Projects The Build Without (Now With) a Body
Discussion in 'Traditional Hot Rods' started by LostInOC, Jan 27, 2021.
  1. rusty valley
    rusty valley
    i have rounded and tapered the ends, lots of work. i have a vice out in the driveway i try to use for m***ive grinding projects so the snot doesn't fly everywhere. i would do ,maybe two ends each day after work, that was enough
    Chief 64 and Moondog13 like this.
  2. LostInOC
    LostInOC
    Aaaaand more painting. My wasted glove had something to say about all this... 0AADFD77-C07F-4BF8-B56B-178C79149360.jpeg 974C1830-FFF6-48BB-986F-66A16EB62315.jpeg DBCD2ADC-6CCE-4CDB-A0E4-21115616DB03.jpeg
    oliver westlund, brEad, bct and 9 others like this.
  3. warhorseracing
    warhorseracing
    from cameron wv
    A few years back while pulling in my driveway after g***ing up my 1929 Model A the deputy followed me in and when I parked he got out. Walking up behind me I could see in the mirror he was looking very intently at my 1929 YOM license plate. The Deputy knew me and said, Chuck I know your license plate is legal but what are the procedures for getting one approved. I opened the door to get out and he exclaimed, "You can't drive that car like that." pointing at the milk crate I had been sitting on. I just said, "you just followed me 6 miles from the gas station. Did I break any laws?".
    As far as the mechanical brakes, yes as long as they are sound and adjusted but they need maintenance unlike the "juice brakes".
  4. rusty valley
    rusty valley
    i drove my 34 coupe half the summer this year sitting on a wooden box. the real seat was dropped off at the upholstery guy last feb. said it would be done in april, in about july i got sick of the wooden box and borrowed some early lowback vw buckets, mounted them on a hunk of plywood, then got the real seat in october! i swear, i will never hire anybody ever again to do anything. thats the way it always goes
  5. leon bee
    leon bee
    How is it you get the whole garage?
  6. LostInOC
    LostInOC
    She gets the whole house, Pinterest and a husband to build, plant and fix whatever she wants.
  7. LostInOC
    LostInOC
    It’s a small victory but I’ll take it. Had a few minutes to spare in the garage so I flipped the front spring and got it hung on the frame. Right away, I realized the spring doesn’t have all it’s leafs as the u-bolts are a bit long. When I took it all apart, I noticed a bunch of washers on the original cross threaded U-bolts....I now know why. What are some thoughts on sorting this out? I’m thinking: run a die down the u-bolts and re-drill the cotter pin hole, fab up a leaf spacer, add washers, or just buy a new leaf. BF7CF8D9-8198-45A0-982C-E05CCAFE5517.jpeg 92451401-84E6-4348-BBAF-98C946057904.jpeg 64167194-A59B-44FC-BCD3-A04125336B9E.jpeg CDB30DE8-B71A-4983-84D1-83A853BD4144.jpeg
  8. embyman68
    embyman68
    A spacer like one of these should take care of it upload_2021-1-31_21-26-11.png
  9. LostInOC
    LostInOC
    Problem solved, thanks for the tip. DEBC6F4B-2893-41F1-BA56-14D10C66D70B.jpeg
  10. micshotrodgarage
    micshotrodgarage
    from colorado
    Hay, as a fellow Colo-raden I'm sure you could find body parts or even a Whole body @ Berts! in Englewood. Or I could hook you up with a T roadster body.
    oliver westlund and loudbang like this.
  11. LostInOC
    LostInOC
    Where in CO are yah? I stop by Bert’s at least once a week these days, they’ve got my motor at the moment. I’m sure Steve would let me know if they get a good body.
  12. LostInOC
    LostInOC
    Stuff is happening. Ignore the mess. 015E21A3-CA8D-44AF-BE5B-07D437F46FD5.jpeg
  13. AHotRod
    AHotRod
  14. loudbang
    LOL you call that a mess :)
  15. Budget36
    Budget36
    What a great way to build a rod, keeps you focused on the suspension, etc. gives you time to then look for the right body to put on it and probably at a price and in the condition you want.
    Heck, even a stripped out Model A body couldn’t be missing much “needed” stuff, right?
  16. Budget36
    Budget36
    I’m with ya my man, I clear spots to change a wheel;)
    brEad, loudbang and Cosmo49 like this.
  17. LostInOC
    LostInOC
    Front and rear suspension in for good. Took out 3 springs in the rear and needed to modify the rear clip bars to make up for the difference. Placed the smallest spring under the main spring...it all tightened up nicely. Spindles are painted and installed with new bearing and bushings, used the king pins that came with the car. Against better judgement, I used the original perches that looked like they’d been through a Canadian bar fight, the new nuts were forced into place like a shotgun wedding. Brake crosshaft is also on and moving freely. Lost some paint on the springs but that’s an easy fix. 763B5E56-F223-4FE5-83E3-76B40ABA6AF8.jpeg FE8F7F46-D1DB-4699-917F-2F6407792A58.jpeg 82996F4C-3DF1-4F31-BE2C-1302C9BB9D0A.jpeg 22D35BDF-48D4-4C23-9CB5-43097CD7CEB1.jpeg 8560B0E3-36C9-4872-90B0-F0F5E5AC7556.jpeg I’m convinced that building this car is 90% cleaning and painting while 10% is actually getting **** done.
  18. rusty valley
    rusty valley
    lookin good. usually model A front springs have clipped corner ends. yours are straight, like 32-34. must have got swapped out years ago. now you have bragging rights with " 32 parts" !
  19. LostInOC
    LostInOC
    Steering is in. Love seeing parts disappear from my shelves. 6C73B61B-4598-4C3F-92A5-2E972F61AEFA.jpeg
  20. LostInOC
    LostInOC
    Came home with a box full of parts to put hubs and brakes back on the car. At over $600, I had a bit of sticker shock. Oh well, if you’re gonna do it....do it right. My drums are measuring between .125” and .130” so I guess that’s good. Went ahead and stripped em down and painted them. They’ll get new bearings tomorrow. Backing plates will get cleaned and freshened up as well. After everything goes back together, the drums will get turned, really hoping they can be used. The guy(s) who had the car before me did a terrible booger weld job on many of the rear wheel studs. Even with a 1/4” of jelly welds, the studs were still loose. With nothing to lose, I used a 3/16” drill bit to drill 2 holes on each side of the back side of the studs and really put a hot weld fill in. They’re not going anywhere now. After a ton more cleaning, painting and wrenching....the car should be a roller this weekend. The guys at the shop said my engine is next in line and will be torn into next week. Next chapter: the transmission. 5D4F4F17-D1CB-4DBF-AD5B-C67335787B3E.jpeg 7FBC236F-3114-419B-A41A-EB6490097AE3.jpeg 4B581F04-B76B-4A9B-8DDA-B506CC2C418F.jpeg 79BFE51A-BE15-465B-8B54-4095BBFBF675.jpeg ABF1FB1F-4EA9-4ABC-A092-5BB3E8358DA2.jpeg 77F104D2-345A-48C9-B987-7FBECA14A5F8.jpeg
    brEad, shortypu, osage orange and 4 others like this.
  21. sloppy jalopies
    sloppy jalopies
    commercial springs often had square ends... henry wanted the trucks to ride a little stiffer...
  22. manyolcars
    manyolcars
    Mechanical brakes can work well if the car is a rarely driven toy.The problem is they take a lot of time to keep them working well if you use the car daily. Hydraulic brakes from 39-48 are pretty ****py too. I put Bendix self adjusting brakes on everything. They adjust evenly and rarely need attention. I dont drive any modern cars so I want good brakes with low maintenance
  23. burl
    burl
    from Minnesota
    Well adjusted mechanical brakes are fine anything else is fake news.I started the other way around with just a body,still a lot of work
  24. Joel W
    Joel W
  25. rusty valley
    rusty valley
    nice lookin body there BURL. must have been inside a barn to be that clean here in the swamp. Dodge?
  26. burl
    burl
    from Minnesota
    Yes dodge brothers i like odd ball stuff.Body was purchased at a long time local collectors estate auction.Think it was inside for along time.Its rough in a few spots but savable all i can afford for a roadster.
  27. LostInOC
    LostInOC
    Good lookin cars Burl!
    Momentous occasion for me, the front is sitting on her own weight. 28EE39A3-B1C2-4BE2-90FB-B48FC943D9E5.jpeg
  28. LostInOC
    LostInOC
    Missed breakfast, lunch and dinner but.....it’s officially a roller. From being trailered to becoming a roller in exactly 2 weeks, I’m exhausted. Right now it sits perfectly level at 21” front to back. It’ll be interesting to see how she sits when done. I may get lucky and not have to change a thing.
    D6A11B66-6D0A-4228-BEAB-CD53ABC5F4E1.jpeg DDE9656E-9E83-40D9-8BB5-36352CDB3C31.jpeg
  29. Aaron D.
    Aaron D.
    Way to go man, it's looking great. That's a lot of work to be done in only 2 weeks.
