Projects Frenzel Supercharged Ford 1936 3 Window Coupe-Chopped Build
Discussion in 'Traditional Hot Rods' started by TWO9FORD, Jan 17, 2021.
  1. TWO9FORD
    TWO9FORD
    Here are some pics of the chop from the Menges Twins Speed Shop:
    20200702_101612.jpg IMG_1743.jpg IMG_1750.jpg IMG_20200708_173219_935 (1).jpg IMG_20200703_205008_666.jpg FB_IMG_1593833717087.jpg FB_IMG_1593833632588.jpg FB_IMG_1593833629500.jpg FB_IMG_1594415749059.jpg FB_IMG_1594415743483 (1).jpg FB_IMG_1594415737859 (1).jpg
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    John Edge: Love the 36, only thing wrong is it's not in my shop in Nebraska. Gary
    VANDENPLAS, okiedokie, Stogy and 4 others like this.
  3. Forsman
    Forsman
    from Sweden
    That is going to be a really cool car !
    TWO9FORD, loudbang and chryslerfan55 like this.
  4. TWO9FORD
    TWO9FORD
    A little more progress... went with an open driveline so had to get the 3rd link setup with custom brackets and custom bracket for the hydraulic clutch amd brakes. 20210128_122944.jpeg 20210128_133021.jpeg 20210202_124352-1.jpeg 20210202_124334.jpeg 20210202_155531.jpeg 20210202_155536.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Tim, ibflyin, olscrounger and 10 others like this.
  5. TWO9FORD
    TWO9FORD
    Thanks!!
    Thank you! Getting a little closer each week.
    VANDENPLAS, Stogy and loudbang like this.
  6. hotcoupe
    hotcoupe
    I like everything that you are doing with that car!
    Tom
    TWO9FORD, Stogy and loudbang like this.
  7. TWO9FORD
    TWO9FORD
    Thank you! It's a dream build...
  8. TWO9FORD
    TWO9FORD
    Got the 40 Ford frame back from powdercoating... next is install fuel lines/block, oil filter, gas pedal, wire it and fire it up! 20210301_155107.jpeg 20210301_155122.jpeg 20210212_113934-1.jpeg
  9. FlatJan
    FlatJan
    i wasn't really a 36 guy but yours definitely changed my mind.
    man she's a beauty!
    Stogy, TWO9FORD and loudbang like this.
  10. Budget36
    Budget36
    Can’t explain it but I can say he looks better now than I did at 53.
    Such a great build going on here!
    TWO9FORD, loudbang and Stogy like this.
  11. Super Streak
    Super Streak
    from Florida
    Awesome build, like every thing you've done to it!
  12. v8flat44
    v8flat44
    OUTSTANDING !!!! Reminds me of a local 36 that had a "full house" 312 y in it back in the 60's. The owner put it in the barn years ago & passed away last year . The car has vanished....
    Your entire concept is fantastic. Is that your "180" .....?
    TWO9FORD, VANDENPLAS and loudbang like this.
  14. hotcoupe
    hotcoupe
    Have you come up with a way to drive the generator? Your car is beyond badass!
    Tom
  15. alchemy
    alchemy
    Any closeup pics of the finished wishbone/torquearm mount?
    TWO9FORD and HotRodWorks like this.
  16. fleetside66
    fleetside66
    Crazy cool project! Gene was 9 years old when that car was built...even crazier. I saw something interesting that might be a fit when you start dealing with the dash & gauges. Some guy on Ebay (not me) very recently constructed what appears to be a repop of Fenzel supercharger gauge. I never realized that such a thing existed & it would be interesting to hear the story about it. Anyway, it'd be a nice functional touch to your dash.
    hfh, Tim, Budget36 and 6 others like this.
  17. JOHN H EDGE
    JOHN H EDGE
    Thanks. My partner wanted to sell it last year and after the intervention he got his mind straight “what we have here is failure to communicate “
  18. This car is so wicked ... love it!
  19. wandi harry
    wandi harry
    This is one very cool looking ride.
    I am guessing the torque rod will necessitate some work to the floor at the rear?
    chryslerfan55, TWO9FORD and loudbang like this.
  20. TWO9FORD
    TWO9FORD
    chryslerfan55, loudbang and Stogy like this.
  21. TWO9FORD
    TWO9FORD
    A little more progress... drilled and tapped the block for the external oil filter.. should have the body back on next week and hopefully have that engine purrrring! 20210312_113315.jpeg Screenshot_20210320-033405_Gallery.jpeg Screenshot_20210320-033320_Gallery.jpeg Screenshot_20210320-033248_Gallery.jpeg 20210317_103729-1.jpeg 20210317_103655.jpeg
  22. TWO9FORD
    TWO9FORD
    Yes Aaron who built the Frenzel makes those gauges... I have one to install... plus a cool Frenzel fuel block.
    rumblytruck, Stogy, fegsta and 3 others like this.
  23. TWO9FORD
    TWO9FORD
    Stogy, fegsta, chryslerfan55 and 3 others like this.
  24. TWO9FORD
    TWO9FORD
    Yes. A custom bracket to hold it off to the side that will act as a tensioner as well... also had to do some modifications to the mechanical fan off a truck.... I'll post up some pics of it soon... that was the tricky part because most the frenzels I see are not on running cars just engines on stands...
  25. alchemy
    alchemy
    What happens when the one rear wheel goes up and the other goes down? That big bolt on the front of the wishbones just twists? Or do the wishbones bend?
    Many years ago I built a similar setup for my 40 tudor. I welded the yoke and ball from a front wishbone to the rear arms. Then used a couple wishbone ball caps to create a socket in the crossmember for the rubber ball. It gives complete, unhindered movement in all directions.
    Outback, lewk, HotRodWorks and 7 others like this.
  26. 19Fordy
    19Fordy
    alchemy: Very good point.
  27. TWO9FORD
    TWO9FORD
    It moves with the wishbones
    ibflyin, chryslerfan55 and loudbang like this.
  28. Subscribing! Very cool car. The Twins used to be up here...their work is amazing.
  29. birdman1
    birdman1
    I truely admire a guy that has a plan for the build and actually stays with that plan! I change directions all the time. love those 36 coupes.
    winduptoy and loudbang like this.
  30. alchemy
    alchemy
    Might want to re-examine that design.
    Outback, lewk, HellsHotRods and 5 others like this.
