Technical 40 Ford Woody Dash Identification
Discussion in 'The Hokey Ass Message Board' started by Itchy, Feb 2, 2021.
  1. Itchy
    Itchy
    So I bought a 40 Ford Woody last summer that was missing the dash. Unbeknownst to me I purchased a dash for it not knowing that the woody and convertible use a slightly different dash than the coupe/sedan. My question is, what are the differences between the two style dashes? I would like to find out if the dash I have is actually for a woody/convertible. The angles in pics online are tricking me and it’s hard to make out any differences.
    Thanks in advance.
  2. alchemy
    alchemy
  3. lothiandon1940
    lothiandon1940
    .....He would know.
  4. 40LUV
    40LUV
    from Mid Jersey
    I'm not much help, but the pointy "horns" on the upper corners of the dash are different on the Woodie/Convert dash. I'll try to take a picture for you, but my Convertible is currently snowed in. Someone on Ford Barn will know, if you post there.
    lothiandon1940 and i.rant like this.
  5. 40FORDPU
    40FORDPU
    Here is my dash from my '40 Convertible, if that helps.
    Itchy, lothiandon1940 and olscrounger like this.
  6. 40Vert
    40Vert
    Here are some close up pics of mine from a 40 convertible. IMG_7710.JPG IMG_7712.JPG IMG_7713.JPG IMG_7714.JPG
  7. Itchy
    Itchy
  8. Itchy
    Itchy
    Again, I’m ***uming but it looks like the coupe/sedan dash has a more subtle corner that isn’t as pointy as my dash.
  9. olscrounger
    olscrounger
    measure across the top corner to corner bottom too-I have several dashes to check
    lothiandon1940 and LOU WELLS like this.
  10. 40Vert
    40Vert
    Let me know if you need any measurements and I can measure tomorrow.
    lothiandon1940 likes this.
  11. LOU WELLS
    LOU WELLS
    from IDAHO
    If It Is Not This Then It Is Correct For Your Application...Removed From 4 Door Sedan.. DSCN2342.JPG
  12. Nitroholic
    Nitroholic
    from SoCal
    I just received Mike Kubarth's new "everything you ever wanted to know about the 1940 Ford" book available from the Early V8 Club. According to his photos and description (higher corners and top pull ashtrays) your dashboard is from a convertible produced after Jan. 1940
    Great book, by the way...........
    LOU WELLS and 40ragtopdown like this.
  13. goldmountain
    goldmountain
    Wouldn't it be easy enough to modify your dash to fit? '40 dashes get mounted in lots of other cars.
  14. Automotive Stud
    Automotive Stud
    That looks like a closed car dash you have, it appears the ears stick out a bit more, but it's very hard to tell from a picture. I've had them laying on top of each other and even then it's subtle.
    LOU WELLS and olscrounger like this.
  15. Itchy
    Itchy
    The woody has been sold, and I want to list this dash for sale. I don’t want to misrepresent this when I list it.
    LOU WELLS likes this.
  16. ronzmtrwrx
    ronzmtrwrx
    98DA8BF5-B5A9-411B-9FB5-15690B497989.jpeg This may not be relevant, since you’re talking 40 model, but on a 39, if you’re looking straight on at the dash, the ends taper up at the bottom from about 8-10” inboard to the outer edge. The area around the 39 gauges is noticeably different between the closed car and open car as is the glove box door. In your case, the 40 glove box doors look the same in the pictures, but it could be shaped differently from the gauges/glovebox out. I would measure the height at the outermost edge of the dash and compare it to a known Conv/woody dash. You can see the difference on the 39 in the pics I have posted. I’m repairing the gauge area of my Conv dash with a donor panel from a closed car. 93DEEF7D-F351-4782-B265-ADFA5D9EDD75.jpeg
  17. 40LUV
    40LUV
    from Mid Jersey
    Maybe these pictures will help. The purple dash is from a Convertible and the brown one is from a Sedan. IMG_6481.jpg IMG_6484.jpg
