Hot Rods Resurrection of an Old Hot Rod
Discussion in 'The Hokey Ass Message Board' started by JNKYARDDOG_1, Aug 12, 2020.
  1. TomT
    TomT
    I agree!
  2. ct1932ford
    ct1932ford
    Coming along nice. Sorry about your Dad. RIP
    chryslerfan55, loudbang and TomT like this.
  3. Finally little more progress..
    Got the transmission completed and back in...
    brEad, LAROKE, loudbang and 2 others like this.
  4. A little work on the engine.. Got rid of the shiny FUGLY and gave the oil pan a brushed look.
    Intake set on with rebuilt carbs..
    and a look to see if the mag would fit.
    The air cleaner I want gonna hit it SIGH
    shortypu, brEad, LAROKE and 6 others like this.
  5. A quick mock up of grill and hood,....
    But with rad in place it is going to be a few inches short even with grill right up to rad...
    Another big SIGH !
    brEad, LAROKE, loudbang and 4 others like this.
  6. Stogy
    Stogy
    Can you notch the air cleaner aka makitfit?...
  7. was looking and looking for a fan to use but it was either wrong rotation a stinking flex fan or just to large. Seen a 4.3 fan in back of trash truck and was about right size.. hmm again wrong rotation though.. UGH
    So looked at my solid axle conversion s10 blazer with a 2.8 and WOW look at that cute little ****** and correct rotation to boot.
    dont think I am gonna need a riser
  8. Here is what I want to use...
  9. Stogy
    Stogy
    :rolleyes:...well that would be a sizable notch...I hope you have a Plan B...:oops:
    Maybe risers off the carbs, there must be a bottom housing that goes with that I suspect...there seems to be some wiggle room above...some...
    I just noticed you don't have the
    mag in...:oops:
  10. You are correct...
    Yes there is a bottom plate of sorts I started making from 3 different 2bbl air cleaners.
    As you can see the Mallory fits...
    I would have to raise the air horns for the base 4 inches to clear the mag ..o_Oo_Oo_O
    loudbang and Stogy like this.
  11. Stogy
    Stogy
    Yes you may have to look at other options...certainly an obstacle,
    Perhaps offsetting the filter box and studs fwd could achieve the goal...
  12. Almost forgot one other thing... Added some noisy gears, Dont know if there gonna be heard over the headers..
    61SuperMonza, brEad, LAROKE and 2 others like this.
  13. AS much as I tried the Mallory is the route I have to go.. The carbs are LARGE base Rottenchestors.
    Nothing off shelf for it beside those stinking helmet's. With the air cleaner sitting where it wouldn't obstruct the carb flow it still sits over the dizzy.
    Also the top plate has 2 factory notches the the rad support rods meet together like factory..
    And yes I will have to Z the air cleaner rods go go thru the holes properly.
    brEad, loudbang and Stogy like this.
  14. 1-SHOT
    1-SHOT
    from Denton
    Leave room for when the engine torques over, both sides because the engine torques the opposite direction in reverse.
  15. Stogy
    Stogy
    Tight, Tight, really tight...if you fabbed the lower box to have .5 to 1" of clearance above the carb you could move it fwd and the air could still p*** freely into the carb but would it look wacky moved fwd that much?...I also see the water neck is also near under it which might also be a headache...just thinking out loud...
  16. Rocky
    Rocky
    Classified Editor
    Yeah, only the Rocky 33 was a little rougher than this 34. 33interior.jpg 33leftrear.jpg 33rfront.jpg
    bchctybob, loudbang, Tman and 2 others like this.
  17. Stogy, Runnin shine and loudbang like this.
  18. oldiron 440
    oldiron 440
    What filter element is that? It looks to be 3" tall.
    Stogy and loudbang like this.
  19. K&N #e1963 it is 3 inch tall
    oldiron 440, Stogy and loudbang like this.
  20. oldiron 440
    oldiron 440
    Thanks, I have used that air cleaner for 20 years but the short filter from Ford would cause fuel to be pulled from the bowl vents.
  21. Well going for it again.. Woodward right around the corner, And planning Dads funeral same time, Covid restrictions did not allow the funeral.
    Got some done last weekend made the fuel lines for the carbs instead of the hoaky *** mess there was that came with them.
    First time bending/fitting and flaring lines... OH what a joy that was, After about 6 s****ped pieces this was the finish.
    shortypu, bchctybob, brEad and 4 others like this.
  22. Then mounted the fuel pump and as close to a factory line was made to run to the carbs.. Think it is tacky just running a rubber line up..
  23. And YES the top bolt for the fuel pump rod access/bracket hole will be plugged, Ask me how I know this sto0pid reason not too :eek::eek:o_Oo_Oo_O
  24. Then on to making the plug wires fit..
    Also cleaned the pulleys and a shot kote of Krylon semi flat paint.. Painted the water pump and glued into place.
    Almost rdy to fire this thing and break in the cam.
    shortypu, tb33anda3rd, LAROKE and 5 others like this.
  25. Tonight mounted the fuel tank and starting to run the fuel lines up front.
    bchctybob, wheeldog57, brEad and 6 others like this.
  26. studebaker46
    studebaker46
    one hardest jobs to me is making fuel lines look decent and still function you've done an excellent job Tom
    brEad, LAROKE and loudbang like this.
  27. Thnx Tom
  28. 48 Ford Pitman arm indexed and bent to fit...
    All this little **** is time consuming UGH !
    Stogy, bchctybob, LAROKE and 3 others like this.
  29. Got the LONG weekend so time to get some more done.
    Headlights mounted with Halogen conversion. Need to mount the grill yet..
    Stogy, brEad, LAROKE and 1 other person like this.
