. Bert Kollar
    Bert Kollar
    I haven't weighed my baby hemi 270 Dodge but when I pick it up with the cherry picker it balances the same as my 383 Big Block Mopar ,if anybody cares
    mgtstumpy likes this.
  25. Hemi Joel
    Hemi Joel
    from Minnesota
    I'll be screwing together a gen 2 Hemi in the next 18 months, I'm really curious as to what it will weigh. I'm very skeptical of the 843# quoted above. Maybe that includes a cast iron bellhousing and flywheel. My guess is 740# complete with iron heads, no bell or flywheel.
    Hnstray and WillyKJr like this.
  26. mgtstumpy
    mgtstumpy
    My Ford FE weighs 625lbs, I'd hate to think what that 354 with cast iron transmission, convertor and park brake ***embly weighed. I recall that Chrysler saved approx. 65lbs by going to aluminium from cast iron. This is the flathead 6 and cast iron Hydro from my 46 Olds; I remember that it was no light weight when removed!
  27. 6sally6
    6sally6
    Soooooooooooo....you never said how much your hemi weighed!!
    6sally6
  28. Pete Eastwood
    Pete Eastwood
    from california
    393 hemi . . .
    1,251 lbs. ready to race !
  29. 73RR
    73RR
    Beautiful!!!!!
    Hnstray likes this.
