Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. AmishMike
    AmishMike
    Great build, admire your skills. Thought engine was “regular” flathead. Now guess some kind of “f head”. Like 64dodge440 says above, can u show pictures of head &explain how she works?
    VANDENPLAS, loudbang and Thor1 like this.
  2. noboD
    noboD
    Are the valves horizontal like a Duesenberg?
  3. Ziggster
    Ziggster
    That looks like one heavy sona*****. Those coolant p***ages are tiny.
  4. animal8324
    animal8324
    from nj
    There is a single cam with a "rocker rail" directly above it. This serves asapivot point forthe rockers. The valves are horizontal. The combustion chamber is kindof an inverted T with very little clearance between the piston and head.
    On the side of the head that isntpictured sub headleadts with the spark plugs mount.
  5. noboD
    noboD
    YES, it's way cool. Thanks for showing that. Moves your build up the ladder for me!
    Stogy, loudbang and warhorseracing like this.
  6. AmishMike
    AmishMike
  7. AmishMike
    AmishMike
    Trying to get head around your head.... is my rough drawing sort of right?.. never seen one like that
    Stogy and loudbang like this.
  8. RodStRace
    RodStRace
    Found this (gotta blow it up) from this site
    https://gr***rootsmotorsports.com/forum/cl***ic-cars/1931-auburn-12-160/104608/page1/
    There is a reference to an Auburn site, but you can't navigate to the engine page from the home page.
    Here's a link
    http://www.1932auburnsedan.com/v12-engine-home.html
    There are also references to the V12 shop page, but it appears to be MIA.
    It was a Texas Fire Truck group that restores and sells parts, with this V12 offshoot.
    Reference
    https://www.speedville.com/texans-think-big-v-12-shop/
  9. animal8324
    animal8324
    from nj
    More like this Amish mike
    Stogy, RMR&C, brEad and 2 others like this.
  10. Ziggster
    Ziggster
    Very interesting. Never knew anything about this type of arrangement before.
  11. noboD
    noboD
    Amish Mike, how about that Udder Choice? Love that place.
  12. AmishMike
    AmishMike
    Sort of understand head design - sure a new one for me. Thank u everyone that added info. Udder choice for soup sandwich & icey dessert
  13. animal8324
    animal8324
    from nj
    I pulled the stuck valves tonight and found the valve guides were crumbling.
    One guide even came out on the valve lol. 20210203_173416.jpg 20210203_173427.jpg
    Im willing to be that a piece of the valve guide is what cracked the piston.
    Off to the machine shop with her.
  14. AmishMike
    AmishMike
    Wow, what I would call 2 heads. One over the cylinders & a smaller one over combustion chamber. Sure never seen one like that - but learning. Great build
  15. RMR&C
    RMR&C
    from NW Montana
    That engine is bizarre...and really cool! Enjoying your build!
  16. 64 DODGE 440
    64 DODGE 440
    from so cal
    Love what you are doing with this build.
    Thor1 and loudbang like this.
  17. animal8324
    animal8324
    from nj
    I dont feel comfortable doing any heavy fab with the engine open but Idid convert a firetruck pump cap into my g*** tank cap 20210213_170335.jpg 20210213_181228.jpg
  18. loudbang
    Cap looks great all cleaned up. :)
    Thor1 likes this.
  19. crider
    crider
    This is one of the coolest builds I have seen in along time
    Ziggster, Thor1 and loudbang like this.
  20. animal8324
    animal8324
    from nj
    Finished welding my tank today. Here's a pic of my poor boy leak detector
    Also started adding beauty brackets to my seat frame.
    This part of the build ****s because you feel like your tearing apart everything you've done but it is what it is.
    20210228_125821.jpg 20210228_143923.jpg 20210228_165014.jpg 20210228_165024.jpg
  21. getow
    getow
    Ha your welds are nicely laid dimes. Makes mine look like crumbled sausage. Lolol. Keep up da good work. Way cool.
    Thor1 likes this.
  22. animal8324
    animal8324
    from nj
    Getting ready to order sprockets. What would a 44 36 combo look like for rpm at 60mph Desmo Dog?
  23. DesmoDog
    DesmoDog
    loudbang, Thor1 and warhorseracing like this.
  24. animal8324
    animal8324
    from nj
    That seems like a good ratio. I think thats what ill order. Thanks for the info man!
  25. animal8324
    animal8324
    from nj
    I have begun collecting the final parts for the driveline. I searched hi an low and found a 1 foot chunk of 11"id .5"wall dom to create extend brake drums to attach my hubs to my sprockets which are also on order.
  26. animal8324
    animal8324
    from nj
  27. warhorseracing
    warhorseracing
    from cameron wv
    Will you weld the sprockets solid to the shafts or will the back one need a key way cut into it?
  28. animal8324
    animal8324
    from nj
    The rear sprockets will be welded to the Hubs and the fronts will be bolted to the axles
  29. warhorseracing
    warhorseracing
    from cameron wv
    OK, thank you Sir. I was wondering how you would eliminate any slippage. So the larger of the two still need the bolt circle drilled?
    chryslerfan55, loudbang and Thor1 like this.
  30. animal8324
    animal8324
    from nj
