Hot Rods The stupidest thing I did in the garage.
Discussion in 'The Hokey Ass Message Board' started by hotrodrhp, Jan 28, 2021.
  1. hotrodrhp
    hotrodrhp
    from Wisconsin
    Sitting here at my computer thinking of some of the dumbest things I've done in the garage. Some I admit to sheer carelessness, some just stupid youth borne ignorance.
    Can think of a few right off the bat. Working late into the night during a work week trying to ****on up a friends head and cam install on my buddy's small block Chevy. All went well until time to drop the distributor into the block. Somehow I knock the distributer retaining bolt into the empty hole!!! **** I am screwed it's 1 am tired and now totally pissed. Tried the magnet trick, lights grease on a dowel. Nothing worked, can't retrieve the bolt, the pan is next...great!
    Climbing under the car to pull the pan I lay on something hard and low and behold lies the bolt I've tried to find for hours. In my panic I failed to even look under the car. Finished up at 3 in the morning and at age 18 learned a valuable lesson. Take the easy path first prepare for the worst. BTW the car ran exceptionally well after the mods.
  2. Almostdone
    Almostdone
    As a kid of maybe 12 I ‘copied’ my dad and used a lighter to burn away some gas I spilled on the floor of our attached garage while filling the lawn mower. When the entire gas can caught fire a construction worker ran from across the street, up the driveway, into the garage, picked up the burning can, and ran it out to the street - I don’t think he ever slowed down.
    I hope I don’t top that one. Geez.
  3. 41rodderz
    41rodderz
    from Oregon
    :D That’s where my small parts always end up but true to form they hide under tool boxes, under a tire just out of sight ( first and second look) or under a cabinet right at the wall. :(
  4. oldiron 440
    oldiron 440
    All the dumbest things I ever did in the shop involved women.
  5. mad mikey
    mad mikey
    When I was in my teens I had a OT 69 nova. 327 with a 671 blower, 660 center squirters, A real street sweeper. I was about to change oil and do some other maintenance when my buddy came walking into the garage and asked what he could do to help. I had already changed the oil filter so I said hey Earl, put the oil in and then check the level. He dumped the oil in, 5 and 1/2 quarts. Checked the level and yelled, hey MIKE, its the whole way up the dip stick. I had forgot to drain the oil .. My dumb *** mistake. One of many I suppose over the years.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Trying to run 2 additional circuits in and outside of garage as it's trying to rain just minutes ago.
    mad mikey, loudbang, blowby and 2 others like this.
  7. AVater
    AVater
    Does there just have to be one thing?
  8. 51504bat
    51504bat
    In Jr. High I had a gas tank on a mini bike that had a leak. No problem, I just fired up the propane torch and proceeded to try to solder it up. Why I didn't blow myself and the entire ba*****t to kingdom come I'll never know. And of course the solder "fix" didn't work anyway. Later in HS I had trouble stabbing the distributor in my 289. Always got it in a tooth off. Didn't think about moving the plug wires one hole. Just kept pulling the distributor up and trying to get it right. On about the 10th try the oil pump shaft came out of the pump and fell into the pan. Got up at 6 am the next morning to pull the pan and retrieve the shaft. Finally got the distributor set correctly. Learned a lot since then but unfortunately still do a bunch of bone head stuff.
  9. Deuce Daddy Don
    Deuce Daddy Don
    With the SS battery box under the seat, I was removing the positive lead when my ring contacted the edge of the grounded SS box!----In an instant the ring glowed red & exploded my flesh around the ring----OUCH!!
  10. Mike, I did just the opposite of that. Years ago, I was changing my oil. At the time we had an old farm house without a garage. The garage was at my dads place. So I just changed the oil on the front lawn. I had drained the oil, and changed the filter. When my wife called me for lunch. When I came back out after lunch. I added 5 quarts of oil. Checked the stick, and nothing! I hadn't put the plug back in the pan yet.:confused: Can you say clean oil in the gr***? And I wish that was the dumbest thing that I ever did. But NO, that's another story. lol Ron.....
  11. Sitting in a heated, completely insulated and sealed shop with 20 below outside temps, checking the cooling capability of the new radiator and fan I'd installed in my BB powered 27 roadster. As I sat there watching the gauge, after about 40 minutes I was pretty happy with the results, some might even say euphoric...
    Still get razzed over that one by my Buddy. But if he hadn't showed up when he did, that razzing would be the least of my worries.
  12. GordonC
    GordonC
    I didn't have a garage where I lived when I was younger and the clutch had gone out on my car. So me, my 3 brothers and 2 brothers in law, tipped my car up on it's side on an old mattress, propped it in position with the driveshaft, and I then pulled the 4 speed and replaced the clutch. I know, I know, not the smartest thing I could have done...
  13. rusty valley
    rusty valley
    it seems to me that after all these years of dropping things our ears and brain combine and cause a freeze, so you can try to picture where it went. like, fell...but i never heard it hit the floor, check frame rail or on a bad day down into some inaccessible lower fender mount. or, hit the ground, rolled, then "plink" hit somethin, thats an easy one, look near the wrench you dropped an hour ago. hit the ground, bounced a few times, then quiet...thats a tuff one, could be anywhere. those are usually tiny parts that you no spare in stock, neither does the parts store thats closed anyway, and you cant finish the job without it. of co**** all these scenarios require the brain and hearing freeze i started with, however, at 65 the brain and the ears and the eyes dont always perform like they used too.
  14. rusty valley
    rusty valley
    Gorden c, i had a 50 chev up on its side to get the ****** out and the neighbors called the police! thats when i knew i had to live in the country
  15. harpo1313
    harpo1313
    from wareham,ma
    I put a sbc 400 in my truck with all the 350 stuff including the balancer, made it 20 miles and it left the room.
  16. Joe Troilo
    Joe Troilo
    After finishing a beautiful paint job I began the demanding task of wet sanding. Had about half the car completed when I heard a scuffing sound coming from the other side. I looked for the source of the noise and found my 4 year old son helping his Dad sand the other fender. I thought that was cool until I saw the 80 grit paper in his hand.
  17. jjjmm56
    jjjmm56
    from FL.
    One night while drinking a few and cleaning the shop I had some clear that hardened in the bottom of the cup. I thought, hey let’s see if it will burn. I set it on the floor and lit it. As the flame grew and was starting to really stink up the place i decided the best way to put it out would be to STOMP on it. Not only did that not put it out but ,what was once one fire was now about 20 smaller fires. Of course in my state of mind I thought it would now be easier to extinguish them again with my foot. I now had 50 tiny fires that hid under cabinets, tool boxes, cardboard and anything else that might cause a much larger problem. Thinking to myself oh **** I grabbed the fire extinguisher and proceeded to fog my entire shop with an unsightly yellow dust. The worst of this whole ordeal was at the peak of the fogging my wife decided to come to check if I was ok because she hadn’t seen me for awhile. I now am not allowed to play with matches when I’ve been drinking.
  18. blowby
    blowby
    from Nicasio Ca
    Came home after night clubbin' in my Vette, pulled into the garage, knocked my Harley over into some shelving, dumping the contents on it.
  19. Rickybop
    Rickybop
    I've already divulged too much in previous threads. Maybe I should try to retain at least a little of the illusion that I know what I'm doing.
    Or, I could start a build thread and shatter any remaining illusions.
  20. deathrowdave
    deathrowdave
    from NKy
    My 32 was Chebbie powered with a Vertex Mag . The Mag was laying on the work bench when an Ole Buddy arrived with his date on his Harley . He tells me watch this , he leaned against her twisted the Mag and she wet her laundry ! Naturally it was my fault because I was laughing , she slapped the smile right off his face causing him to drop my Mag . Not good . But it was funny .
  21. hotrodrhp
    hotrodrhp
    from Wisconsin
    Had a 421 Pontiac engine apart in the garage in my first apartment. Newly married and worked days and attended college at night. I got home late after cl*** and decided to stop in the garage where I had found rust starting to form on the crank journals. In a moment of genius the previous day I thought using sulphuric acid I had gotten at work would remove the rust. Yes still stupid! Bottom of the gl*** acid bottle burst spraying my coat and shoes with acid. Ran into our apartment ripping clothes off. There they sat smoldering like the wicked witch in the Wizard of OZ. My wife laughed herself silly watching me dance around ripping off clothes once she realized I wasn't hurt. Scared the living **** out of me! Had the crank turned down the next week. More to come from the land of stupidity and to think I'm considered smart in some circles.
  22. MeanGene427
    MeanGene427
    from Napa
    Saw a guy do that once on a GMC tractor with an 8V-71. When we walked in, he was on top, halfway through the second case of oil, and a sea of oil 10ft past the front bumper
  23. MCjim
    MCjim
    from soCal
    Tried to put out a carb back fire with a greasy, solvent soaked rag...****.
    mad mikey and loudbang like this.
  24. MeanGene427
    MeanGene427
    from Napa
    Stupidest thing I did in the garage- Carol, in her Escalade
    chryslerfan55, fauj, Ford52PU and 9 others like this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
  26. goldmountain
    goldmountain
    I was parting out this late model EFI car and didn't want the gas to go to waste so I decided to drain the tank. Since these cars come with electric fuel pumps in the tank, I found the correct wires and hot wired the thing with the fuel line dumping into a plastic jerry can. To make sure that I didn't overfill the jerry can, I placed a trouble light along side it to see the fuel level. Of course, it overflowed and once it hit the hot trouble light, caught fire and I got burnt trying to move the trouble light away.
  27. 56don
    56don
    How about when I installed a C4 Ford transmission, get it all ****oned up, try to drive it....no go.....left the input shaft laying on the bench. No wonder it went in so easy.
  28. Okie Pete
    Okie Pete
    We have a old fridge in the shop that we store welding rod in . I was going to cut the small freezer out of the top for more storage. Dad tells me don't put your head in there when you cut the lines . Some companies used propane for refrigerant . So I stand to the side and reach inside with the die grinder to start cutting. I cut the first coil it goes ****f and a 6' flame shoots out. The freezer is still in there .
  29. Pats55
    Pats55
    from NJ
    The dumbest thing I have ever done is put a socket extension under a kingpin and lower the car on it. Then I proceeded to hit it with a 5-pound hammer . Luckily for me I was sitting off to the side because the socket extension slipped it went through the sheetrock wall. My latest trick was to put a strut in a vice I managed to launch that across the garage.
  30. thintin
    thintin
    well ...its early, aint got done with coffee and gone out there yet.
    safetythird, Okie Pete and mad mikey like this.
