Technical Ford 9" rearend question
Discussion in 'The Hokey Ass Message Board' started by "T'RANTULA", Jan 30, 2021.
  1. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I have what I beleieve is a 9" ford but not entirely sure but the bolt pattern is 5x4.25". I dident think they made a 9" with a bolt pattern other than 5x4.5" and 5x5.5". I have no idea what the rearend originally came from. Hoping I can just swap axles to a 5x4.5 bolt pattern. Has anyone seen this or have any idea what this could have came out of? 20210130_164647.jpeg 20210130_164625.jpeg 20210130_163538.jpeg 20210130_163754.jpeg
    Sent from my LM-K400 using The H.A.M.B. mobile app
  2. First off that is not the way to measure wheel pattern. It is clearly a 9" and being it's in a Truck probably 5 on 5.5 pattern unless it's in an Econoline.
  3. I think T bird, Cougar from the late 80"s had that pattern.
  4. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Its not the original rear to the truck, its under a 65 gmc truck and I have some 5x4.5 wheels off a mustang that will not fit lug pattern is too big. Please dont bust my balls too bad ive always measured wheels that way and never ran into this issue...
  5. oldiron 440
    oldiron 440
    They all had 5 on 4 1/4 but had IRS.
    The Lincoln verse I had a 9" with 5 on 4 1/2 with disk breaks.
    irishsteve likes this.
  6. nobux
    nobux
  7. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Thanks for the help clearly im an idiot that measures wrong. Hope everyone got a laugh at my ignorance atleast. [emoji23]
  8. No body is laughing at ya because none of us knew until it gets explained to us. Your doing fine. At least you asked for help.
  9. Doublepumper
    Doublepumper
    from OR-WA, USA
    Meh....we're all born ignorant. Live and learn....name of the game;)
    Boneyard51 and "T'RANTULA" like this.
  10. grumpy65
    grumpy65
    I'm only seeing four studs ?????????????????? Am I wrong?:confused::confused::confused:
    Is there one under the tape measure?
    Edit: Sorry, under closer inspection I think there are five (head slap).:rolleyes:
    "T'RANTULA" likes this.
  11. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I also bought a set of wheels and the guy said they came off his mustang, I measured them the same way "wrong" and they turned out to be 5x4.75. Everything makes perfect sense now...
    RICH B and greybeard360 like this.
  12. 54vicky
    54vicky
    looking at the spacing of the other 4 I would say there is absolutely a 5th.no question about it
    grumpy65 likes this.
  13. hotrodA
    hotrodA
    Measure across, skipping one lug, add 1/4”. Works every time.
  14. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Don't worry about making a mistake........all of us have. At least you were smart enough to ask someone. There would be no need for this forum if we all knew everything.
  15. vtwhead
    vtwhead
  16. 1958 big Edsel and some Mercury cars had a 5 x 5 bolt pattern.
    Hnstray and X-cpe like this.
  17. I have found what is the easiest way for me to recognize a 9" rear. Look at the nuts holding the center chunk in. If you cant get to the bottom nut with a socket, it appears to be a 9" rear.
    Hnstray likes this.
  18. Ken Smith
    Ken Smith
    Alliance Vendor
    As noted above: measure across 2 studs, add about 1/4"
    Hnstray likes this.
  19. X-cpe
    X-cpe
    Mine came out of a mid 70's Lincoln Mark (?) with 5 on 5 and discs.
    Hnstray likes this.
  20. Hnstray
    Hnstray
    from Quincy, IL
    Mercury from ‘55 up to ??? (somewhere in the ‘70s) were 5 x 5”
    Edsel ‘58 Corsair and Citation were 5 x 5” (I have two of those axles)
    Several Lincolns had 5 x 5” but I am ‘fuzzy’ on what year models, but have seen them from the ‘50s and into the ‘70s on various models. So, some of the later versions are 9” and/or 9 3/8”
    Ray
    ekimneirbo likes this.
  21. Marty Strode
    Marty Strode
    Hnstray likes this.
  22. bchctybob
    bchctybob
    Need to get yourself one of these little guys, about $2 at the local swap meet.
  23. grumpy65
    grumpy65
    That would certainly have saved all the ink we have used on this thread..........................
    Wait..........the internet does use ink doesn't it?
    It must do. I can read this as I am typing..................:confused::confused::confused:
    Boneyard51, ekimneirbo and Hnstray like this.
  24. 54vicky
    54vicky
    but how would we p*** the -19 time:D:D^^^^
