Technical Spin on adapter identification
Discussion in 'Traditional Hot Rods' started by raoul duke, Jan 28, 2021.
  1. raoul duke
    raoul duke
    from S.E. Mass
    Hey all,
    Got another question: what type of spin on adapter is pictured below? Getting my ‘66 327 block ready for the machine shop and this is the only thing I can’t figure out. My inclination is to pull the bolts and get a rod into the threaded filter boss and pry, but I don’t want to ruin anything.
    Thanks again in advance!
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    Spin on oil filter adaptor. Should pop off after removing the two bolts.
    loudbang, HemiDeuce and Johnny Gee like this.
  3. Bob Lowry
    Bob Lowry
    Yep, standard spin on SBC adapter.
  4. raoul duke
    raoul duke
    from S.E. Mass
    That’s what I thought, but I remove the bolts and it seems stuck. Like, really stuck. Ran a razor blade around the gap outside and flushed it out with carb cleaner and no change.
    This is why I was considering the prying.
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I believe there is just a gasket under the adaptor. It may have some gasket cement on it holding it tight.
    loudbang and VANDENPLAS like this.
  6. raoul duke
    raoul duke
    from S.E. Mass
    Second question is “would you save and re-use?” These don’t degrade over time I would think?
  7. Probably just good and stuck.
    Try giving it a good tap with a dead blow hammer
    And as far as wear ? How ?
    Maybe the threads where the filter spins on can get damaged by hamb fisted oil change kids but simply wearing out? Naw.
    and Raoul , where, where you when the drugs took hold ?
  8. raoul duke
    raoul duke
    from S.E. Mass
    Why somewhere around Barstow, out in the desert - of course...
    chryslerfan55 and VANDENPLAS like this.
  9. Ebbsspeed
    Ebbsspeed
    Remove the bolts and put a little heat from a propane torch to the perimeter of the adapter. That will soften up any gasket glue which might have a firm grip on the adapter. There appears to be a slight gap between the adapter and the edge of the engine block where you could stick a small flat blade screwdriver in and twist to see if that will pop it loose. If it is flush, tap the sharp edge of a knife blade between the adapter and the engine block.
  10. dadsdreamcar
    dadsdreamcar
    Take out the bolts holding it to the block, then screw on a filter, gently tap on the filter the added leverage should help
    dwollam, egads, partsdawg and 7 others like this.
  11. X-cpe
    X-cpe
    How about a couple of shots of gum cutter or brake clean?
  12. tinkirk
    tinkirk
    It is stuck in the grove where the original canister would seal on a square cut o ring is
  13. raoul duke
    raoul duke
    from S.E. Mass
    Lots of great advice, thanks all!
  14. Oilguy
    Oilguy
    I had the same issue recently with a 1965 built block. I put the rubber covered handle end of a 1/2 ratchet down the center of the adapter and gently worked it back and forth and it popped out. If you break the adapter, you aren't out much. I got a replacement from TransAdapt just so I would have a clean one for reassembly.
  15. sdluck
    sdluck
    Some of those adapters used ford oil filters.
  16. Blues4U
    Blues4U
    from So Cal
  17. 56sedandelivery
    56sedandelivery
    I think it's the "better made" of the adapter's out there. Most likely takes the Ford application filter with a built in pressure relief valve. That feature goes with the stock, canister, locating plate. I am Butch/56sedandelivery.
