Technical New ‘32 Ford throttle assembly?
Discussion in 'Traditional Hot Rods' started by 65standard, Jan 26, 2021.
  1. 65standard
    65standard
    Are there any reproduction throttle ***emblies for the ‘32 Ford? I’m looking for a correct setup for a V8 car.
  2. Pete Eastwood
    Pete Eastwood
    from california
    originals are not hard to find .
  3. 65standard
    65standard
    Thanks, I’ll check the cl***ifieds
  4. alchemy
    alchemy
    Do you know how to tell a 32 from all the others?
  5. ^^^^the 32 ones will cost 3-5 times more than the Model A ones :):)
  6. alchemy
    alchemy
    Try ten or twenty.
  7. alchemy
    alchemy
    The 32 has the small little nub out the left side of the pedal arm for the dashboard throttle rod to connect to.
  8. Deuce Lover
    Deuce Lover
    No repops made.There is one on EBAY right now.My mistake,its a 33-34. The Ford Store in San Dimas,CA has a few in stock.
  9. hotcoupe
    hotcoupe
    Sent you a P. M.
    Tom
  10. HOTRODPRIMER
    HOTRODPRIMER
  11. 65standard
    65standard
    What is the dashboard throttle rod? What does it connect to?
  12. Andy
    Andy
    It goes to a bellcrank in the dash tunnel and it works with the hand throttle in the dash.
    Make sure you get the little v shaped cover with any purchase. I see 20 to 1 advertised with out the cover. It is required to hold the ***y to the firewall.
  13. 5window
    5window
    Amazing place,the HAMB
  14. 65standard
    65standard
    Thanks for all the great information I never knew about the ‘32.
  15. Deuce Lover
    Deuce Lover
    Here is a pic of the doghouse cup that mount it to the firewall. Those alone not currently reproduced have been selling on EBAY for around $40.
    Budget36 likes this.
  16. Oldtmtech
    Oldtmtech
    Never did understand how the s**** pedal worked with only one stud for mounting any more pics? Thanks
    Just Gary and FORDY 6 like this.
  17. Deuce Lover
    Deuce Lover
    On the stock firewall there is a vertical hole and 2 "D" nuts .The s**** end of the pedal slips thru that hole.The doghouse has a notch on one side.The notch goes on the shaft side.The pedal pivots in that.The other hole to the left is where the other shaft attachment attaches. 32 Firewall gas pedal hole.jpg Here is a pic.
  18. Oldtmtech
    Oldtmtech
    Thanks
    I guess that bump out on the sleeve is what keeps the sleeve from rotating
  19. alchemy
    alchemy
    Yes, the standoff on the sleeve sits against the firewall, and the triangle "doghouse" has a slot which covers over the standoff.
    Note I just learned something from my brother a couple months ago. A 32 cover is different from later year covers. So, not only are they usually missing, the replacement might not fit right. I haven't spent time comparing the 32 to later ones yet to visualize the differences.
  20. Deuce Lover
    Deuce Lover
    33 truck firewall 1.jpg 33-34 truck firewall 2.jpg The one that is different is the 33-34 truck ones.They are slightly offset.That is the only difference.Here are pics of the 33-34 truck firewall- gas pedal location.You can see that the doghouse shape is not centered but off set to the top.
  21. xix32
    xix32
    If you want to be authentic, those are #12x24 sloted head screws that hold the "dog house" cap to the firewall on a `32 Ford. A rather odd size by todays standards.
    So, don't attempt to force some 1/4" X 20 screws into those threads.
  22. alchemy
    alchemy
    Geez Ford was gung ho with the #12's wasn't he? Such a hard to find size anymore.
    seb fontana and Just Gary like this.
  23. Dak Rat
    Dak Rat
    from NoDak
    Menards home centers have a fairly good selection of 12/24 screws. Zinc plated only, no stainless that I have seen.
  24. 51box
    51box
    from MA
    The early Ford store California sells a reproduction listed to fit 32 p*** car.
  25. dirt car
    dirt car
    from nebraska
    Look closely at the Home Depo packaged s.s. selection I found 12-24 oval head, & others for my 32 dash redo.
  26. alchemy
    alchemy
    I bet all the screws from Menards and Home Depot are phillips head. Hard to find slot head screws anymore. I usually go to McMaster Carr for them, and then buy a box = lifetime supply.
  27. Jacksmith
    Jacksmith
    from Aridzona
    Try Fastenal... they've got just about any fastener you can think of.
  28. alchemy
    alchemy
    My local Fastenal store doesn't have half the weird stuff I want, so I'd need to order it in anyway. I can order any size bolt made by man from McMaster Carr and it will be on my doorstep tomorrow. I bet Henry Ford ordered bolts from McMaster Carr.
    Here they are in stainless so they will never rust: https://www.mcmaster.com/screws/thr...lotted/material~stainless-steel/length~3-8-2/
    Just $0.10 each in the box of 100.
  29. sloppy jalopies
    sloppy jalopies
    You can use a 33-34 but need to weld an extra linkage ball onto the interior shaft to run your hand throttle.. [early cruise control]...
  30. Deuce Lover
    Deuce Lover
    Here is a 33-34 gas pedal.Its longer and different dogleg.Yes it could possibly be made to work 33-34 gas pedal.jpg
    65standard likes this.
