Technical C1 Corvette performance upgrades
Discussion in 'Traditional Hot Rods' started by C1/C2Guy, Oct 6, 2020.
  1. jimdillon
    jimdillon
    Movin on- maybe this will help.
    loudbang and 31hotrodguy like this.
  2. movin/on
    movin/on
    Jim: Thanks with that I can calculate the AA to CC measurements and get close to what I need.
    Movin/on
  3. movin/on
    movin/on
    Jim Looking at it again: measurement O is 7.75" from the datum line.
    Any idea how this measurement relates to the CL of the front and rear axle center heights?
    Movin/on
  4. jimdillon
    jimdillon
    No I am not sure of the relation and my cars are anything but stock in height. I see O as the centerline of the frame longitudinally in the center portion of the frame, when it is sitting level. If I had one stock I could take the 7.75 and set that measurement and then find the front and rear axle heights but anything I could do with mine may be a bit cloudy. I used this schematic when I repaired a frame that was out of whack and it came out well but never played with components in relation to the frame, other than when I mounted the body it worked out well. If I can take a measurement with what I have let me know. I have a frame with a Dana 60, a Ford 9 and a stock housing. All of the fronts ***emblies have been changed from stock height.
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Aren't the axle centerlines just a function of tire diameter?
    For example:
    6.70 x 15
    6.7 X 2 = 13.4
    13.4 + 15 = 28.4
    28.4 / 2 = 14.2
    There has to be some allowance for tire 'squish' but that should get you close.
  6. 31hotrodguy
    31hotrodguy
    Steering question? Has anyone of you ever used the quick steering adapter? Is it helpful or does it make the steering to hard for normal street driving? I may have asked this before but I couldn’t remember??
  7. 31hotrodguy
    31hotrodguy
  8. movin/on
    movin/on
    Does anyone have the weight of a bare body 1960 Vette? No interior, windshield, doors, hood or rear deck etc...
    I'm getting ready to take the body off the ch***is and need to find what it weights for lifting strength.
    Movin/on
  9. I've never used one but I have read about them. I believe there is a big increase in steering effort. A lot of the guys who switch to elect. steering use them.
    31hotrodguy and loudbang like this.
  10. v8flat44
    v8flat44
    I know where there is a restored 59 with dual quads. It doesn't need any performance improvements. Just say'n .......
  11. saltflats
    saltflats
    from Missouri
    There is always room for improvements. ;)
  12. 31hotrodguy
    31hotrodguy
