Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. King ford
    King ford
    from 08302
    WOW !! JamieUc, outstanding worksmanship...and vision....and glad to see period correct components and vision...I definitely have had a soft spot in my heart for tanks ever since I saw one in an article about bonneville in Hot Rod magazine about 50 or so years ago....if I were to ever run across an empty for a decent price I probably won't be able to pass it up!!!
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It would look great pulled behind your pickup.
    King ford, chryslerfan55 and loudbang like this.
  3. JamieUC
    JamieUC
    from Swansea UK
    A litle bit of progress on the tank this week, putting in a fire wall between me and the engine, will post some pics at the weekend.
    I did try the oven cleaner on the quickchange rear cover that Ricks garage sujested but didnt do much, it was a UK brand not the "Easy off "Rick sujested. Will have to try get some Easy Off.
    Got some header flanges delived today from Wengparts, couldn't resist a pic of these with there business card, the card made me laugh.
    EVL401, brEad, 40two and 7 others like this.
  4. nobby
    nobby
    the caustic soda you want is
    oven pride
    its a caustic soda gel,
    bit strong
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    What did you use for a driver / engine firewall?
  6. JamieUC
    JamieUC
    from Swansea UK
    Some photos of this weeks progress on the tank.
    I've been making a fire wall as I want the engine compartment sealed off from the passenger space, proably a good idea when you've got a supercharged flathead roaring away six inches behing you.
    Bulkhead is 1/8" steel plate, so fairly stout. First picture is wooded template and plasma cutter, not very traditional but sure makes life easy on a big peice like this.
    Now its time to get the seat out, this was one of the first parts I got for the build, I'd been planning the build in my head for a while and in walks a good freind and says "look what I've just found" and shows me a picture of this vintage aircraft seat, anyways a bit of bartering later he turns up with the seat for me.
    Havent got a clue what this came out of but judging by the fact its got a swivel base I'm thinking gunner or navigator, If anyones got any leads on its history, what plane it might be from, I'd love to know more about it.
    Here the swivel base has been removed to make it low enough to fit in the tank.
    In the pic above the white chaulk line is where the top of my head is with helmet on, Ive deliberatly made the firewall a bit bigger in this area and will cut it down to size once all the roll cage is fitted.
    ratrodrodder, 40two, GordonC and 13 others like this.
  7. brepil
    brepil
    Great progress Jamie. I can't wait to see this running.
    Brett.
  8. JamieUC
    JamieUC
    from Swansea UK
    Also spent a bit of time looking at the ride hight, rear is about right but front is to low so I need to lower the front crossmember two inches, the crosmember I've already made was to narrow for this to work so I've knocked up a new one out of a bit of box.
    Finished and ready to fit.
    brEad, GordonC, AHotRod and 9 others like this.
  9. JamieUC
    JamieUC
    from Swansea UK
    Hi Brett
    I've made my mind up I'm gonna crack on with this and aim for getting it finished in time for Pendine 2022 .....see how it goes.
    Gonna PM you, I've got a question.
  10. FORDY 6
    FORDY 6
    Nice!
  11. woodbutcher
    woodbutcher
    :D Hi Jamie.Very nice Sir.I`ll saddle up and go along for the ride.Every time I see one of these threads about a belly tank racer and hear the builder lament about the dearth of same,I remember the piles of them that were just laying around for the asking at the local airports that were the local Navy bases during WW2.There were three of them around the town where I grew up in Vero Beach, Florida.
    Main was at Vero Beach.Then there was one at Ft Pierce and one at Sebastian.Vero was in the middle and Sebastian was about 15mi North and Ft Pierce was about 15mi South.
    Ahhhhhhh those were the days.
    Good luck.Have fun.Be safe.
    Leo
  12. JamieUC
    JamieUC
    from Swansea UK
    Mocking up the roll cage, I haven't got the equipment to bend the hoops so will be getting these done at a roll cage shop. Spent quite a bit of time sitting in it with my crash helmet on day dreaming about racing down the beach :) 20210130_145028.jpeg 20210130_145013.jpeg
    brEad, cheddar, GordonC and 15 others like this.
  13. 26 T Ford RPU
    26 T Ford RPU
    Looking real good !! JW
  14. gbones32coupe
    gbones32coupe
    Hey maybe we can go to Bonneville together when we get our cars done. Great work you are a cool cat
    Sent from my LM-Q720 using The H.A.M.B. mobile app
    JamieUC, loudbang and 26 T Ford RPU like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    I intend to take mine there when its done. JW
  16. 26 T Ford RPU
    26 T Ford RPU
    Are you following the SCTA rule book with your build? JW
  17. bandoola
    bandoola
    Excellent work. You will have a blast in that car.
    The external tanks for the P-38 ranged in capacity form 150 gals to 300 gals, and there were variations in dimensions and capacities do to different manufacturers. Early model 38's had the intercoolers in the leading edges, this proved to be a bit of a problem as there were vunerable to enemy gunfire. The intercoolers were relocated to the nacelles post G models, and 60 gal leading edge tanks were installed. The L had reinforced rails capable of handling 2000lb bombs or 300 gal drops. The L had 2 60gal reserve tanks forward, next to the*****pit, and 2 90 gal mains aft of the reserve tanks, plus the 60 gal outer or leading edge tanks.
    This is a picture of me (circa 1994ish) in a P-38L - sans the drop tanks.
    You can see the red fuel caps near the walk-strips. The drop tank rails are protruding under the wing, below the walk-strips.
    Tman, 40two, Surfcityrocker and 10 others like this.
  18. 282doorUK
    282doorUK
    That seat has just perfect patina, and this has got to be a first, a car build starting with a seat!
  19. gbones32coupe
    gbones32coupe
    Yes the book is on my cowl at all times
  20. typo41
    typo41
    Be sure to sit in with a fire suit or at least very heavy coat when you check for room, you would be surprised how much they add/subtract in the available limited space
    loudbang, 26 T Ford RPU and 51504bat like this.
  21. treb11
    treb11
    IDK the SCTA rulebook, but it would seem there would be a need for longitudinal tubing below the main rails to protect drivers legs. Just a skin of aluminum between your***** and sandpaper!
    Sent from my SM-G965U using The H.A.M.B. mobile app
  22. JamieUC
    JamieUC
    from Swansea UK
    Yes got a copy of the SCTA Rule book and making sure my car would comply with that aswell a rules for racing here in UK, just incase I make it to Bonneville one day...
  23. JamieUC
    JamieUC
    from Swansea UK
    Wow..I bet your a proud man having flown in that P38, I know I would be, Ive been up in my mates microlight and thought that was fun but flying a P38 would be something else.
    I did pick up a copy of Genn Gurneys book the P-38 Lightening on ebay last week so I can brush up on my history and tech a bit.
  24. JamieUC
    JamieUC
    from Swansea UK
    Yep dont want my***** skiding down the beach at high speed, there will be more roll cage to come this is just the start.
    RMR&C, loudbang and 26 T Ford RPU like this.
  25. bandoola
    bandoola
    The 38 was one of the coolest, there are few of them remaining in relation to the other fighters, and they have some unique flight characteristics. We had drops for the 38, the P40, and the P51; I never flew the 38 with the drops mounted but I was told the drops had a bit of a "keeling" effect. I've flown the P40 with and without a center mounted drop, and you could definitely tell the difference. Both the 38 and 51 had more range than the 40, so we ran the drop on the 40, mostly for the cross-country flights to and from airshows. The drops were popular in the 70's and 80's when airshows - especially at Military Bases, would give you all the fuel you could carry.
    I****ume you checked with the guys at Duxford when you were looking for an original tank. I doubt they would have parted with one, but always worth a try.
    The fuel burn schedule would generally be the same for all aircraft with external stores: take-off/climb(15 minutes) - use the tank with the vapor vent return (so as not to overflow a full tank), on the 38L this would have been the 60 gal res tank. Next would be outboard or external - if equipped. The idea would be to get closer to the target with as much on-board fuel as possible. Drops would have been discarded when: depleted or engaging.
    So, anyone hunting for a survivor tank - the L would have been burning about 1 gal a minute once in cruise. If you figure 25 -30 minutes, plus 5 hours - that's where to start looking. Good luck.
    brEad, The 39 guy and loudbang like this.
  26. King ford
    King ford
    from 08302
    Thank you for the compliment Frenchtown Flyer!!
  27. 26 T Ford RPU
    26 T Ford RPU
    P-38 tanks are around $20K U.S now days, that's why i went F-Glass P-38 for my build, $3 K NZ. JW
  28. 26 T Ford RPU
    26 T Ford RPU
    These got me excited at Chino Ca. JW
    The 39 guy, loudbang and chriseakin like this.
  29. bandoola
    bandoola
    Roger that.
  30. COCONUTS
    COCONUTS
    How about this for a drop tank, one from a B-58, these were built and flown in the 60s.
