Technical Closed shaft rear end to open shaft
Discussion in 'Traditional Hot Rods' started by LB+1, Jan 29, 2021.
  1. LB+1
    LB+1
    from 71291
    I have searched can't find, how to change a 40 ford rear end from closed drive shaft to open. In the back of my tire smoked mind, this was common in the 50's? Hope someone knows how. Now on a Chevrolet closed shaft rear you can use a 3/4 ton drive shaft.
  2. Budget36
    Budget36
    Easiest is to find a ‘42-47 Ford PU rear. But have also read that other methods work, with machining an adapter and using a seal, etc. pretty sure kits are available, but don’t recall who from
  3. rusty valley
    rusty valley
    speedway has em i believe
  4. warbird1
    warbird1
    As Budget36 said, 40's Ford pickup rear end parts... or buy one from Hot Rod Works or other vendors.
    HotRodWorks likes this.
  5. krylon32
    krylon32
    from Nebraska
    For converting to open drive Hot Rod Works is the only way to go. Stay away from the cheaper kits.
  6. 31Apickup
    31Apickup
    You’ll also have to come up with some radius rods to mount he rear ended once you get rid of the torque tube.
  7. 31 Chopped Coupe
    31 Chopped Coupe
    Absolutely spend the little bit extra and go with Hot Rod Works kit. I have had no issues whatsoever with mine. Good quality stuff!
  8. brading
    brading
    As for the radius rods here is one way of doing it. Two tubes one each side from a brackets fitted to the wishbone at the Red dot to brackets fitted to the banjo at the Yellow dot.
  9. Truckedup
    Truckedup
    What I did on the mid engine street lakester built for a friend....All made from parts laying around an some lathe work and welding. It doesn't leak or vibrate but this car doesn't get a lot of miles....
    12372302504_f4442e9dbe_c.jpg 12372318914_4426f95b58_c.jpg 13173828085_2b231f0221_c.jpg
    flyin-t likes this.
  10. gbones32coupe
    gbones32coupe
    Dude I may have to" steel"your idea on the rear ladder bars you made that is a dope idea why did I not think of that. That is exactly the idea I needed. I hope you do not mind but I love the look of that. And it is a period look. I'm building a 32 mid engine potvin blower set up. You can check it out in build threads 32 gbones32coupe
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  11. gbones32coupe
    gbones32coupe
    Dude do you have a build thread on This car I'm intrested pm me or post more pic of the car I could not find it. It's cool man love it
  12. Ken Smith
    Ken Smith
    Alliance Vendor
    deucemac, warbird1 and rusty valley like this.
  13. LB+1
    LB+1
    from 71291
  14. LB+1
    LB+1
    from 71291
  15. LB+1
    LB+1
    from 71291
    Thanks on the heads up
  16. LB+1
    LB+1
    from 71291
  17. LB+1
    LB+1
    from 71291
  18. Truckedup
    Truckedup
    It the car is in a lakester build thread here about 5 -7 years ago. unfortunately, a lot of the build photos were lost in a computer **** up...There might be a few more , I will have look for them. The same car is my avatar.
  19. LB+1
    LB+1
    from 71291
    I lucked up - found a good deal on this - Thanks everybody![​IMG]
  20. Ken Smith
    Ken Smith
    Alliance Vendor
    That looks like a Model A rear end. Nothing interchanges with a '40.
  21. LB+1
    LB+1
    from 71291
    It is gathering up stuff for my TT build. Engine 140 mercruiser, T-10, Model a front axle as well as rear axle I wanted 39,40 rear for the already in place juce brakes. [​IMG]
  22. If the 40 Ford rear is a truck rear you will need a machinist that knows his ****. In the truck rear the pinion and the driveshaft was one piece.
    Other wise you can get the parts you need from Speedway as a kit. I know that is whimping out but it is the easiest way.
  23. LB+1
    LB+1
    from 71291
    Thanks and its a true story, go back up a few posts. Then you will see the way I now going. Found a super deal on converted to open shaft model A rear. I guess I will convert old school 40's backing plates ect. to juice drum brakes.
