Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. fastcar1953
    fastcar1953
    I've been playing with some old gl***. Going to try it on my own. I have 2 windshields and all the old side gl***. If it doesn't go well I will be on here asking for help. Back gl*** will not need cut.
  2. dehartcarl
    dehartcarl
    Unless the shape changed the side gl*** should fit. It just wount roll up as far.
  3. fastcar1953
    fastcar1953
    The shape changed with the slanted b pillars.
  4. Lloyd's paint & glass
    You drive here and put me in a heat pump, bring patterns and your windshield, I'll cut them, and we'll call it even :p:D
    saltflats and fastcar1953 like this.
  5. Lloyd's paint & glass
    As for my car(s), i drove by them in the driveway today and looked at the snow on them :(
  6. goldmountain
    goldmountain
    I have one of those van axles in my car. Shortened the long side 8" to center the housing.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  7. fastcar1953
    fastcar1953
    How about I bring the car and you cut and install them for that heat pump.
    saltflats likes this.
  8. squirrel
    Not a damn thing, except work around it....taping drywall and installing lights in my new shop.
  9. Lloyd's paint & glass
    DEAL! :D ;)
  10. Lloyd's paint & glass
    Looks like you're settling in squirrel :D
    juan motime likes this.
  11. junkyardjeff
    junkyardjeff
    Did nothing to them and waiting on a radiator that should be here any day.
  12. I like your Avatar! Especially the teardrop. Is there a thread or forum on here for travel trailers.?
    Ben
  13. blowby
    blowby
    from Nicasio Ca
    I'm a bit ahead of you, my new shop (I know it doesn't look new..) is far enough along that I got under the hood of the new toy today and tried to figure out where the $%@# ballast resistor goes, as apparently the previous owner didn't think it needed one.
  14. saltflats
    saltflats
    from Missouri
    I talked to the gas and light company about my options to get power and gas to an new garage plan.
    Fabulous50's and Lil32 like this.
  15. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I know this a forum about Hot Rods but damn Blowby ,how far is that Beautiful beam spanning in the new shop?
    bob b. likes this.
  16. Chappy444
    Chappy444
    Worked on making some various 30's and 40's Era front end parts work together...
    Chappy
  17. blowby
    blowby
    from Nicasio Ca
    They're 20 footers but sorry to disappoint, they're composite paralams. I got 4 of them plus about 40 I-joists out of a warehouse demo for $300.
    I found the ballast resistor hole in the Corvette firewall. Turns out it takes a special clutch head screw, right into the fibergl***. Or a wood screw.. :eek:
    Kinda weird place for one
    Atwater Mike and guthriesmith like this.
  18. TA DAD
    TA DAD
    from NC
  19. Joel W
    Joel W
    Salvaging not one, but two 32 heavy axles I found as a running gear under a buddy's propane tank. Close to getting done. Then to Okie Joe for a drop and drill. 1612555359890.jpeg
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  20. I,ll bet the one with the steering ball welded on in the middle lives up to it,s name .
  21. Lloyd's paint & glass
  22. Lloyd's paint & glass
    And to celebrate, my wagon yelled and said "let's go down the road and back big guy!" So we took a quick trip and parked in a different spot :D 20210206_150228.jpg 20210206_150241.jpg
  23. jockeyshift41
    jockeyshift41
    from Florida
    Fitted, drilled, painted and installed bed wood strips yesterday and today. [​IMG][​IMG][​IMG][​IMG]
    simplestone, Budget36, LAROKE and 8 others like this.
  24. 61SuperMonza
    61SuperMonza
    Hooked up the battery tender and checked tire pressures. Gave the motor a wipe down. I like it clean. 20200625_204208.jpg
  25. charleyw
    charleyw
    Worked on setting up motor mounts on the Faux 32, cheap laser came in handy.
    Budget36, LAROKE, Oilguy and 6 others like this.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    Minus 11 this a.m. , never left the house
    osage orange and Lil32 like this.
  27. Fabulous50's
    Fabulous50's
    from Maine
    Outta this thing
  28. 57 Fargo
    57 Fargo
    -40 here....no heat in the shop=stay inside
  29. RICH B
    RICH B
    Worked on the start of a grille surround today; stupid rod wasn't very cooperative in matching the shape of the grille; even though it seemed to last week when I bent it. Eventually capitulated and I tacked it to the mounting tabs. Took way longer than it should have.
    charleyw, Lil32, j hansen and 2 others like this.
  30. blowby
    blowby
    from Nicasio Ca
    Made a new mount for my steering rack. When I got my Bantam it had a Corvair box mounted in front of the grill. No room for rear steering so found a circle track rack narrow enough. Took a ton of adjusting but got it steering and handling great. Doing some winter maintenance I noticed the mount I had made was bent. So I made a new one out of 2x4 box steel.
