Hot Rods Had To Have Another Five Window After All.
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 19, 2020.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Patiently waiting,. HRP
    ct1932ford and loudbang like this.
  2. ct1932ford
    ct1932ford
    My original measured about 49-7/8" so I lost not quite an inch on either side. I know the re-popped dropped axles are also 48"
    bchctybob, Stogy and loudbang like this.
  3. ct1932ford
    ct1932ford
    Took spindles off to be dropped. I don't know why I thought they would just place the tie rod on top of the wishbone. Besides that they hit the axle, so unless you just want to drive straight they will need to be dropped.:rolleyes: No photos today, it is Sunday and not spending all day in the garage. Going to get some couch time.:rolleyes: Back at it tomorrow. :cool:
    Stogy, swifty, TFoch and 3 others like this.
  4. ct1932ford
    ct1932ford
    Have been moving snow the last few days as I am sure many of you HAMBers have.:mad:
    Did start to drop the steering arm and getting some things painted. On my way out to the Garage now. IMG_7670.JPG IMG_7671.JPG
  5. HOTRODPRIMER
    HOTRODPRIMER
    It's been could here in the Sunny South but none of that white stuff to deal with.
    Be careful Mark, I have heard of people getting hurt shoveling that stuff. HRP
    ct1932ford, Stogy and loudbang like this.
  6. seabeecmc
    seabeecmc
    How I dealt with the dropped axle on my '32. Ron tie1.jpg tie2.jpg tie3.jpg tie4.jpg
  7. ct1932ford
    ct1932ford
    loudbang and Stogy like this.
  8. ct1932ford
    ct1932ford
    Finished up the steering arm. It had some undercut welds and looked like it was ready to fail. I cut a piece out of a heavy flat washer and beefed it up. IMG_7674.JPG IMG_7675.JPG
    The bolt is keeping the spread the same while welding, so the heat did not pull it in.
    Stogy, lucky ink, alfin32 and 4 others like this.
  9. ct1932ford
    ct1932ford
    I use my plow truck 2001 S-10 only thing holding the bed on is the liner.:oops: Lots of rot. Every year I say one more year.:rolleyes: And with this storm I mostly used my snow blower because there was no place to put this snow. Close to 2 feet of it! May put a small block in the blower if this keeps happening.:p Lots of garage time.:cool:
  10. 270bob
    270bob
    Usually stock deuce axles measure about 51-3/8" center of king pin to center of king pin. Not sure why yours is narrow. I could see it though, I always like that original look cause anybody can buy a new one. However, you will obtain a little more fender clearance with that narrow axle.
    Sent from my SM-G960U using The H.A.M.B. mobile app
  11. ct1932ford
    ct1932ford
    My roadster's axle is dropped and it is 48". I had fenders on it at one time and it looked right. Maybe the Heavy axles are less than other 32 axles? I have been told the heavy axles run around 50" I could have missed the 1/8" when I measured by my self. Having a friend check his heavy non dropped . Keep you posted.
  12. seabeecmc
    seabeecmc
  13. 270bob
    270bob
    No worries, keep moving forward on your stuff. Don't let me distract you, I have plenty of axles to reference.
  14. ct1932ford
    ct1932ford
    Friend of mine measured his and it was 50-1/2"
  15. ct1932ford
    ct1932ford
    Well it has been awhile, but I'm back at it. Parts are being painted as I type this. I started the coupe up yesterday. I should be getting the frontend back together soon. Yes, I will post photos. It should look something like this Moose rendering! Black 5.jpg
  16. swifty
    swifty
    You've kept us waiting for 2 months for this post LOL
    I like Moose's rendering but then I like 32-5 windows.
  17. clem
    clem
    Yep, that will look good. (as your cars always do).
    So are you keeping the bumpers ? - would look good without them, ( but l won’t remove mine off my full fender car due to the poor driving skills of others demonstrated on the roads here ).
    ct1932ford and Stogy like this.
  18. ct1932ford
    ct1932ford
    Not sure about the bumpers. See when it's back on four wheels. I did put the short rear bumper brackets on. That helped. Thanks for the kind words. Mark
    clem, TFoch, loudbang and 1 other person like this.
  19. Stogy
    Stogy
    Looking good @ct1932ford, bet you're getting pretty excited?
  20. ct1932ford
    ct1932ford
    Dropping axle, spindles, ordering parts etc. all take time. Also waiting for weather to cooperate so painting can be done. Ted is painting right now. :cool:Two of my tires just got delivered. Back at it this week.:D
    loudbang, j3harleys, swifty and 4 others like this.
  21. ct1932ford
    ct1932ford
    Ted painted everything today. I will wait until mid-week to pick it all up.
    Get the roadster back together first . Then onto the coupe! Stay tuned. Big thank you out to tb33anba3rd.
  22. ct1932ford
    ct1932ford
    sacminiwheels, AHotRod, TFoch and 6 others like this.
  23. ct1932ford
    ct1932ford
    The roadster parts still need some work so I am back at the coupe. Got the spring back in and hope to get back at it today. Had more photos but they were too dark. Try and do better.:oops: IMG_7753.JPG IMG_7754.JPG IMG_7755.JPG IMG_7757.JPG
    alfin32, AHotRod, TFoch and 5 others like this.
  24. ct1932ford
    ct1932ford
    Got the spring in yesterday. Made a spacer out of solid nylon to take up the extra space. I left the top spring out. "how low can you go" Need to shorten the tie rod . King pins and spindles in. IMG_7761.JPG IMG_7762.JPG IMG_7767.JPG IMG_7764.JPG
  25. ct1932ford
    ct1932ford
    Still plugging along! worked on the shock mounts yesterday. They will need to be shortened once the shock get here. Been waiting for my front tires to arrive. Seems they were on there way with Fedx and got as far as NJ in route to me in Connecticut, then for some reason were put on a truck to Texas.:eek:
    Also waiting for shocks and some hardware. Put the backing plates on today and cleaned up some fasteners that were used by original owner. Here are some photos from the last couple of days. IMG_7769.JPG IMG_7770.JPG IMG_7774.JPG
    Not using these shocks. I have a thing about no covers.:rolleyes:
    Back at it tomorrow:)
  26. swifty
    swifty
    Love those fenders LOL
    What's wrong with the tires on the car?
  27. ct1932ford
    ct1932ford
    They are loners and very old anyway. Hard as a rock. Going black on black on black.[emoji41]
    Stogy, TFoch, loudbang and 1 other person like this.
  28. kidcampbell71
    kidcampbell71
    Oh man .. ... @3wLarry approval !! Well, minus the obligatory "no fuggin'" fenders commentary. But, HEY ( !!! ), black on black on black. Love it !!!
    Stogy, TFoch, ct1932ford and 2 others like this.
  29. earlymopar
    earlymopar
    Looks great. What diameter did you go with for the dropped center section of your tie-rod?[/ATTACH][/QUOTE]
  30. ct1932ford
    ct1932ford
    Did a hardware run last night over at Ted's
    Finished up shortening shock brackets now that I have everything in place. Got them painted for install tomorrow. Prepped steering damper for installation by drill and tapping wise bone. IMG_7786.JPG You can see how much I had to remove. That was in the plan all along.
    Front tires arrived today from second order. First ones are lost in Texas. I have to say Speedway stood up and made good on Fedx losing my tires. :cool:
    Now I have to decide what rims I will use!:rolleyes:
    OR 40's
    alfin32, Stogy, AHotRod and 4 others like this.
