Hot Rods CA Hot Rod Deuce Coupe **Found***
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Dec 20, 2020.
  1. Hotrodderman
    Hotrodderman
    Wow! Great find. What a score. Real nice early work done to the car.
    Hotrodderman
  2. bchctybob
    bchctybob
    Normally I would be in the DON'T channel it camp but I saw this today on another thread and now I'm not so sure. That thing looks mean, even with the skinny tires and wire wheels.
    It always seems a shame to channel a '32 and lose the nice reveal line on the side of the frame rails (not to mention the comfort factor). I always thought a good channel would stop just above the reveal, like maybe a 3" channel.
  3. lumpy 63
    lumpy 63
    Awesome score ! build it to suit your vision just like was done in the day. You may not remember me but we met at Irwindale a couple of years ago at the antique drags when you were running your A sedan and we were running the Willys PU. Your sedan was a pleasure to watch going down the track and was no slouch. I hope you plan to treat the 32 as a Hot Rod also . Sincerely Colin
  4. BrandonB
    BrandonB
    from nor cal
    Picture's worth a 1000 words and this says it all. Good for you.
  5. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Same stoke!!!
    The wife has been hearing me talk about this car for a long time and was great. Totally on board with my addiction.
    Another 1000 words.....
  6. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    No more Milner fenders....
  7. As Alchemy stated. The flip and dip way was how we channeled a 1932 Ford 5 window coupe in the early 1960's when I was in the Stockers car club in Glastonbury, Connecticut. It was an easy way to channel the body, but also left us the option of un-channeling it in the future.
  8. The37Kid
    The37Kid
    DSCF0186.JPG Instructions from 1947 Ray Kunh's Automobile Racing Vol 6. Wonder if you could stuff a '32 frame in diagnally throug the deck lid opening with the bottom panel removed and save the cut lines. Bob
  9. gbones32coupe
    gbones32coupe
    Stogy and loudbang like this.
  10. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Scored this... with a floor.
    alfin32, dwollam, 40two and 16 others like this.
  11. AHotRod
    AHotRod
  12. Nailhead A-V8
    Nailhead A-V8
    Alternately there is another '50's method "goosenecking" or "V-ing" this is taking pie cuts from the top of the frame at the firewall and under the frame before the front crossmember which drops the body leaving the subframe/floor alone...with a flat frame Z-ing the rear is also necessary but with a '32 probably switching to an A rear cross/spring will do depending on the amount of "sweep" at the front...
    Stogy and chryslerfan55 like this.
  13. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    ***** UPDATE******
    I think I might have found the history on my car.
    Can anyone get me in contact with Willie Wilde of Wilde’s custom shop ( Salinas CA) or his family.
    Stogy, SS327, Thor1 and 2 others like this.
  14. HEMI32
    HEMI32
    Paging Rod Powell (@RodP) ...
  15. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Huh???
    Stogy likes this.
  16. HEMI32
    HEMI32
    Salinas customizer, painter, & artist Rod Powell (@RodP on the H.A.M.B.) knows/knew Willie and the Wilde family … so he may have some contact info for you ... see this POST by Rod in @Rikster's 2008 "Willie Wilde Custom Cars" thread.
    UPDATE: Unfortunately, Rod no longer frequents the H.A.M.B. ... but he does post on Facebook & Instagram.
  17. SS327
    SS327
    The red on your sub rails looks to be the same red on the frame of this car. Any sign of color other than black on your frame? I could be wrong?
    Stogy likes this.
  18. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    ***UPDATE***
    So this is what I am working on to figure out.
    Saw a pic tire this 32. The article makes sense with my car. My previous owner said it was a “full fendered flat head car before”
    I have noticed some similarities. Plus I’ve found both red and blue paint on my car.
    Stogy, alfin32, chryslerfan55 and 3 others like this.
  19. catdad49
    catdad49
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    The craftsmanship on my chop looks professional as done by Willie Wilde. Other places look amateur and probably done later.
    Stogy, Thor1 and Jim Bouchard like this.
  21. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    More pics..
    Side loader
    Blue dash
    Red and blue on frame. D9D32F90-D42B-416F-AA41-24CC307B0EE4.jpeg 165229C6-1F7F-471C-AEF3-5ABEF51DB63C.jpeg 3BE2E2F3-F592-49F1-9AC9-6D99CF0AFC17.jpeg
    Stogy, Thor1, alfin32 and 3 others like this.
  22. Squablow
    Squablow
    Using the red picture as a reference, can you take a picture of your body at the exact same angle? They could be overlayed in the Photoshop thread to see if the heights and lines all line up correctly. It wouldn't be definitive, but it would be a step in the right direction, or maybe would eliminate it as a possibility. It's been done to help ID several historical cars in the past. They sure do look similar.
  23. Gotgas
    Gotgas
    from DFW USA
    That really looks like it could be the car! Shaved door handles, too. I hope the connection gets made, that would be really awesome. That's a great looking deuce. Would like to see it in blue, hopefully that history can also be found. :)
    Thor1, chryslerfan55 and SS327 like this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    I made the last pics big for you, simply click "full image" when posting.....
    Stogy and 40two like this.
  25. alchemy
    alchemy
    Now THAT would be a great example to recreate! Arntcha glad you didn't channel it?
    Stogy and SS327 like this.
  26. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I always said if I found how the car was I’d recreate it.
    NOW YES!!
    Stogy, Thor1, chryslerfan55 and 5 others like this.
  27. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’ve reached out to Industrial Machine Shop in Salinas CA to help identify anyone who knew **** Shannon. Unfortunately he has p***ed away, but may be able to contact a daughter. We will see.
    I also reached out to Rod Powell on Instagram.
    I hope I can find more pictures of this car to solidify my su****ion.
    Stogy, Thor1, HEMI32 and 4 others like this.
  28. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’d like to talk with Andy Southard who wrote the book and knows more about the car. If he can identify the dash I think that would confirm it.
    Stogy, Thor1, chryslerfan55 and 3 others like this.
  29. Yep, the dash and some minor details f.e. the inner rearview mirror could give a clue. i like your story very much, you're doing good. keep on! Cheers, Carsten
  30. SS327
    SS327
    If it is the same car you have struck gold as that car is fantastic looking. I would be excited if I was you! I think I would have to go Stude on the engine though.
    Stogy, Thor1 and chryslerfan55 like this.
