  1. themoose
    themoose
    OK is this better...
  2. Squablow
    Squablow
    Damn, that was fast! That is exactly what I was thinking of.
    I must say, I like the red version better, but the white would be easier to do.
    But a paint job is still probably a ways off in the future. The wheels I'm fairly likely to do this summer though. I'm definitely sold there, and it's gonna need tires soon.
    Thanks for the rendering. When it comes time to paint this car, I'll circle back to these pictures.
    I've committed this summer to turning my '62 Imperial into this rendering.
    Gonna be a long road...
    OahuEli, James D, Peanut 1959 and 2 others like this.
  3. nitrobrother
    nitrobrother
    Pretty cool...are those Lincoln fins?
  4. Squablow
    Squablow
    The quarters are from a '61 Imperial, which shares the rest of the body with my '62 so they should line up really well.
    The car also has a mangled hood and some rusty spots that will need to be repaired. I'm going to try to match the paint and blend it in and only paint what absolutely needs to be painted, just from a budgetary and time standpoint. That might be the trickiest part. But any areas that are getting painted can get some custom work done there, so some emblem shaving and molding shuffling is going to happen as well.
    I've always wanted a '61 Imperial. When I got my hands on this one, I knew it needed the '61 fins (which I already had and was saving), and the quarters need work anyway so it's the perfect time. Now, if I can find a 60-63 2 door hardtop donor car for the doors and such, then this project is going to get more involved.
  5. 33 coupe
    33 coupe
    I'm trying to decide whether to leave the wide whites of change to black walls. Can someone photoshop this pic and give me a visual. Thanks 33 pass.jpg for the help.
    Gas_Tires_Oil and loudbang like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    Black walls PLEASE
  7. themoose
    themoose
  8. Busted Knuckles
    Busted Knuckles
    Help me figure out a classy mid 50s color for my 53 Buick Roadmaster. The interior is dark red and black. Id like to see what maroon, dark green, black, light grey, maybe even a pale yellow would look like. Thanks in advance buick side.jpg
  9. Squablow
    Squablow
    Not a Photoshop, and I'm sure someone who's good at color changes will step in and do one on your 2dht, but my dad had a '52 Roadmaster sedan that was red and silver and I always thought the paintjob on that car was perfect, would go with your interior, too.
  10. Busted Knuckles
    Busted Knuckles
    Is that your dads car?
  11. 33 coupe
    33 coupe
    Thanks so much. I like it that way. Maybe rear tires need to fill up wheel wheels a little better
    loudbang and Busted Knuckles like this.
  12. themoose
    themoose
  13. Squablow
    Squablow
    It was, he sold it. It had been burnt in a garage fire but only the old paint melted off and the windshield shattered, the rest was OK, so he bought it burnt and changed the color from black to this.
  14. themoose
    themoose
    Here's a few for you to ponder....
  15. shorrock
    shorrock
    Hello
    I bought this car last summer and found that the engine is very worn out, had gearbox trouble as well so decided to hop up a bit with a french flathead and a T5 transmission working on a Chevy rear axle. Mechanics are well under way but I want to decide about the final paint. Moose or anyone else having the ability - could you please change color brown to black and white to mouse grey. Would like to paint the car but might paint the roof and upper hood black.(everything above the door opener)
    Thanks so much!
  16. Busted Knuckles
    Busted Knuckles
    Moose, Thank you. Can you do a much lighter yellow? And bubble skirts!
  17. themoose
    themoose
  18. atch
    atch
    I always wondered what one of these would look like with the tail lights removed from the top of the fenders and different ones cut into the bumpers:
  19. Gas_Tires_Oil
    Gas_Tires_Oil
    Thinking about Scallops on my '31. Cream or Silver, or any other color you think. Also I'm unsure about starting it in the cowl area or just on the sides. Can someone do me the favor? Thanks in advance.
      287.1 KB
  20. Rot 'n Kustom
    Rot 'n Kustom
    Here are three: Mandarin Red, Mandarin Red and Dark Grey, and Sapphire.
    ZZ 53 Roadmaster 00 Final.jpg ZZ 53 Roadmaster 01 Final.jpg ZZ 53 Roadmaster 05 Final.jpg
  21. nitrobrother
    nitrobrother
    Mmmm....that Mandarin Red and Dark Grey is tasty.
  22. Rot 'n Kustom
    Rot 'n Kustom
    Here's a similar Imperial I did awhile back. Taillights in the trim.
    loudbang, Squablow and themoose like this.
  23. themoose
    themoose
  24. themoose
    themoose
  25. themoose
    themoose
  26. shorrock
    shorrock
    Peanut 1959, loudbang and themoose like this.
  27. 33 coupe
    33 coupe
    Can you show it to me with white wall tire and black wheels and maybe even black walls tires and black wheels.
    Thanks for your help
  28. themoose
    themoose
  29. atch
    atch
    This cleaned the lines up greatly. I like it way better than the factory version. Thanx.
    And here's the original for comparison:
  30. Squablow
    Squablow
    This would be easy enough to do using a '63 Imperial rear bumper and putting tail lights in the reverse light holes. I agree, the design is much nicer looking without the "flashlights". I'm still going all-in on the '61 fins, but that is a nice, clean look.
