Projects 1931 Roadster AV8 Build
Discussion in 'Traditional Hot Rods' started by 53studecoupe, Nov 30, 2019.
  1. 53studecoupe
    53studecoupe
    from Eagle WI
    20191109_155034.jpg I have always liked this site with so cool stuff. I never considered building nothing like I see here. I was always stuck in the 50's nothing wrong with either until I went to a SEMCO show here in WI. I enjoyed to old hot rods and caught the fever in Bonneville. So I bought a model a frame from a fellow hamber here. Thank you guys although my wife has a different opinion......
  2. Nice looking frame....what is the plan?
    Stogy likes this.
  3. 53studecoupe
    53studecoupe
    from Eagle WI
    I am not 100% sure. It will be a 1931 roadster. But I saw one channeled with fenders and it was different, low to the ground made a nice stance.
    Stogy likes this.
  4. 53studecoupe
    53studecoupe
    from Eagle WI
    Oh a flatty for sure!
    3340, sidevalve8ba and Stogy like this.
  5. cederholm
    cederholm
    I'm in the middle of my own AV8 build myself - also a "first timer". I've found the Vern Tardel big book to be very helpful.
    ~ Carl
    Macstoy, Outback, 3340 and 4 others like this.
  6. Flathead Youngin'
    Flathead Youngin'
    Welcome! Be sure to start a build thread...... Nothing like the first time you take the rattle-trap down the road the first time....
    Fordors and Stogy like this.
  7. sounds good to me........
    Stogy and porknbeaner like this.
  8. or Studiebaker power...........
    Stogy and chopo like this.
  9. 53studecoupe
    53studecoupe
    from Eagle WI
    20191207_144310.jpg Oh I get it! Since I don't have any sheet metal to play with just yet. I put the gauge package together today. Not going with the cowl gas tank.
  10. 53studecoupe
    53studecoupe
    from Eagle WI
    First thing I bought.
    Thanks.
    Stogy likes this.
  11. 53studecoupe
    53studecoupe
    from Eagle WI
    20201114_193910.jpg 20201114_193910.jpg 20201114_183211.jpg I have not posted in a while too busy in the garage. 1931 roadster all steel with fenders. Going a little different than most. 3" kickup in the rear frame and a 4" drop axle up front. 8BA flathead with 3 Strombergs. Just tacked up some lake headers. Barely fit the cowl and fender but it does. The other side has the F1 steering box. That one will be a challenge.
    oliver westlund, Tim, -Brent- and 8 others like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The look of full fenders, lowered is always impressive. Enjoy.
    Outback and Stogy like this.
  13. wheeldog57
    wheeldog57
    Looks like you are well on your way, keep it up and keep us posted
    Stogy likes this.
  14. 53studecoupe
    53studecoupe
    from Eagle WI
    20201203_160142.jpg 20201203_160210.jpg 20201203_160225.jpg 20201203_140000.jpg 20201203_132554.jpg I was able to get one header built and still not hit the cowl or the front fender.
    I could have gone higher in the vertical as the fender pulls away but i didn't like the look so we split hairs here. No paint to worry about either.
    I purchased parts from Speedway and some tight radius starters. Very easy to build really. Note to self. Put the bad welds on the bottom....
    Lil'Alb, Outback, Tim and 4 others like this.
  15. 53studecoupe
    53studecoupe
    from Eagle WI
  16. 21studder
    21studder
    from Finland
    Really nice work!
  17. 53studecoupe
    53studecoupe
    from Eagle WI
    Took the 40 banjo apart and welded up over the top spring perches. I guess I found a pretty good deal. Complete with brakes bones and torque tube for $100.
    Check out the bearing surfaces and if it couldnt get any better a nice set of 3.54 gears! 20201211_143900.jpg 20201209_141200.jpg
  18. GordonC
    GordonC
    Looking good so far!
    Stogy likes this.
  19. Aaron D.
    Aaron D.
    That's a great deal. All that stuff is usable in an AV8.
    Stogy likes this.
  20. 53studecoupe
    53studecoupe
    from Eagle WI
    20201221_150445.jpg 20201221_155449.jpg 20201222_130626.jpg Banjo all cleaned inside and inspected for wear. None! Clean leaves of rust and apply anti seize compound. Mount model a spring with main leaf first and C clamped the rest. Always kept a treaded rod engaged in the center hole just in case. Ended up going from 7 leaves to 4 for a lowered look as well as a softer ride. We will see....at least the shackles ended up at a 45 degree like they are supposed to. View attachment 4917493 View attachment 4917493 20201222_130700.jpg
  21. v8flat44
    v8flat44
    Some one at your place does real nice work on a really neat project....tell em to keep it up.....
    Stogy likes this.
  22. 53studecoupe
    53studecoupe
    from Eagle WI
    Little more work done on the roadster. Found a Dodge Caravan second row seat for $20. It was like it was made for the car. Fits right on the seat riser. It will help locate the steering wheel and pedals for a comfortable position. Yes I will be recovering the upholstery at a later date. 20210118_160806.jpg 20210117_172756.jpg 20210109_140228.jpg
  23. 53studecoupe
    53studecoupe
    from Eagle WI
    Here is a Caravan seat recovered. It will need some foam work to lose Screenshot_20210106-111131_Chrome.jpg the butt and backrest impressions. It looks beautiful!
  24. Nice..............
    Stogy likes this.
  25. 53studecoupe
    53studecoupe
    from Eagle WI
    20210203_144950.jpg Its a roller!
    4" dropped axle. Round back spindles and 40 drums. Posie spring and split wishbones with Speedway mount kit. Not welded just yet. But the chassis with 29.0 rear tire and a 25.0 front I get a nice three deg rake. 20210203_162307.jpg 20210203_144903.jpg 20210203_144928.jpg
  26. Stogy and Fairlane500 like this.
  27. 53studecoupe
    53studecoupe
    from Eagle WI
    Mine are not attached just yet but are positioned where they go. I noticed the sub rail could have extended a little farther to give the top two holes to bolt/rivet to. 20210204_113225.jpg
  28. 53studecoupe
    53studecoupe
    from Eagle WI
    Hope this helps.
    Stogy likes this.
  29. 53studecoupe
    53studecoupe
    from Eagle WI
    20210212_132237.jpg I have a 4" kickup in the rear for the rear spring. I did a little sheet metal work today in the shop. Can you tell I have done HVAC work in the past? Don't have a beading tool but it does the job. Small little trunk now. Hope to fit a gas tank in there somewhere. 20210212_145043.jpg View attachment 4974012 View attachment 4974012
    oliver westlund, Tim, Stogy and 5 others like this.
  30. 53studecoupe
    53studecoupe
    from Eagle WI
    Finished mocking up the rest of the floor.
    The toe boards. I used a F1 trans cover to clear the 32 crossmember and trans tower. Again trying to use old ford parts.
    I was almost going to use plywood but I just couldn't bring self to doing it. Shifter tower is a little off from the F1 location in the cover. A little patching will fix that. Next clearance the steering column and pedals and we can start hanging the body. 20210215_153850.jpg
